(#3451)
khancerto's Avatar
khancerto khancerto is offline
Car: 2020 Hyundai Elantra Sport
Default 08-02-2020, 12:49 PM
So this was asked a while back but there wasn't any serious answer to the question, but is it possible to get crackles and pops with the JB4?
atr1 atr1 is offline
Car: Stinger GT
Default 08-02-2020, 12:55 PM
No piggyback can do that. Need a back end flash or ECU tune.
Struble Struble is offline
Car: 2018 stinger GT1
Default Jb4 going back to map 0 - 08-03-2020, 09:00 AM
2018 stinger3.3 BMS intakes BMS blowoff valve 2 step colder plus and Jb4 with fuel wires
On map 1 or 2 car goes to map zero and have to restart car after
Looks like Iím running out of fuel???
Default 08-03-2020, 03:11 PM
Looks like one of the fuel wires isn't making correct contact.
N20_to_VR30 N20_to_VR30 is offline
Car: RS400
Default 08-03-2020, 05:00 PM
JB4 keeps dropping to Map0 for no apparent reason. Posted some logs a couple lines up to show. Any ideas on why?
MurlinatoR's Avatar
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 08-03-2020, 08:31 PM
Looks like Terry reviewed the logs. Did you check your last safety?
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
Car: RS400
Default 08-03-2020, 09:03 PM
I think the issue is with my WMI install. The connections and tubing is on tight but this p2563 goes back to when I put it in. Any thoughts on why this would cause a code and reverting to Map0?
Car: RS400
Default 08-03-2020, 09:28 PM
Actually- from what I can find online, it may be due to EWGs. Is it possible those went bad?
Default 08-05-2020, 12:04 PM
Could be a wiring issue. If codes clear but then return next startup may be an older JB4 that requires a 2580 update.
Car: RS400
Default 08-05-2020, 03:42 PM
Thanks Terry- as usual, your customer service team comes through with quick responses. Iíve been emailing with them to get the update. I appreciate all your help.
jwalkingjon jwalkingjon is offline
Car: Genesis g70 3.3T
Default 08-05-2020, 08:20 PM
Hi new to this forum I asked on the genesis forums though also but no luck, I installed the JB4 perfectly and got it brand new from Khartuning who I believe buys from Burger. Whenever I open the app and try to connect to the JB4 in the app it gets to Waiting for handshake then fails after 5 attempts, I tried it on 3 phones with no luck. I can see the JB4 in their Bluetooth and I see it in a bluetooth scanning app with full signal but I can't get it past the handshake part in the app so that it finally connects. Any help would be appreciated
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 08-06-2020, 07:40 AM
Just shooting from the hip...
1. If the car has bluetooth, and you're phones are automatically connecting to that, kill that connection
2. Shut the WiFi off on your phone
3. Pull the latest firware through the app, 19 seems to be working well. Try flashing your JB4, I'm pretty sure it uses a different process outside of the normal synch.
Default 08-06-2020, 07:52 AM
Thanks for the reply
1. It was only connected to my LG phone (i've tested it on 3 devices) I tried disconnecting it from the LG too and giving it a bit but no luck with that.
2. Wifi was off on all 3 devices (one hasn't had wifi on in a few days since my dad always has it off). Still no luck
3. How do I flash the JB4 through the App? Also will this work if I can't connect to it.
Some notes: I know the JB4 is working on at least Map 1 (I think is the default) because the thing pulls completely different and I can feel the power since I've been daily driving it 30+ miles a day for 7 months. Also the Light on the Bluetooth adapter isn't on I see what looks like a little light but that's not any color i'm just not sure if that lights up when it's connected or if it's on at all times. I tried the pin method that they have on the site but had to rush back inside since it started drizzling so I will try again later as well. Just want to get a few things that I can do to try on the device.
Also note I can see the JB4 in the bluetooth settings for the phone / a bluetooth scanning app I downloaded I see it at full signal when I lift it off the car and right next to my phone.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 08-06-2020, 08:28 AM
With no connection in the app you can still go to Setting, Advance, Firmware. There at the bottom hit Browes latest firmware files, you just need an internet connection. There you will see a list of 90+ makes and model the JB4 supports. Unfortunately I can't find anything on the Hundia G.... (which I assume you have because your first post said you were on a Genesis forum) Edit, #21 is for both KIA and Hundai, sorry about that....
Default 08-06-2020, 10:01 AM
Downloaded the newest "Stable" version of #21 and went outside. Once i select the .hex file then select flash / Update it says "Connection to JB4 required" so it won't let me flash it before connecting to it which is my main issue , I tried the Pin method that support mentioned to me but no luck. I'm just not sure if the light means something because if the light on the dongle is suppose to be on then mine definitely isn't working properly because mine is off.
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 08-06-2020, 10:27 AM
You might have to reach out to Burger directly. I know they monitor this forum so maybe they will chime in. It does sound like that blue tooth adapter might have issues. The only other thing I would recommend is to open the box back up and check the 9 pin connectors seating. Pull it apart and make sure the pins aren't bent or missing. I *think there are 3 total on the male side.
Default 08-06-2020, 11:37 AM
Email in to JB4 mobile tech support but sounds like a faulty JB4 mobile adapter. If you tried the basic steps they can swap it out for you.
Default 08-06-2020, 11:55 AM
Yep tried everything suggested, Seems to be that or the main board from what they said. Hoping it's the kit! They said they'll send a replacement so going to try and go with that. Thanks for the assistance!
MurlinatoR's Avatar
Kia Efficinato
Default 08-06-2020, 09:52 PM
Nothing lights up on the bluetooth adapter.
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
ClutchKargo ClutchKargo is offline
Car: Stinger GT2 AWD
Default 08-09-2020, 05:55 AM
I contacted the folks at jb4connectkit about my issue I'm having that I'm only getting Map and Boost gauges working on my Android phone screen using the app with my new JB4 and connect kit for my Kia Stinger 3.3TT. I've triple checked all connections then left the message with them and this was Chris' response:
"The Map and Boost only showing is related to a CANbus issue.
BMS should be able to assist, I'll forward this message to them for assistance."
I thought I'd also leave a message here because this is driving me crazy and I just don't understand why it is not working. Blue tooth is connected because I can change maps and I'm loving the new performance even though I'm keeping it on Map 1 because I haven't changed the stock plugs yet. I actually tried Map 2 and WOW! I didn't run Map 2 very long because I didn't want misfires on stock plugs but I didn't have any issues when I did.
So Please help with this CANBus issue I have no idea what this refers too but hopefully it's something I can do to fix it on my end.
sym sym is offline
Car: Stinger
Default 08-10-2020, 06:13 PM
I've had this happen a few times. If you aren't seeing it in the app, it's likely that the JB4 isn't getting that info either.
First order of business, did you install the OBD cable? It might be a dumb question, but I didn't realize it was important until I did some more research.
When it happens for me I just reseat the connector on the OBD port side and the JB4 side and it has always come back. Make sure the pins aren't pushed out of either side of the connectors. If it still isn't working and you have a multimeter, look for a very low resistance between the wires on the big OBD connector and the small 4 pin connector on the JB4 side.
Default 08-11-2020, 07:34 AM
A common problem is attaching the OBDII-JB4 end incorrectly. It should go like this.
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 08-12-2020, 01:35 PM
What is the latest firmware
Car: RS400
Default 08-12-2020, 07:46 PM
Wanted to make sure all is good after putting in a new 2580. Can you please take a look?
Default 08-12-2020, 07:54 PM
Looks good to me!
