Tgrossman Tgrossman is offline
Car: BMW 135i FFtec single turbo
Default N54 30FF code HELP!! Please - 10-10-2019, 01:26 PM
Please help, i cant get rid of my 30FF code.
Ive replaced the vacuum lines, replaced the boost solenoids, while replacing the rear turbo inlet gasket I created a bracket to keep it seated to the turbo, replaced exhaust gaskets. Im drawing max 5lbs of boost so im praying that my turbo is working. I really wanna stay away from BMW because I dont wanna spend $$$ but im out of options. Ive ran JB4 on and off and i cant get ride of this dang code, driving with no boost is NO FUN.....I hopefully can attach my JB4 logs and my current settings that I've no touched, I havent tested the wastegate or the turbo because i have no clue how, I didnt remove intercooler to check the seals but i dont know if that would pop a 30FF.....please help
DeepEddy DeepEddy is offline
Car: E92
Default 10-10-2019, 03:15 PM
??? 15 in 6cyl timing and tmap???
I am only a professional in my mind but that aint right
jacobniell jacobniell is offline
Default 10-10-2019, 10:34 PM
I Im also based on your boost level sure that TMAP should have been 0, and the Timing logging should have been any of the belov values (4, 5 or 7) dependent on your ECU
Default 10-12-2019, 03:54 PM
Yeah I dont know how my settings got jacked up but Ando from burger motorsports got me situated.
Bbelstad's Avatar
Bbelstad Bbelstad is offline
Car: 08 E60 535i
Default 10-12-2019, 07:12 PM
So is everything ok now then? What was the problem if so?
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
Default 10-12-2019, 07:23 PM
Bbelstad's Avatar
Car: 08 E60 535i
Default 10-12-2019, 09:15 PM
Best emojis I've ever seen.
Brandon
Hayden, Idaho.
[/SIGPIC]
