seroga1986's Avatar
seroga1986 seroga1986 is offline
Default N54 JB4 to display engine oil pressure interest - 04-20-2016, 06:59 AM
Can we get a oil pressure readout on jb4? I have seen way to many failed/failing oil pumps on these cars that result in worn out motors. I can help with this if need be. Thanks.
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 04-20-2016, 07:07 AM
I'd be in for monitoring oil psi for sure.
2011 335is DCT, FBO
psychosinmylobby psychosinmylobby is offline
Car: 07 e92
Default 04-20-2016, 07:37 AM
+1 On this
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 04-20-2016, 08:37 AM
INPA and Tool32 can read oil pressure from the DME, so it's possible...oil pressure is returned by the value STAT_P_OEL_IST_WERT in hectopascals (hPa).
Code:
<JOB>
		<JOBNAME>STATUS_SYSTEMCHECK_ODR</JOBNAME>
		<JOBCOMMENT>0x332C STATUS_SYSTEMCHECK_ODR</JOBCOMMENT>
		<JOBCOMMENT>Auslesen Diagnosefunktion Oeldruckregelung</JOBCOMMENT>
		<JOBCOMMENT>Aktivierung: Klemme 15 = EIN</JOBCOMMENT>
		<JOBCOMMENT>Activation: LV_IGK = 1</JOBCOMMENT>
		<RESULT>
			<RESULTNAME>STAT_DIAGNOSE_1_TEXT</RESULTNAME>
			<RESULTTYPE>string</RESULTTYPE>
			<RESULTCOMMENT>Stati fuer Diagnosefunktion Oeldruckregelung</RESULTCOMMENT>
			<RESULTCOMMENT>ST_TESTPOELSYS</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_DIAGNOSE_1_WERT</RESULTNAME>
			<RESULTTYPE>int</RESULTTYPE>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_DIAGNOSE_2_TEXT</RESULTNAME>
			<RESULTCOMMENT>Erweiterte Stati fuer Diagnosefunktion Oeldruckregelung</RESULTCOMMENT>
			<RESULTCOMMENT>ST_TESTPOELSYS2</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_DIAGNOSE_2_WERT</RESULTNAME>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_TOEL_WERT</RESULTNAME>
			<RESULTTYPE>real</RESULTTYPE>
			<RESULTCOMMENT>Ausgabewert Motoroeltemperatur fuer LoCAN (A2L-Name: Toel)</RESULTCOMMENT>
			<RESULTCOMMENT>TOEL   Einheit: C   Min: -3276.8 Max: 3276.7</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_TOEL_EINH</RESULTNAME>
			<RESULTCOMMENT>degreeC</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_P_OEL_SOLL_WERT</RESULTNAME>
			<RESULTTYPE>unsigned long</RESULTTYPE>
			<RESULTCOMMENT>Sollwert Oeldruck</RESULTCOMMENT>
			<RESULTCOMMENT>P_OEL_SOLL   Einheit: hPa   Min: 0 Max: 65535</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_P_OEL_SOLL_EINH</RESULTNAME>
			<RESULTCOMMENT>hPa</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_P_OEL_IST_WERT</RESULTNAME>
			<RESULTCOMMENT>Istwert Oeldruck</RESULTCOMMENT>
			<RESULTCOMMENT>P_OEL_IST   Einheit: hPa   Min: 0 Max: 65535</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_P_OEL_IST_EINH</RESULTNAME>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_NKW_SOLL_WERT</RESULTNAME>
			<RESULTTYPE>long</RESULTTYPE>
			<RESULTCOMMENT>Sollwertanforderung Drehzahl aus Funktion Oeldruckregelung</RESULTCOMMENT>
			<RESULTCOMMENT>NKW_SOLL   Einheit: Upm   Min: -32768 Max: 32767</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_NKW_SOLL_EINH</RESULTNAME>
			<RESULTCOMMENT>Upm</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_NKW_WERT</RESULTNAME>
			<RESULTCOMMENT>Istwert Drehzahl</RESULTCOMMENT>
			<RESULTCOMMENT>N   Einheit: rpm   Min: 0 Max: 8160</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>STAT_NKW_EINH</RESULTNAME>
			<RESULTCOMMENT>rpm</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>JOB_STATUS</RESULTNAME>
			<RESULTCOMMENT>&quot;OKAY&quot;, wenn fehlerfrei</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>_TEL_AUFTRAG</RESULTNAME>
			<RESULTTYPE>binary</RESULTTYPE>
			<RESULTCOMMENT>Hex-Auftrag an SG</RESULTCOMMENT>
		</RESULT>
		<RESULT>
			<RESULTNAME>_TEL_ANTWORT</RESULTNAME>
			<RESULTCOMMENT>Hex-Antwort von SG</RESULTCOMMENT>
		</RESULT>
	</JOB>
	<JOB>
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
suspenceful's Avatar
Car: 2008 BSM 135i
Default 04-20-2016, 08:44 AM
Would love to see this as well.
omarmarji's Avatar
Car: n54 335
Default 04-20-2016, 08:52 AM
+1 ...... trans oil temp got enough interest to get it going.. im sure terry will help out with oil pressure for the engine
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
ryanm8 ryanm8 is offline
Car: 07 335I
Default 04-20-2016, 09:15 AM
+1. Very important parameter to have.
seroga1986's Avatar
Default 04-20-2016, 10:31 AM
I hope this gets Terrys attention just like the ATF temp did.
2008 135i Sport 6at
Car: 07 e92
Default 04-20-2016, 10:46 AM
We need appx of 4~5 pages of votes. Lets go guys!
Torsion Torsion is offline
Car: 335
Default 04-20-2016, 10:58 AM
Also interested
bigdnno98's Avatar
Car: e92 335i
Default 04-20-2016, 11:36 AM
Still interested hahahaha.
2011 335is DCT, FBO
omarmarji's Avatar
Car: n54 335
Default 04-20-2016, 12:11 PM
Make a poll thread
751WHP 688WTQ
JP Works Kit Record
BostonBeemah's Avatar
Car: AW 135i
Default 04-20-2016, 12:19 PM
In!
RIP 2008 AW/BL 135i
bhanner95 bhanner95 is offline
Car: 2009 335i
Default 04-20-2016, 03:14 PM
I lost an engine to this so... In!
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 04-20-2016, 03:34 PM
yep
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Nniftyfour's Avatar
Default 04-20-2016, 04:11 PM
Great idea. I want it.
Slawekn1 Slawekn1 is offline
Car: 2008 BMW 535xi
Default 04-20-2016, 05:00 PM
I would like to see that option as well.
neroneuman's Avatar
neroneuman neroneuman is offline
Car: n54 335i
Default 04-20-2016, 05:24 PM
I'm interested too :D
omarmarji's Avatar
Car: n54 335
Default 04-20-2016, 10:50 PM
BUMP!!!! terry & dmac!!!
751WHP 688WTQ
JP Works Kit Record
ThreeDirtyFive ThreeDirtyFive is offline
Car: BMW E92 335i
Default 04-21-2016, 12:29 AM
In for it
johmei's Avatar
johmei johmei is offline
Default 04-21-2016, 02:05 AM
If we have a accurate sensor I am in for it!
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 04-21-2016, 02:29 AM
I'm in as well...I would use that instead of water temp when gauge hijacking.
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 04-21-2016, 04:12 AM
+1
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
marconi118 marconi118 is offline
Default 04-21-2016, 08:16 AM
for me too please
seroga1986's Avatar
Default 04-22-2016, 11:34 AM
Terry and Donnie and whoever can help: will this ever have any traction? I think this is a very important parameter to keep an eye on. I wish i knew how to help on getting this done.
2008 135i Sport 6at
