patk12295 patk12295 is offline
Car: 2009 E90 335i
Default Log review PLEASE - 11-27-2020, 11:47 AM
Hi guys, I know BMS is revolved around JB4 which I will be pairing with MHD soon but in the meantime Can someone please look over these logs and tell me how they look? I have a good understanding of these cars and how to work on them but I struggle with logs a bit lol car is 2009 e90 335i, stock turbos, stock inlets/outlets & chargepipe (one is on order) mhd ots stage 2+ e50 mix, XHP stage 3 trans tune with custom tweaks (torque reduction at +20, shift speed at +20 & custom M mode autoshift points at 6500 rpm) 5" intercooler, 3" ******* ********* & secondary *** delete, BMP stage 2 bucketless lpfp & new OEM hpfp, also 1 step colder NGK plugs gapped to 0.022 per spec.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 11-27-2020, 04:36 PM
Need to post in the support section.
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5” RACE FMIC
VRSF DP’s - VRSF INLETS - VRSF OUTLETS
MISHIMOTO 25 ROW OIL COOLER
MISHIMOTO 15 ROW TRANSMISSION COOLER
19” 666m WHEELS - HANKOOK VENTUS V12 EVO 2’s
Default 11-27-2020, 04:52 PM
We're only able to look at JB4 logs so just post those once you get it up and running.
