(#476)
austinkale00 austinkale00 is offline
Car: 2018 Honda Civic EX
Default 08-12-2019, 10:28 AM
Outside the USA there is a passive delete option. Inside the USA there is not for emissions purposes.
What all is needed for proof of outside the U.S. lol..
Jb4, BMS intake, Drag wheels
Default 08-12-2019, 11:03 AM
The app checks your GPS.
Default 08-12-2019, 11:07 AM
Well dang. On another note, I've been running JB4 for 20k miles with no issues for those wondering about longevity. I've been on Map 5 for the last 5k.
Default 08-12-2019, 11:24 AM
Good to hear! Help spread the word that people don't need to resort to reflash their cars to pickup solid reliable gains.
Dan Villa Dan Villa is offline
Car: Accord Sport 2.0t 10AT
Default 08-13-2019, 08:25 AM
Any updates on fueling for the a ccord 2.0 running map3?
Default 08-13-2019, 10:29 AM
No updates on our end, no. You'd have to evaluate your own logs to see what map setup works best for your car/conditions/fuel.
Default 08-13-2019, 11:25 AM
Map2 is as far as I can go.
ededic00 ededic00 is offline
Car: 2011 BMW 535i
Default 08-14-2019, 03:58 PM
Hi Terry. I had a JB4 in my previous car and had zero issues. So when I purchased my 2019 Accord I wanted to get some break in miles on the engine before adding more power. Attached is a Map 1 log that I did earlier today. My car is a 2019 Accord Sport 2.0T with the 10 speed automatic transmission. I am running a Takeda Cold Air Intake System w/Pro 5R Filter and 93 octane fuel. Let me know how Map 1 looks and ill get more logs of other maps, once you approve. Also if it helps you guys in any way, my wife has a 2019 CR-V and I can move my JB4 to her vehicle and get some logs for you as research if needed.
Current: 2019 Honda Accord Sport 2.0T 10AT
Mods: JB4, Takeda PRO 5R Intake, Mishimoto Oil Catch Can.
Previous: 2011 BMW 535i M-Sport
Mods: JB4, BMS F10 N55 Intake, VRSF down-pipe.
Default 08-14-2019, 06:00 PM
Looks fine to me! Boost, knock, and fueling all under control. Lets compare with map2 next.
Car: 2011 BMW 535i
Default 08-15-2019, 08:17 PM
Terry, attached are two logs I did today with map2. Let me know how it looks and if you want me to try map3. Thanks
Default 08-15-2019, 08:20 PM
Map2 looks clean too! That is normally a good map to run we've found. So no need to crank it unless you need the extra power.
Car: 2011 BMW 535i
Default 08-15-2019, 08:21 PM
Alright, for now ill stay at Map2 until I get an itch for more power. Thank you.
Nex Nex is offline
Car: Civic type R
Default 08-17-2019, 02:43 PM
Hi Terry,
Just got the JB4 installed on the Type R. Using 94 octane. Everything else is stock.
How do the logs look? I did a map 1 log. Everything felt good. I went ahead and did a map2 log as well. Let me know
Default 08-17-2019, 03:02 PM
Logs look fine to me.. You can stay with map2 as long as it's running well. But if fuel pressure starts to crash at some point (which will result in engine stuttering) then definitely drop back down to map1.
Nex Nex is offline
Car: Civic type R
Default 08-17-2019, 03:08 PM
Thanks Terry!
Which variable on the chart is the fuel pressure?
Jonplavist Jonplavist is offline
Car: Civic
Cool Map 2 - 08-19-2019, 07:22 PM
Hello Terry could you review my map 2 fk8.
Map 6 question, how much more aggressive is it than map2?
stuffle69 stuffle69 is offline
Car: 2019 type r
Default 08-19-2019, 08:50 PM
Terry,
Getting code p0420 should the jb4 be able to delete this code? when i click delete code it starts to then says reading code and never gets deleted any suggestions i have catted ******** by prl.
Default 08-20-2019, 10:22 AM
Originally Posted by stuffle69
Terry,
Outside USA passive delete can be turned on on the WMI page.
Default 08-20-2019, 10:23 AM
Map6 is a user adjustable map. Since fuel pressure is the limit on the typeR there generally isn't any reason to run over map2.
Car: Civic
Default 08-20-2019, 10:33 AM
Sorry Terry, I posted a log in my original post just wanted to make sure it looked OK.
Thanks,
Car: 2019 type r
Default 08-20-2019, 11:00 AM
Where is wmi page located?
Default 08-20-2019, 12:16 PM
In the app
Car: 2019 type r
Default 08-20-2019, 12:24 PM
In the app
ok found it when i click on wmi to modify what do i need to change?
Car: Civic
Default 08-20-2019, 12:46 PM
Terry
Can you take a look at this map 2 log 93 octane stock car fk8.
Default 08-20-2019, 06:41 PM
Terry
Looks OK to me.
