rknick81 rknick81 is offline
Car: 2012 BMW 535 xdrive
Default N63 tips and trick - 03-11-2020, 07:42 AM
Here goes nothing...
I have purchased some bolt ons for my 2013 msport 550xdrive.
Arm ******* *********
Arm intake
JB4
2 stepcolder ngk iridium plugs (from burger) and new ignition coils
Long story short Im just looking for any tips and tricks for install and potential reliable tunes for the JB4 to get the most out of everything I can reliably. I know thats somewhat of an oxymoron with the N63 but its what ive got and what I wanted so here goes nothing. Obviously there isnt much for info on these because no one wants to work on them but Im a glutton for punishment. I have the install manuals for all parts listed above, just looking for any advice to make it go smoother. Capable of almost any bolt on. Novice tuner at best. Previously had JB4 on N55 and worked great. Not looking to run meth or e85 blend. Thanks in advance...
Wht550Jersey Wht550Jersey is offline
Car: 11 550i
Default 03-11-2020, 10:21 AM
3.5 map sensors
Default 03-11-2020, 10:57 AM
Thanks for the heads up. Having a tough time finding a 3.5 that fits the n63. There are aftermarket "vdo" options but it doesnt specifically say they are 3.5.... Also I have 4 of them on the n63. Are you refering to intercoolers, intake or all 4? Thanks again
Car: 11 550i
Default 03-11-2020, 11:11 AM
Get them from burger . That’s what I did. The t maps are on the ic. There’s 2
Default 03-11-2020, 11:38 AM
Thanks again. Mine was manufactured 10/2012. Evidiently they are the same sensor for the intake manifold and IC. Didnt see them on Burger website but will reach out.
BMW Boost Pressure Sensor N54 N55 N63 13627599042 (13 62 7 599 042)
Car: 11 550i
Default 03-11-2020, 11:51 AM
Ya you don’t want to put them there .tou have to set the jb4 also for the new maps
Default 03-11-2020, 12:06 PM
10/4. Ill pick up a couple. Assuming you mean I need to set up JB4 via the sticky thread and update hex files or are you referring to some other "new maps" settings?
Car: 11 550i
Default 03-11-2020, 12:08 PM
Ya update and you have to change tmap on the jb4 to 1
Default 03-11-2020, 12:17 PM
really appreciate it!
Default 03-11-2020, 12:45 PM
We have the 3.5bar and required adapters for typeA harnesses on our site.
Default 03-11-2020, 01:02 PM
And type "b" harness does not need the adaptor? And just to clarify that the website says n55/n54 but these will fit the n63 no?
Default 03-12-2020, 07:31 PM
Type B harness needs sensors only, the sensors are in a type B format.
Default 03-17-2020, 11:48 AM
If anyone viewing this has any questions regarding removal of the factory dp's feel free to ask. Once I get the install finished (was sent the wrong clamps) I will try to post a review of the removal and install. So far the instructions were pretty vague and on my 550xdrive (10/2012 production) it was quite a bit different than the removal/install instructions shown. First tip and trick would be 2 sets of hands to get the stock dp's out and a lift would be much easier than doing it on the floor like I am!! (installing arm ctlss dp's)
Car: 2010 535
Default 04-06-2020, 09:49 PM
Are you going to dyno it?
BMWKing123's Avatar
BMWKing123 BMWKing123 is offline
Car: C7 Z, 550i, Hayabusa
Default 06-12-2020, 06:11 PM
Did you get it dynoed?
Default 07-01-2020, 01:50 PM
I have not got it to the dyno yet. Tey just opened a shop here in town with an all wheel drive dyno that I plan to check out. So far all the mods have been great and it runs like a beast. Only complaint is that it smells really rich after the ctless ********* but i knew that going in. Any other questions feel free to ask but so far so good!
Default 07-08-2020, 03:45 PM
Hey terry@bms Quick question about the "6 cylinder timing" for the N63 JB4. As mentioned in the sticky thread, My boost in bank 1 typically doesnt match my boost in bank 2. Bank 2 is usually a little lower than bank 1. What should I input for that value to get them to match boost? I saw 0, <50 or >50 for the options but I dont quite understand where I would be at maybe somwhere inbetween. Thank you in advance.
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Default 07-10-2020, 03:04 PM
I have the issue, I tested that function and it doesnít seem to work. Tested at 25 and 75 and I still have the same difference between bank 1 and 2.
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Michelin Pilot Sport 4S 235/40R19
Front: Michelin Pilot Sport 4S 275/35R19
2011_550i_TX 2011_550i_TX is offline
Car: BMW 550i RWD
Default 07-16-2020, 10:33 AM
Originally Posted by Wht550Jersey
3.5 map sensors
Why would he need 3.5 map sensors on stock turbos? 3.5 maps are only for pushing above about 21 pounds of boost. He's not gonna get anywhere near that with JB4 on N63 especially without a flash tune.
SINasTER's Avatar
Car: BMW 335xi E90
Default 07-16-2020, 02:34 PM
ahah... really... I'm pushing 23psi stable on stock turbos with a JB4 on map 6 with the 3.5 bar tmaps
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
Default 07-17-2020, 01:32 PM
I didnt end up needing the 3.5 map sensors. However I am exceeding 21psi of boost on stock turbos with the other bolt ons I haven mentioned in this thread all on map 2. (ctls dp's, intake,2 step plugs,jb4) Have you tired the update file for the n63 regarding boost differences? It seemed to help mine dramatically. still a tad off but only .1 or .2. Bout as accurate as you could hope I reckon.
SINasTER's Avatar
Car: BMW 335xi E90
Default 07-17-2020, 04:33 PM
I want to make sure the new map for N63 is working correctly first and is made for the 2011 550 and works perfect with it. I asked for the changelog regarding this new map since itís not on the first page. Nobody here seems to know the changes made to the new map and for once, my car is running really good, donít want to mess that up with a map that was pushed to help a few people with a particular problem and could potentially cause problems to others
As for your tmaps, youíre pushing your luck running 21psi on stock tmaps, youíll start to see dtmís sonner than later 🤷🏻*♂️
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
Car: BMW 550i RWD
Default 07-17-2020, 08:14 PM
Nice. What are your boost values per rpm in map 6? Coukd you mabey send me a screen shot. It might help me dial my n63 in.
