B58_Dude
Car: M240i
01-27-2020, 07:49 PM
The newest firmware is located on the first page of this thread under the last picture (The engine bay) in Terry's post.
JB4_B48_B58_14_T11.hex
I recommend always using the newest firmware whenever they update it.
Yes the maps are different, I would definitely data log map 0 for a baseline then map 1 before moving onto the others. Once you get a log of the new map I would recommend posting it in the "Support & Log Review" Forum. Either Terry or one of the other BMS support will review it.
Ex: I was running map 3 for a couple of weeks posted it and my trims were maxing out and it was not ideal for my car (M240i). Thus with 93 octane map 1 is basically the safest and most ideal for me to be running.
Hope this helps, I would still wait for one of the support guys though on their advice!
Reason: Update it to be cleaner and more accurate
Car: 2020 BMW 440i Xdrive Convertible
01-28-2020, 08:06 AM
Terry I tried the test firmware on my 2020 F33 and the CANFlaps are working now!
01-28-2020, 09:17 AM
Sweet!!!
01-28-2020, 03:57 PM
Sweet!!!
I only did 1 logged pull with gears 1-4 on v15 and it looked very good. Nice and smooth trims, boost, and AFR. If 1 log is useful I’ll send it in or post it.
01-29-2020, 09:44 AM
Post it, lets take a look!
01-31-2020, 04:36 PM
Here you go.
02-03-2020, 10:54 AM
Here you go.
Looks really good!
Car: 440i
02-06-2020, 09:04 AM
Morning BurgerFolks!
I just bought one of your early beta JB4 units for the B58, with the metal housing.
Can you tell me - is the unit weather resistant? Have there been any hardware changes since this unit was produced?
02-06-2020, 02:37 PM
Yes, but moisture and condensation can still get through if you put it near a rain drain under the hood.
Car: 440i
02-06-2020, 05:48 PM
Thanks Payam - can you tell me if there have been any hardware changes/updates since this unit was produced? Thank you!
Car: 2016 340i xdrive
02-07-2020, 04:31 PM
Hey everyone.
2016 340i x drive here, so far my mods are:
Jb4, BMS intake, ctsturbo **, ngkplugs gapped at .22, 550i luk clutch upgrade.
I have a few logs in 3rd if anyone is able to review. I run map 5 usually and I live in the midwest in kentucky
Edit: apparently mobile uploads of csvs dont work. I'll upload on a computer shortly.
Reason: Files didnt upload and now I look like a doofus
02-07-2020, 04:53 PM
here are the logs.
02-14-2020, 06:11 PM
Added v15 firmware to the JB4 firmware database linked in the first post to start to get some logs in.
v15 BETA
1) Revised map guide, map4 is now absolute 20psi map and map5 absolute 22psi map, especially useful for Supra/M340i applications on E85 mixtures.
2) Revised boost control system for vehicles equipped with the EWG connector. Set duty bias to 50 across the board as the new default settings.
3) Added CANflap support for newer models.
4) Adjusted FF to save unique values per map to facilitate boost targeting during on the fly map changes.
5) Added speed logging parameter.
02-17-2020, 09:08 AM
I think minor changes to the board, nothing major that would need attention.
Car: Supra 2020
02-20-2020, 09:08 AM
Swapped from V14 to V15 for my Supra, duty bias changed to 50, I see FF is set default at 0, is that function still the same as V14 where I had it around 100 or do I keep it at 0?
Also I'm assuming pid gain remains unchanged between both versions?
Car: 440i
02-20-2020, 11:25 AM
I apologize if the answer to this question has been covered elsewhere, but I've been unable to find it.
On the JB4 firmware versions, what does the "T__" designation mean in the filename?
For example:
Which file should be used in what situations?
Thank you!
02-20-2020, 11:31 AM
For example:
Thank you!
Those are just notes for us.
Higher the number, the latest one.
You'd want this one JB4_B48_B58_15_T16.hex
Car: 440i
02-20-2020, 11:50 AM
So the "14.hex" file is made of notes and the "_Txx" version is the firmware? Hmm...
Whatever the case, I think I hear you saying "always use the "_Txx" version", yes?
Thank you again!
Car: Supra 2020
02-21-2020, 03:38 PM
Tried V15 firmware for 2 days, it's been very annoying for my application:
2020 Supra, jb4 with EWG harness installed, Titan downp, drop in filter running map 6 with great success on V14.
Migrated to V15 with same map setup, the car spiked like crazy upto 28psi and went into limp mode.
Reset and went to 50 duty bias and played with FF and setup to each for a couple of pulls( 0, 50, 100) , results are almost the same, I'll always get throttle closures down to 40s%.
Also, there seems to be a bug, when I am on map 6 and do settings/user adjustments and save, these settings are saved for map 6, let's say I then run map 5 and then I go to the user adjustment to play around, I'll find totally different FF and PID settings which I can change again, if i save and select map 4, the settings would also be different, unlike V14, no matter which map you are on, that custom table is only reserved for map 6 and would t be different for each map.
One last issue, with v15, I keep getting fault 12AB04 rear O2 sensor disconnected where I will get limited with boost, stop car, reset codes, go for a pull and find that I'm boosting well but I get throttle limited to 40-50% again..
Almost always, DME BT is lower than ecu psi.
Reflashed to v 14, cleared codes, car is pulling perfectly again.
02-24-2020, 11:10 AM
Logs??
Car: Supra 2020
02-25-2020, 08:49 AM
Payam, here are 2 logs one with almost perfect run (except the spike) another is the aftermath.
Note, I noticed high boost spikes during gear shifts even if the boost was manageable under load, it would spike between shifts and cause issues as well.
v15 has great potential, I see good increase in ignition timing, I think with minor tweeks the firmware will rock the supra.
Keep up the great work bms!!
02-25-2020, 11:05 AM
Something isn't lining up here, drop me an email with the log and we'll work on the details. terry@burgertuning.com
02-25-2020, 11:33 AM
Just updated to v15. Pulls are a ton more consistent and so is my throttle response. Ran map 3, 4 and 5 to test it out. I have the ewg harness add on to my 2016 340i and setting my DBS to 50 across the board really helped.
I'd post a log or two but I'm on mobile so it wouldn't format.
03-10-2020, 06:42 AM
Totally different question regarding JB4 specific for California (CARB approved version). Can the firmware be updated on those? If not, can anything be done to update the firmware?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
03-10-2020, 02:33 PM
No updates on those.
