ragyan03 ragyan03 is offline
Car: 08 335xi
Default MHD stage 2+ - 08-22-2020, 10:49 AM
Hey guys just a quick question. So, I have been running the JB4 with the MHD BEF for a while now. I feel like there could be some improvements. I was wondering if I did the MHD stage 2+, do I just leave the JB4 settings the same as the BEF and just upload the stage 2+ with the JB4 disconnected and then connect the JB4 back after the flash?
I am PWG, FBO, running e20-e25 mix on my car. I have definitely felt a difference with the BEF compared to just JB4 on map 5. Ran a best of 12.7 at 109mph with the BEF. I think I was only able to hit 13.2 at best on the JB4 alone. Crap all season tires and I could not get the car out of the hole enough even after lowering tire pressures. Couldn't get under a 1.9 60"
Goal is to 12.5 on the same tires until next summer after the new wheel and tire combo is in. Hope for 11's next year after a fuel pump upgrade, e50 mix and custom tune.
E90 335
F30 335
Car: guess...
Default 08-30-2020, 08:33 PM
Turbo upgrade?
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 08-31-2020, 07:21 AM
You won't gain with an MHD flash instead of a BEF. Focus on air (turbo) and fuel (hpfp and lpfp). Air + fuel = power.
2013 E92 335i XDrive
JB4, MHD E85 BEF, EOS PI, Fuel-it Stage 2 LPFP, XHP Stage 3, XDelete Sport, 3.5 Bar TMAP, VRSF 7 HD IC, GFB DV+, VRSF D/P, VRSF CP, PE Mod, ST V1 Suspension.
Car: guess...
Default 08-31-2020, 10:11 AM
The MHD has the ability to modify the timing table(s) according to your typical fuel of choice. The stage 2 might be too spicy for your day 2 day driving.
435gc 435gc is offline
Default 08-31-2020, 11:49 AM
Does your timing look good with map 5? If so a custom map 6 could eek out some more boost.
With pwg you could probably run more ethanol than e25.
