(#526)
AzM750 AzM750 is offline
Car: 2011 750i M sport
Default 10-10-2020, 01:48 PM
Originally Posted by SINasTER
A 3.5bar TMAP would be useless with stock turbos, you would need to upgrade them. If you think you have problems with your TMAPs, just replace them eith oem
How exactly would it be useless? Our stock ones max out at 20 and that means I canít go up in boost. Iím already hitting 17-20psi depending on the air temp outside so once I put my ********* on and 5 gallons of e85 yes it will definitely help me get beyond the point of throwing codes or whatever difficulties you guys go through. Iím also doing a tune on top of the jb4 so I will be doing a setup that holds a constant 24psi
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Default 10-10-2020, 02:35 PM
I donít know what cheap chinese TMAPs youíre running but I presently go up to 25psi on a heatsync stage 2 tune without issues.
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Michelin Pilot Sport 4S 235/40R19
Front: Michelin Pilot Sport 4S 275/35R19
Default 12-28-2020, 09:24 PM
Just an FYI for people like me who were under the impression we needed 3.5 bar tmaps to go beyond 20psi. i have a vivid racing stage 2 flash with the jb4 along with VRSF ************ *********s ARM cold air intake N63intakes oil cooler valve ngk 2 step colder plugs this is on a n63 NON TU...on map 0 I’m running 17psi map 1 22-23 and map 2 23-24psi...so no need to add these unless you are turbo swapped
Default 12-28-2020, 09:49 PM
You absolutely need 3.5bar sensors to safely run over 20psi. Otherwise, you're just asking to smoke your motor due to out of control boost.
Default 12-28-2020, 09:52 PM
Should I be seeing boost spikes and huge variations? It seems to hold steady and the logs look good lol...guess I’ll be ordering the 3.5 bar tonight based off your response lol
Default 12-29-2020, 11:38 AM
Post the log if you want tuning advice on it.
Wht550Jersey Wht550Jersey is offline
Car: 11 550i
Default 01-16-2021, 02:51 PM
Map 2 log . How does it look . Thanks
Default 01-17-2021, 02:06 PM
Do you have an ECU flash also?
Car: 11 550i
Talking 01-17-2021, 02:22 PM
Not yet . Had some kinks I been working out , hopefully all good now
11 550i Rwd
Badblk intakes , 3.5 tmaps , bms JB4 & pedal tuner, vrsf *********, custom X pipe and exhaust .
Car: 11 550i
Default 01-18-2021, 09:31 AM
Posted a log for you . Thanks
11 550i Rwd
