Whateva's Avatar
Whateva Whateva is offline
Car: E90
Default OBD wiring schematic - 01-31-2020, 06:29 PM
Can anyone share the wiring schematic for an F series N55 OBD port?
I am trying to wire up ShiftP2 shift light
Shift-P2 - Ecliptech
2011 F10 535i | D Shoup Flash | PS2 | GFB DV+ | Wagner FMIC | Helix Overdrive | Sprint Booster | CDV Mod | Koni Yellows | Eibach Sports | M5 Sways | Spec 2 Clutch | SMF | UUC SSK | Custom Inlet | Custom Dynomax Exhaust
Whateva's Avatar
Car: E90
Default 01-31-2020, 09:37 PM
Looking for the RPM pin, but now its looking like I should get it from the cluster: Instrument cluster
The diagram on this link looks like the RPM is in the (KOMBI) so maybe it is not as easy as tapping a wire into an "RPM signal". Does anyone or has anyone ever tapped into the coil wires?
Default 02-03-2020, 10:50 AM
We get RPM from the third unused pin on the black OBD2 cable.
Whateva's Avatar
Car: E90
Default 02-03-2020, 11:41 AM
BMW OBD-II diagnostic interface pinout diagram @ pinoutguide.com
This diagram shows 2 & 3 pins not being used. Is this correct? and if so, I could tap that 3rd pin to readout an RPM signal?
That link above is from a diagram showing a 2001 535 so I just wanted to be clear.
However, this is a diagram from an e90 that shows pin 3 as a vendor option.
Default 02-03-2020, 12:24 PM
Pin 3 on the OBD2 molex end.
You'll see a pin that's unused:
https://lh3.googleusercontent.com/pr...IU7NHQnKIBFkmt
Whateva's Avatar
Car: E90
Default 02-03-2020, 01:44 PM
You have to excuse my understanding of the vernacular Molex. If the Molex is the pin socket interconnection and its relation to the ODB cable; couldn't I just dissect my USB to OBD and find the unused pin?
If that is the case, then how would I know where the unused pin on the USB side was supposed pin to on the OBD side?
Thanks for all the help
are you referring to this cable? https://burgertuning.com/products/jb4-obdii-replacement
if this is the unused connection then I suppose I could tap directly into that line from the vehicle.
Default 02-03-2020, 02:07 PM
Yes that cable.
The lower pin that is unused that I marked with the red arrow is RPM.
The green and brown wires go to were I marked.
Whateva's Avatar
Car: E90
Default 02-03-2020, 02:25 PM
Excellent, Thank you, Payam!
