Andrew3424 Andrew3424 is offline
Car: E92 335
Default 335i N54 manual transmission noise - 10-09-2019, 05:02 PM
Hey guys so I just completed my full build changed everything from turbos, intercooler literally every bolt on possible. I also upgraded to m factory single mass flywheel and spec stage 3+ clutch. Changed my master clutch slave , guido, Clutch Pilot Bearing, throw out bearing, Driveshaft Center Carrier, and transmission mounts. Didn't find out that I shouldn't of touched my clutch pilot bearing until it was to late. Was a huge pain in the ass to get off heating it up and using all different removal tools, and dremeling it off we finally got it off. Put the car back together and now I here a lot of noise coming from my transmission attached is a video. If anyone has any idea and could help me out it would be much appreciated. Thanks
October 9, 2019 - YouTube
jacobniell jacobniell is offline
Default 10-11-2019, 04:09 AM
Originally Posted by Andrew3424
Hey guys so I just completed my full build changed everything from turbos, intercooler literally every bolt on possible. I also upgraded to m factory single mass flywheel and spec stage 3+ clutch. Changed my master clutch slave , guido, Clutch Pilot Bearing, Driveshaft Center Carrier, and transmission mounts. Didn't find out that I shouldn't of touched my clutch pilot bearing until it was to late. Was a huge pain in the ass to get off heating it up and using all different removal tools, and dremeling it off we finally got it off. Put the car back together and now I here a lot of noise coming from my transmission attached is a video. If anyone has any idea and could help me out it would be much appreciated. Thanks
Noice from the "transmission" is usually amplified from the single mass flywheel. Could this be the case as well here?
(I did not hear your attachment)
Car: E92 335
Default 10-11-2019, 05:04 PM
Yes I was definitely anticipating chatter but this is not chatter. Check our the video and you’ll hear the horror lol
Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Default 10-11-2019, 05:21 PM
You sure your bolt that hold the clutch to the fly wheel are tight?
07' 335xi, VTT Stage 2, Meth CM10, Stage 2 LPFP pri, walbro 525 LPFP 2nd, JB4 E85 BEF, VRSF exhaust, Phoenix Race IC, MMP AL inlets, VTT AL Outlet, PR Coils, Fuel-IT CPI 950cc, Manual swapped, SMF Spec Twin disk
Car: E92 335
Default 10-11-2019, 06:10 PM
Yes torqued everything down to spec. Bolts also have Loctite on them so its doubtful they came lose. Clutch is smooth and engages fine. Just the noise I’m hoping it’s a bad throw out bearing.
