01-12-2020, 10:14 AM
We're still waiting for production to wrap up, don't have a date, but can't imagine it will be too much longer.
Car: 2019 Accord Sport 1.5
01-14-2020, 03:28 PM
Terry, just read this whole thread and installed my kit. When you get a chance would you check out my log? I only run shell 93 octane, I think they look good from when ive compared them to others on here. Also, the CVT in my 2019 Accord sport seems a teeny tiny bit confused under part throttle on MAP 2, are there any adjusts I should know about it that may cure that? No biggie if you think this MAP 3 looks good. I'll continue to monitor the logs. Thanks for the great product!
01-15-2020, 10:13 AM
Log looks solid to me! No signs of knock, boost and AFR are good.
For the part throttle try to capture the issue on a log and we'll see if anything looks off. Could just be adaption related though.
Car: Honda C-RV
01-15-2020, 07:34 PM
Is it surging a bit about 55-60 when cruising and then stops? or something else?
01-15-2020, 08:33 PM
Thank you for checking it, Terry. And I think you’re right, it’s the adaption in the car, if I drove it more on that MAP it would prob resolve in no time, I did capture a quick log by luck and I think it’s the timing moving a little that caused it to feel that way. Typical behavior on a fresh MAP I assume, no worries. Here’s a log for the curious.
01-15-2020, 08:37 PM
Only noticed it when cruising, honestly can’t remember if it’s in one or two speed ranges, I think Terry nailed it as part of the adaption. Since MAP 3 is working well in this cooler weather I’ll prob stick with it and the watch the logs when it warms up. I ran MAP 4 and the logs looked pretty darn good to me, but it was 33 degrees this morning so I assumed good 93 and cold air would work fine.
Car: Honda C-RV
01-16-2020, 07:33 AM
I had a similar glitch with the CRV, it was fully resolved with the last 2 firmware upgrades so I'm sure Terry will sort it. It seems that some speed/rpm is right where the turbo fully spools and the extra boost was causing the cvt to want to shift, then it went back up in gear when it realized it didn't need to. At least in the Crv's case.
01-16-2020, 09:11 AM
Let them know where to find us. The JB4 is a great alternative to ktuner for many reasons.
Car: Civic type R
04-05-2020, 05:56 AM
Hi Terry, can you please look at these 2 logs and let me know what you think?
Stock 2019 Type R
94 octane on map 3.
Thanks!!
04-07-2020, 03:52 PM
Stock 2019 Type R
94 octane on map 3.
Thanks!!
Looks good but gas pedal is not going 100% here. Something blocking it?
Car: Civic type R
04-07-2020, 04:40 PM
Hmmm. Not that I know of. I’ll try to get some more logs and see. Thanks!!
Car: 2020 Honda Accord 2.0t
04-08-2020, 04:56 PM
So I installed the jb4 on my new 2.0t Accord sport. Everything is working great. I am running in map 0 (factory). Because I only have 600 or so mile on the car. My question is when or how many miles until it is safe to get on it on in the other maps for engine health. Thanks
04-08-2020, 05:04 PM
Also can u disable the speedlimiter with the jb4
Car: Civic type R
04-08-2020, 05:16 PM
Hey Terry, I redid the runs. Can you please look at them again?
2019 Type R. Bone stock. 94 octane
Thanks!!
04-15-2020, 08:44 AM
Is this an active page??
04-15-2020, 09:24 AM
Whenever you like. We run JB4 on our car with less than 100 miles on them.
Not at the moment, sorry.
04-15-2020, 09:35 AM
Thanks!!
04-15-2020, 04:12 PM
So I installed the jb4 on my Accord sport 2.0 and love it. My question is what are the horse power gains for maps 1-3 I can't find the avg anywhere
04-15-2020, 04:15 PM
Not sure if we have any Accord dynos specifically posted but the higher the map, the more aggressive the boost target, and presuming knock is under control, the more power.
04-15-2020, 04:56 PM
I am a newb lol is it safe to run the pre installed maps. And what is knock? Lol sorry I'm learning. Everything is doing good right now but I really haven't pushed it yet
Car: 2019 Civic Type R FK8
04-18-2020, 09:33 AM
New here, wondering anybody with an 2019 FK8 that has been running this for a decent amount of time, esp with mods. I drive a lot and am wondering what to expect. Just going to have an intake to start but also wondering if much difference after adding a catback or possibly down pipe as well?
04-18-2020, 11:00 AM
The JB4 records knock among all other safety parameters so you can always record a log and post it if you want us to check it for you.
Olimpiakos
Car: 335i e90
04-23-2020, 03:14 PM
Hey Terry. So Im picking up a 2020 2.0 Accord this weekend. About to order a jb4 on the website. The non type R one correct? And does the intake fit the 2.0 also?
Thanks man
YMB F80 M3- Jb4
F85 X5M-Jb4
Car: Accord Sport 2.0t 10AT
04-24-2020, 01:27 PM
Can someone review this log map4 on e30
