(#3251)
Steven TMAN Steven TMAN is offline
Car: Kia Stinger GT
Default 05-27-2020, 10:09 AM
What timestamp/run did you experience it? Boost and pedal input all line up here from what I can see.
56.25 Timestamp.
Car: Kia Stinger GT
Default 05-27-2020, 10:10 AM
Originally Posted by stock_stinger
Sounds like just suffering comfort throttle response/sensitivity
Is comfort mode sensitive to TQ increase or anything weird?
Default 05-27-2020, 10:29 AM
Originally Posted by Steven TMAN
56.25 Timestamp.
Just looks like the car took 1/2 second to downshift, which is normal for comfort mode as pedal input is heavily dampened.
bosaad bosaad is offline
Car: Kia Stinger
Default 05-27-2020, 03:52 PM
I have a question before buying JB4 for my stinger 2.0T
Are there benefits to using Fuel Wire for map1?
Can i use map2 with 91 octane? (We do not have 93 octane here in KSA)
Car: Kia Stinger GT
Default 05-27-2020, 04:03 PM
It had already downshifted at that point. It hit a brick wall and wouldn't accelerate past 90. No acceleration, no gear change. Felt like fuel cut like a speed limiter.
Default 05-27-2020, 04:33 PM
For 91 octane on the 2L I'd skip the fuel control wire, it's more useful for E85 mixtures.
Default 06-02-2020, 08:28 AM
For those that are in to this sort of thing we've stocked 25 of the vanity plates, if sales are good we'll continue carrying them for convenience.
https://www.burgertuning.com/collect...ack-fuse-cover
Spaceme17 Spaceme17 is offline
Car: 2020 KIA Stinger GT2 AWD
Default 06-02-2020, 12:26 PM
Hello. Just joined this forum as I purchase a 2020 KIA Stinger GT2. Very interested in getting a JB4 along with a number of other add-ons. Very interested in these covers. I just send an e-mail asking this but figured I would ask here. Are there any sales, discounts, or coupons codes currently active? Thanks.
Default 06-02-2020, 01:45 PM
Sorry we're an every day low price business so never do sales or discounts. The covers are pretty decent deal though at $90 for both sides.
Vortex3.3 Vortex3.3 is offline
Car: Genesis g70
Default 06-02-2020, 02:22 PM
By any chance will these covers fit on the g70 as well?
2019 genesis g70 3.3 sport
Jb4, bms intakes, ark midpipes, jun bl catback.
TexasStinger TexasStinger is offline
Car: Kia Stinger GT 3.3TT AWD
Default 06-02-2020, 05:15 PM
You can order the G70 covers from me
Please go to the below link and send me a DM if possible
Kia Stinger Vanity/piggyback /fuse cover | Page 7 | Kia Stinger Forum
Default 06-02-2020, 05:29 PM
We don't stock those yet but plan to bring them in down the road.
Aldony Aldony is offline
Car: Kia Stinger GT1 2019
Default 06-03-2020, 01:23 PM
Just filled up with some E85. This time i added 4.5 Gallons of E85 and the rest with 93. Please check for any timing drops. If there us let me.know which once so i can see for myself on the graph.
Default 06-03-2020, 08:59 PM
Looks fine to me!
sym sym is offline
Car: Stinger
Default 06-05-2020, 09:01 AM
Denso plugs after around 20K miles. Originally gapped to 0.022. It's hard to tell from the picture but the electrodes were well worn. Probably going to change them every 12-15K from here on out.
Default 06-05-2020, 10:57 AM
15-20k miles is the usual plug range
turboAWD turboAWD is offline
Car: Stinger GT
Default 06-05-2020, 03:30 PM
Will the HKS last longer?
Default 06-05-2020, 04:16 PM
I imagine they will be around the same... Haven't worked with them much myself though.
Scorped Scorped is offline
Car: Stinger GT2
Default 06-08-2020, 03:33 PM
Terry, any idea what could have gone wrong here based on the log? Attempted a roll race and had little to no boost. Just a few minutes prior the car (Stinger GT, map 4, <E30, ewg disabled) was running fine.
Default 06-08-2020, 04:05 PM
I can't tell from this log no, would need the log where boost stopped. Usually means boost got too high though at some point.
Car: Stinger GT2
Default 06-08-2020, 04:32 PM
This IS the log where boost stopped.
Never mind though, forget I asked. Should have expected that answer.
Default 06-08-2020, 04:53 PM
This is a log showing no boost which is useless. I'd need to see what lead to it making no boost. e.g. boost vs. ecu_psi vs. engine criteria when it was making boost. The previous log if auto recording was left on which should show boost going over target and under what circumstance, assuming this is an over boost related fault. The kind that resets after you restart the car.
If you were not recording at that time then start recording now and try to recreate the issue so we can figure out how to best resolve it. If you've had over boosting issues in the past that require a lot of WGDC to be removed via EWG, disabling EWG might be part of your problem. Typically cars that over boost need dutybias set to 40 across the board, FF to 50 as a starting point.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 06-09-2020, 07:16 PM
Well, that escalated quickly, didn't it. LOL
No need to be childish. You're much more likely to be treated in a professional manner if you act professionally.
Or, you could send a text to the boys at Pross or Tork to see if they can troubleshoot your issues from two quick sentences... ��
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
Default 06-09-2020, 09:08 PM
Usually when someone posts like that they are just a troll. Removed the inflammatory comments in case the guy actually needs help.
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default 06-11-2020, 11:53 AM
"Typically cars that over boost need dutybias set to 40 across the board, FF to 50 as a starting point."
Could you elaborate on this ?, I do seem to be having fuel crashes on higher maps 3-5 on a roll even with the race fuel, Im I looking at going into user adjustments and under Duty Bias enter 50 flat across all values as a starting point ? Or should I just disable bit 4 v16 firmware.
