suspenceful's Avatar
Car: 2008 BSM 135i
Default 3.5 bar vs. 4 bar TMAP sensor? - 02-22-2016, 10:34 AM
I'll be installing inlets this weekend and want to demand the most boost from these stockers as possible.
Is there any difference if I were to order the 4 BAR sensor instead of the 3.5? I see the 4 BAR available on BMS website for $99 as a complete kit.
Default 02-22-2016, 10:35 AM
They both do the same thing and the JB4 supports either one. The 4bar is a little better value I think. The 4bar has a wider usable voltage range so the one potential drawback, lower resolution, isn't an issue at all.
Car: 2008 BSM 135i
Default 02-22-2016, 10:39 AM
If there is no downside to the bigger one, you should see a purchase from me sometime this week.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-22-2016, 10:42 AM
TMAP is really not going to benefit you any with stock turbos from my understanding. If you were getting it to eventually upgrade and you were going to push more boost, then I would suggest the 4 BAR due to being cheaper. Most people won't need the 4 bar over the 3.5 from a boost prospective. But it comes back to price point and that's why most people will probably start buying the 4 over the 3.5.
Car: 2008 BSM 135i
Default 02-22-2016, 10:44 AM
I'm not looking for benefits. From my understanding, without an upgraded TMAP sensor, you're unable to read or log boost levels above 20psi. Correct me if I'm wrong.
Default 02-22-2016, 10:56 AM
Anyone running 19-20psi or higher should upgrade the TMAP sensor. You want to be able to read at least 2-3psi over your intended target to allow the PID system to properly respond to boost-over shoot.
AZN54 AZN54 is offline
Car: N54 135i
Default 02-22-2016, 03:07 PM
Terry,
I'm running MHD e85 flash on map 7 and overboosting to a little over 21psi and have been getting kicked to map 4. We increased BSR to 80, which has helped a little. I'm assuming getting the 3.5 bar TMAP in there can help, too?
2009 135i
DOC Race 6266 Single, VS DW400 LPFP, VRSF Race FMIC, Motiv BoostBox, Tuned by Wedge
Offering Arizona Walnut Blasting Service:
http://www.n54tech.com/forums/showthread.php?t=36741
Default 02-22-2016, 03:51 PM
If you are running anywhere near 20psi upgrade the sensor for sure.
Car: N54 135i
Default 02-22-2016, 05:13 PM
Thanks Terry, will do that right away
2009 135i
Default 02-22-2016, 07:41 PM
You need the BMS harness too as the plug wont fit the N20 otherwise. Around $34 on the BMS site.
Car: N54 135i
Default 02-22-2016, 08:28 PM
Ya, I saw that. Appreciate the heads up. I'm just going to go with the 4bar since it's less expensive and comes all together.
2009 135i
bnk bnk is offline
Default 03-01-2016, 08:08 AM
3.5bar has proven to work well, so that's the safe bet. What's the experience with 4bar so far?
Car: N54 135i
Default 03-01-2016, 09:25 AM
Curious of this, as well.
Terry, have you seen any more consistency with one or the other?
2009 135i
Default 03-01-2016, 10:29 AM
All the JB4 4bar logs I've seen have been solid. Out of around 40 units sold we had one customer with a DOA sensor. Other than that not heard of any JB4 issues.
For flash only guys Tony@Vargas recently posted he was having some problem with it, but his setup is pretty complicated and flash only, so I don't know what his issue was exactly. Could have blown out the sensor or could be some issue specific to his setup. Another flash only customer also reported some random startup code that must be related to his flash tune sensor scaling. I think the flash tuners will need to work with the sensor more to ensure they have the tables & calibrations setup properly.
Car: N54 135i
Default 03-01-2016, 10:38 AM
For flash only guys Tony@Vargas recently posted he was having some problem with it, but his setup is pretty complicated and flash only, so I don't know what his issue was exactly. Another flash only customer also reported some random code that must be related to his flash tune. I think the flash tuners will need to work with the sensor more to ensure they have the tables & calibrations setup properly.
Thanks, Terry.
2009 135i
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 03-01-2016, 10:40 AM
Just a throw in of opinion, for twin turbos, i'd think of 3.5 as a better match since you don't need the range that 4 provides. Technically both work but one is closer to your needs as opposed to 40psi which might be better suited for a single.
Car: N54 135i
Default 03-01-2016, 10:44 AM
But I'm running 40psi on my stockers... Jk
I went with the 3.5. Thanks for the input
2009 135i
Default 03-01-2016, 11:04 AM
It turns out the resolution between them is very similar as the 4bar goes from .4v to 4.65v, while the 3.5bar goes from .5v to 4.5v. But the 3.5bar is tried and true. Can't go wrong with it.
Car: 2008 BSM 135i
Default 03-01-2016, 12:27 PM
A local N54 friend said Ken didn't want to MHD flash with a 4BAR sensor. Must not be perfected on the flash side of things yet.
Torgus Torgus is offline
Default 03-01-2016, 12:50 PM
PTF said they have no problem flashing with the 4bar w/ MHD fwiw.
Got Boost?
Amgturbo2012's Avatar
Amgturbo2012 Amgturbo2012 is offline
Car: 2010 135i
Default 03-01-2016, 01:40 PM
I'm having issues with mine as well, but as stated its because I'm flash only with Haltech. Sensor works perfectly other than the "intake sensor re-running" code I get at start up. Once I clear it out, the car runs fine and the code doesn't come back up. Ken is supposed to be working on a fix.
10'135i Alpine White M-Sport M/T 827HP 707TQ@32lbs
Motiv 900 - Tial BOV/Wastegate - Big Tom Intercooler - FuelIt! Stage 3+ - MHD Custom Flash - Haltech PS1000 - Motiv Port Injection/Twin Disc - BMS OCC - Kosei - 275/40/17 NT05R's
10'135i Black A/T - 580WHP 540WTQ (11.51@134MPH 2.1 60')
Car: N54 135i
Default 03-01-2016, 01:42 PM
4bar, correct?
2009 135i
Car: 2010 135i
Yes sir.
Car: N54 135i
Default 03-01-2016, 01:44 PM
Yes sir.
2009 135i
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 03-05-2016, 03:46 AM
Issue addresed and resolved http://www.e90post.com/forums/showthread.php?t=1233606
looking for some testers if you already have the 4bar
2011 E92 335is w/DCT
2007 E92 335i 6AT
