suspenceful's Avatar
Car: 2008 BSM 135i
Default Weight Difference: BMW 135i vs. 335i (Actual Results) - 07-19-2019, 07:54 AM
After running a 10 second pass in my 135i, I was really curious what it weighed. So, I found a local weigh station and put it on the scale. I even brought my stock BMW 335i to find out the difference in weight between the two.
135i weighed 3,300lbs without a driver.
335i weighed 3,600lbs without a driver.
For more details, like the weight reduction I've already done on the 135i and how much gas each car had, check out my video below. I ripped the 135i at the beginning, so it's worth watching anyways.
codesx's Avatar
codesx codesx is offline
Default 07-19-2019, 10:45 AM
Fun!
An old '82 Honda Civic with me and everything I owned was 1980 lbs.
I no longer qualify for the light-driver-mod...
My 08 335i E93 papers show just over 4000 lbs.
With fuel and myself in there, along with my x3 322 wheels, it's going to be considerably higher.
Somehow though, I figure my smile would be just as wide rolling down the 1/4 mile track with my hard-top down.
You would be able to see my white pearls in your rear-view mirror
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 BSM 135i
Default 07-19-2019, 12:21 PM
Originally Posted by codesx
Fun!
LOL! True that. I had a convertible once, it was nice.
