Car: e90 335xi
04-12-2020, 11:05 AM
Yes that is the current N63 tuning path.
Start with JB4 map1 or map2, when you want more move in to a flash map with JB4 map6, and then if you want even more you can add in the 3.5bar TMAP sensors which the JB4 supports.
I have a 2013 X5 50i. Can you help clarify a couple things. If I buy a JB4 stage 1, I can run map 1 or map 2. Map 2 gains are around 40HP and 40TQ?
Also, is there any recommendation for a flash tune to run with the jb4 to get a little more out of it? Are there OTS flash tunes I can use like I have from MHD for my n54?
I'm not looking for anything crazy or unreliable. I was hoping to get around 75HP and 75TQ out of this thing with a tune.
08 335xi - 6MT. JB4 ISO, map7, MHD E85 BEF, E50, DCI, VRSF p1p3s, VRSF FMIC.
04 Cobra - Intake, Borla/Bassani exhaust, FMIC, pulley, tune.
Car: 2012 BMW 550xi
04-21-2020, 03:21 PM
I installed a BMS stage 1 to JB4 upgrade with BCM 3 years ago and can't find the wiring diagram with pin connections. Can someone please post a link or email?
Car: 2013 BMW 550 xDrive
N63 Firmware -
04-22-2020, 07:40 AM
Can I use the JB4 N63TU with a N63 engine if I update it with the N63 firmware?
04-22-2020, 05:24 PM
Depends on the vintage. Newer N63TU systems are PWG v2 and would not be N63 compatible.
04-22-2020, 06:08 PM
Thanks for the reply.
If I buy the current JB4 for a 2013 550 (N63), can I buy the mobile wireless option or I have to use the BMS wired connection?
Car: 07 335i
04-24-2020, 08:52 PM
Just sold my 2012 650i and picked up a 2015 550i. Will I have to independently sell my fairly new JB4 and pick up another one or can it be swapped out for credit towards a new one?
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
Car: 2012 BMW 550XI
2012 BMW 550XI -
04-28-2020, 11:05 AM
Been trying to learn how to read the logs.. but would rather get some better insight.. somethings wrong and I can’t figure out what is wrong..
Cars in map 1 JB4 on 91... has n63 intakes, turbosmart bov, vrsf ******* *********, E85 fuel pump, x-HP transmission tune, n63 oil sport cooler valve
Car: 11 550i
05-20-2020, 02:22 AM
You ever figure out what’s going on Cole?
Car: 2012 bmw 550i
Drivetrain malfunction at wot -
05-23-2020, 06:19 AM
Ok guys, I’m new to this, and I want to figure some things out. I have a 2012 550i, and I’m getting a drivetrain malfunction. Looked at the code and it says air mass flow too high? So I’m guessing I have to change my tmap sensors correct? But I’m also looking at the boost I’m running on map 2 and it only hit 16 max. I have Arm car less *********, Megan axle back exhaust, and diy front mount intakes. I data logged it so that you guys can see and let me know where am I going wrong.
05-23-2020, 08:07 AM
Yes for MAF code change the MAF sensors.
Boost looks normal to me.
Car: 2012 bmw 550i
05-23-2020, 08:23 AM
Thank you for the quick response, I will try to get that done today, if not soon. How would I be able to push around 20 pounds of boost. That is what I’m aiming for
05-23-2020, 01:01 PM
N63 life so you have limited options. Look in to a flash tuner to get you clsoer and use the JB4 for fine tuning, logging, boost by gear, and safety.
Car: 2012 bmw 550i
05-31-2020, 06:55 PM
Sooo.... after I looked over the logs I sent to you, I noticed the boost spiking, so I’m thinking that’s when I get a drivetrain malfunction. I saw there’s somewhere in the app to change boost spike between shifting gears. Can you tell me exactly where and how to do this? I’m still running tmap 2.5 sensors, and any map other than 0 I get that drivetrain malfunction, when I’m boosting too high. But I feel like there’s a problem with spike, so while I’m running map 3 I don’t want to over spike and hit detonation. Please give me a solution. Let time though told me tmap sensors but they haven’t arrived
06-01-2020, 09:02 AM
There are no useful adjustments for that on the N63 JB4 as it does not have wastegate control. The N63 is simplified to the point now that a JB4 itself can't cause any tuning issues on map1 or map2. Because we don't want to deal with the headache of N63 support trying to run higher power levels. We'd need to charge $3000 per N63 JB4 to make it worth it.
If you have MAF faults the fix is to replace the MAF sensors.
Car: 2012 BMW 550XI
Drivetrain malfunction -
06-19-2020, 07:39 AM
Getting codes 122104, 122004, and 120408... only on cold starts.. once the car warms up and stays warm I can clear the codes and won’t come back till next cold start
They’re related to diverter valves, however I’ve tried replacing the diverter valve with turbo smarts plumb back diverter valve to no success, is pulls the same codes..
I’ve checked the voltage of both solenoids and they’re in line, also the passenger side diverter valve doesn’t have issues..
Just did a compression test as well everything’s 195+
I feel like I’ve tried everything to diagnose/fix the issue..
Any insight would be fantastic as I took it to bmw yesterday for a diagnosis and paid $160 for them to reiterated what I told them was wrong before their diagnosis.. all they said is replace the diverter valve and I’ve done that twice..
Mods:
3.5 MAP Sensors, N63 Intake, VRSF ******* *********, xHP transmission tune, turbosmart dual port diverter valves, JB4, n63 oil sport cooler, 3 inch straight pipe
Car: 11 550i
06-19-2020, 07:49 AM
Vanos Solenoids ?
Car: 2012 BMW 550XI
06-19-2020, 08:07 AM
I don’t believe they’ve been done yet and I’m at 80k miles so I should probably change them, however it has never thrown any codes for the Vanos system..
Car: 11 550i
06-19-2020, 08:11 AM
I heard cold starts and rough idle could be them with no code showing . I’ll be pulling mine soon and cleaning them with Maf cleaner
Car: 2012 BMW 550XI
06-19-2020, 08:23 AM
Doesn’t have a rough idle, only thing is when I’m in neutral or park and rev it, car does shake from 2300-2900ish rpms..
Also just replaced engine mounts 8k miles ago..
Looks like I’ll be pulling mine as well
Car: BMW 335xi E90
06-27-2020, 05:44 PM
Hello Terry, just saw that on the JB4 app we can update to N63_4_T1 and here you are still pushing N63_3_T2...
What are the differences and is it a bug in the app?
Also, 2 «*problems I have:
I just got an ARM intake and I am getting rough ignition on low rpm and sometimes I get a CEL for rich mixture. How can I play with the AFR to get it to stay happy all across the rpm range?
It seems that I have a 2-3psi difference between bank 1 and bank 2, is there a way to adjust this?
Thank you
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Michelin Pilot Sport 4S 235/40R19
Front: Michelin Pilot Sport 4S 275/35R19
Car: 11 550i
06-27-2020, 06:47 PM
Are you getting any other cels ?
Car: BMW 335xi E90
06-28-2020, 09:12 AM
Only P0175 / 118102 for the rich fuel mixture. The MAFs are installed correctly and in the correct orientation (checked twice) and are correctly plugged in. I really don’t see why I’m getting a rich AFR, plenty are running these intakes without issues (goddam N63 platform and it’s gremlins)
The worst part is the way the engine runs at low throttle or on cruise control, it seems like it’s always misfiring and hesitating but no misfire codes and no codes for injectors either.
Once in a while I get the code for my ca_t_less down_pip_es but thats normal
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
Car: 11 550i
06-28-2020, 10:13 AM
I was getting codes like that after my n63 intakes and jb4 install . Swapped the map sensors out with the harness and it cleared everything up
Car: BMW 335xi E90
06-28-2020, 10:18 AM
You mean swap them from bank 1 to bank 2 and so on or replace them?
They are brand new with barely 100km on them and everything was running 100% before the intake installation
JB4 stage 2
Custom 3" D.P.s
ESR RF2 19" wheels
Car: 11 550i
06-28-2020, 10:38 AM
3.5 bars and harness from serg at n63
