Car: M135ix
04-23-2019, 10:47 AM
check page 1
04-27-2019, 01:58 PM
I had a few friends with PS2, Speedtech stg3 and Bigboost stg3 that are installing B58 hpfp on N55 cars.
I can say if you have some crashing N55 hpfp because with E40 no matter PI or wmi I like the idea of buy an used B58 hpfp ($350) vs N55 ($250)
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
Car: M135ix
04-29-2019, 08:38 AM
Car: 2015 335i
04-30-2019, 09:00 AM
04-30-2019, 09:11 AM
Originally Posted by 52172
no, that says in thank.
that is LPFP
Car: 2015 335i
04-30-2019, 09:24 AM
Gotcha....
Car: 2015 335i
04-30-2019, 10:51 AM
How much power will this puppy support? 600 rwhp?
05-22-2019, 03:13 AM
Great info. If you want more fuel B58 hpfp flows more than N55.
Car: M135ix
05-22-2019, 02:52 PM
if you want that kinda power , you'll need xdi and Emix for sure
hdp5evo is only a little bit better compared to hdp5
05-24-2019, 03:11 AM
T_H_O_M_A_S thanks for open this thread.
I am now using B58 HPFP and I could say is at least 20% more effective than N55 HPFP on real world. Look a graph of my car last night run about 125mph at 402mts without making brake boost.... 11.51@125mph with 1.95 at 60ft 1st and 2nd 20psi, 3rd 21psi , 4th 22psi and 5th 23psi. I am using WMI as alwys. I think this is one of the most important and simple modification you should do to your N55 engine.
Car: 2015 335i
05-27-2019, 07:01 PM
Will it hit 500 whp?
Car: 2015 335i
05-28-2019, 07:45 AM
Whose the company developing the new hpfp to compete with the xdi?
05-28-2019, 09:11 AM
that is a very difficult question, it will depend on all other factors, which turbo, which bef, with or without meth, etc.
This week I will test in almost exact same conditions where oem N55 hpfp could not keep pressure no matter any PI setting using E40 and I will keep you posted guys
Car: 2015 335i
05-28-2019, 09:16 AM
Yes please keep us posted. Do you know which company is developing a pump to compete with the xdi? Also what’s the deal with the pi pump? Thanks
Car: 335i coupe 2010
06-05-2019, 03:34 PM
whats ambient temps near you lucho? turn off your WMI and test that pump out
Car: E90
06-09-2019, 12:43 PM
Hi Thomas what do mean by?
“you only have to close off in and outlet , and the spring while machining it .
soldering is also pretty easy ”
Is there something we have to solder closed?
2011 F10 535i | D Shoup Flash | PS2 | GFB DV+ | Wagner FMIC | Helix Overdrive | Sprint Booster | CDV Mod | Koni Yellows | Eibach Sports | M5 Sways | Spec 2 Clutch | SMF | UUC SSK | Custom Inlet | Custom Dynomax Exhaust
Car: M135ix
06-09-2019, 03:48 PM
you dont want to have any metal particles going in to the pump , it will wreck it for sure and if parts get into your injecttors your ****ed too , so i would closeoff in and output while adjusting the flange
you have to solder the newer style connector if you car is prior 2014 or so .
old connector is much bigger than th enew one
Car: E90
06-09-2019, 05:35 PM
Ok I see what you’re saying. Def will tape-off to prevent debris. As for the wiring harness I will have to get the correct one and retrofit it. I will have more info too to add to this experiment. Picked up a used pump and wiring harness for 175. Pay to play
06-26-2019, 12:27 PM
Gotcha....
Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay
High Pressure Fuel Pump 13517642466
Car: 2015 335i
06-26-2019, 01:05 PM
600 is too much for a pump a little better than our factory pump
06-26-2019, 01:41 PM
New B58 HPFP cost $1,350
Car: 2015 335i
06-26-2019, 02:19 PM
Yep but people are getting them for 200. Pretty common.
06-26-2019, 02:39 PM
I have 4 friends waiting for those prices...
Car: 2015 335i
06-26-2019, 02:43 PM
Have they checked car-part.com?
Car: 2015 335i
06-26-2019, 02:45 PM
I’m waiting to see how much power can be made on pump gas with this pump and ps2 turbo.
