Car: Accord Sport 2.0t 10AT
03-29-2020, 06:16 AM
I don't usually launch this car but if I do it kicks out maps 2 and 3 and god to map 0. I don't believe it will do it in map 1. Any suggestions? Im starting to get frustrated with this and dont like the inconsistency I'm getting.
03-29-2020, 03:37 PM
Would need to see a log of it for tuning advice.
03-29-2020, 04:00 PM
This should be some of them.
03-30-2020, 03:04 PM
Posted logs. Still awaiting a response
03-31-2020, 09:43 AM
You're hitting boost safety. Raise it to 26 psi and get another log.
03-31-2020, 09:58 AM
It keeps going to map0 still raise it to 26psi?
03-31-2020, 11:23 AM
Do you have the log?
03-31-2020, 12:01 PM
I thought one of those 2 were them bc the following log was map0. Ill post 3 more hope fully it's one of these it happens a lot. Im not sure what to look for in the log. Thanks for the help!
03-31-2020, 01:34 PM
I saw those logs, and replied.
Please raise boost safety to 26 psi and get another log.
03-31-2020, 01:47 PM
Sorry I misread your first post... will do have to run down my tank of regular before I test again. I'll report back as soon as I put 93 back in. PS I only run 93 when tuned, running stock atm.
04-01-2020, 10:26 AM
You got it, no worries!
04-07-2020, 05:04 PM
Finally got those logs for you
For some reason logs being combined?
04-08-2020, 10:24 AM
Knock count is moving up so map3 is probably too much for the octane. I'd roll down to map2.
04-08-2020, 05:05 PM
Thanks I appreciate it running 93 too, although ando told me I could move to map4 on e30? Makes me worried that I have 2 totally different responses on the same logs. Im not looking to blow this thing up...Unfortunately I guess map 2 it is.
As far as knock count goes thats ign1 or 2? What should I be monitoring? I prefer to be educated on how this all works.
04-09-2020, 09:04 AM
E30 and 93 are different octane levels. So with the higher octane on e30, you should be safe to use a higher map.
Ign 1, you can see 2-3 counts in that one pull.
Logging Parameters and their Meaning - N54Tech.com - International Turbo Racing Discussion
04-09-2020, 09:18 AM
understood. Should I try e30 on map3 or map4 and then log?
04-09-2020, 12:32 PM
The Honda stuff is a little different than other models. Ign2 is history knock sensor activity and ranges from 0.49 = no knock up to 1.0 = getting noisy.
04-09-2020, 01:11 PM
So Terry what would you advise on using e30? I'd like to get the most out of it but still remaining pretty safe. Or should I just stay away and be happy with map2?
04-09-2020, 02:53 PM
Log map2 and map3 on E30.
04-10-2020, 08:34 AM
Ah, just read the post now. So it's an average knock, between all cylinders.
04-10-2020, 09:49 AM
Basically yes it's an average historic knock count. Sort of like avg_ign we setup in the BMW firmware. We also have it mapped out to avg_ign in Honda firmware in an easier to read 0-100% format.
04-22-2020, 06:32 PM
Got the logs of Map 2 and 3 running e30...might I say, what a difference!
04-22-2020, 08:16 PM
Looks much better!
04-22-2020, 08:42 PM
Glad to hear thanks for reviewing it! If you can, please check this one on map4. Fingers crossed...
04-23-2020, 07:06 PM
^The suspense is killing me...
