m123 m123 is offline
Car: 440i F32
Default 09-27-2017, 12:39 AM
Attached my log.
Forget the first part, just the second part in gear one is interesting.
F32 440i JB4
F11 550i N63tu JB4
Car: 440i F32
Default 09-27-2017, 12:52 AM
We have to find out now if it is related to the gearbox, as this fault seems to happen just in gear 1 and 2.
Or is it related to a "sensor" which meassures acceleration?
The fault is really scary and has to be solved!
Just imagine it happens whilst overtaking and you are left with zero power on the left track and another car comes in you direction!
F32 440i JB4
F11 550i N63tu JB4
JAJBMW JAJBMW is offline
Car: M140i
Default 09-27-2017, 03:21 PM
I agree it needs to be sorted, i don't understand why the JB4 is breaking my car effectively, I was told that the Map 2 "limp mode" problem was fixed. I tried my car in map 2 tonight and it wouldn't throw the code, what's different about Map 2 to Map 1 besides the PSI increase ? Why can't I run map 3 with the mods I have ? 200 Cell Sports ***, air filter, 99 octane fuel ?
JB4OFF JB4OFF is offline
Car: 340i
Default 10-25-2017, 09:22 PM
Got the same code randomly tonight.
Car: 440i F32
Default 10-26-2017, 12:14 AM
Seems to be a problem for everyone. Would be nice to get it sorted out soon
F32 440i JB4
F11 550i N63tu JB4
Car: 340i
Default 10-26-2017, 06:38 AM
Terry said it a valvetronic fault but here it says other... BMS and the support is very confusing at times.
Default 10-26-2017, 03:08 PM
There isn't a description for it on our code listing. Other 1F0 codes we've seen on other platforms have been valvetronic related and I forgot about this B58 thread. In your case if it's the same as the code in the first post and its coming up primarily in 1st gear during WOT runs, then probably the same issue the 2-3 guys in this thread have reported.
I don't know the cause of the code, have not been able to recreate it on any cars, but seems the easiest fix would be to limit boost levels in 1st and 2nd gear such that the fault isn't triggered.
Frank Jia Frank Jia is offline
Car: BMW 340i MPPSK
Default 11-09-2017, 10:09 PM
It seems like there are some other guys who are suffering same issue on facebook.
BMW340i MPPSK,FBO,JB4,WMI,QuaifeLSD,Carbon Driveshaft.
Default 11-09-2017, 11:50 PM
Drivetrain malfunction is pretty generic, could be quite a few things. Each case would have to be addressed separately based on the codes and descriptions.
H17YD_L's Avatar
H17YD_L H17YD_L is offline
Car: M135i
Default 11-10-2017, 02:35 PM
I've had this a few times running map 3, it seems it only happens in 1at or 2nd as reported. I think it's more to do with traction control it only happens in damp/ greasy conditions and when the traction control really kicks in hard to stop wheelspin, it feels as if it's kicks in then gives u some power back then when it break traction again it really steps in and throws the drivetrain error. Best way i can explain it, been using map 2 for a few weeks and haven't had it.
Thinking about limiting boost in 1st 2nd and maybe 3rd, but what I did want to know if it's possible to limit with an additive boost cap rather than an absolute? That way i can have map 2 in the 1st 3 gears and map 3 or 5 in the rest
M140i Auto. JB4.
Mrpink Mrpink is offline
Car: M140i
Default 11-10-2017, 02:57 PM
I have set boost limit to 10 in 1st and 12 in 2nd and never had an issue since.
H17YD_L's Avatar
Car: M135i
Default 11-10-2017, 04:05 PM
Cheers mate, I’ll give that a go but still want to know if it’s possible to cap with the additive? Prefer the way it works compared to the absolute
M140i Auto. JB4.
Car: M140i
Default 11-11-2017, 12:49 AM
I run map 7 with these boost limiters in place and it works.
It’s a strange feeling going from 1st, 2,nd then to third. It’s like vtec kicks in yo lol
Car: 440i F32
Default 11-11-2017, 01:18 AM
I am running map 7 too and made a boost cap for gear and two. My values are 11.0psi for the cap. What are yours?
F32 440i JB4
F11 550i N63tu JB4
lefthander lefthander is offline
Car: BMW F30
Default 11-14-2017, 05:46 AM
i had the same issue but only during cruise control.
i hit the error during 80-90km/h ONLY when using cruise control.
Low gear is fine.
Car: M140i
Default 01-11-2018, 12:12 PM
Did we ever get to the bottom of this ? I keep getting the same issue in my M140i running Map 3 ?
AzuriteM5 AzuriteM5 is offline
Car: M5 F10
Default 02-14-2018, 12:03 PM
Have the same error.
340i rwd stock jb4 map3. Only in 1. gear when accelerate.
Repo335i Repo335i is offline
Default Error - 08-26-2018, 06:37 AM
Hi, today I got the error even when I accelerated in gear 1 full. Car says drive error and I could only go very slowly .. car off and on again and then everything was fine again ... was not the problem fixed?
Dominic 88's Avatar
Dominic 88 Dominic 88 is offline
Car: Bmw F30
Default 08-26-2018, 12:41 PM
Hello, l got the same code today while WOT in 1st gear on map 7.
Default 08-26-2018, 01:20 PM
when the error is fixed .... yes many are the error code .... can you bring an update where in gear 1 and 2, the boost is reduced?
patofdzb patofdzb is offline
Car: 16 340i
Default 01-23-2019, 12:50 AM
Did anyone ever resolve this or find out what's going on? I'm having the same issue a lot!
j3vr6 j3vr6 is offline
Car: 2016 340i RWD
Default 03-15-2019, 09:50 PM
Chiming in. Have gotten it twice in the last month. Both were at hard acceleration from a stop. Not launching or racing, just accelerating quickly to make a turn or something. Both times in Sport Mode. JB4 - Map 3. vrsf catted **, agency power intake. Had to turn off car (in traffic) and start her up again.
Any resolution yet???
Default 11-20-2019, 05:10 PM
Latest BEF has it disabled, limiting boost in 1st gear also can be used on the factory flash.
M4HCP M4HCP is offline
Car: M140i
Default 1F053C fault code - 03-01-2020, 03:25 AM
Terry does the latest V15 firmware Resolve the 1F053C limp mode fault on Map 7?
absaifan absaifan is offline
Car: Supra 2020
Exclamation 08-22-2020, 04:41 PM
I got this fault code twice on my 2020 supra, running jb4 and BEF through MHD.
Both times happened to me within a week while driving in sport mode, both times I was on a turn (not going straight) and the road would be a bit bumpy and my throttle above 70% trying to power out of the turn, the fault would pop up and I'll lose complete power down to 5-10% throttle max, just enough to get you to the curb side to park.
Restart car and all is well.
I never got this fault before the BEF, not sure but I feel bef is causing it, I have a CAI, stock *** dp, full exhaust, stock turbo, running map6 on 93 octane.
Attached is a partial jb4 log (auto log) from today.
Here is the MHD dump reflecting the fault:
- DME active codes - 1F053C - Drive, safety function: Maximum acceleration exceeded. - DME shadow (inactive) codes - 30E1C unknown 10D000 unknown 1FBD08 - Driving readiness: MSA deactivation request from BDC. 21B055 unknown 21B056 unknown 24000B unknown - Transmission active codes - None - Misc. information - MHD build: version 2.42 Voltage 12.78V Last flashed file : G20_SUPRA_RACE_2.bin VIN: WZ1DB4A03LW025401 Factory software: HWEL 3DDE v003_019_006 HWAP 3DD1 v255_255_255 BTLD 48DC v001_011_001 SWFF 5D55 v060_110_005 TPRG 6352 v060_110_005 Current software: HWEL 3DDE v003_019_006 HWAP 3DD1 v255_255_255 BTLD 48DC v001_011_001 SWFF 5D55 v060_110_005 TPRG 6352 v060_110_005 CAFD 2742 v000_171_006 Current PRG (hex): 5D553C6E05 ECU status: - - Readiness - Misfire: Complete. Fuel System: Complete. Components: Complete. Catalyst: Complete. Heated Catalyst: Not avail. Evaporative System: Not avail. Secondary Air System: Not avail. A/C Refrigerant: Not avail. Oxygen Sensor: Complete. Oxygen Sensor Heater: Complete. EGR System: Complete.
Terry, over to you!
