BigDBD BigDBD is offline
Car: 2018 Accord Touring 2.0T
Default 02-05-2019, 04:03 PM
Here you go! It looks off because the plastic Engine Cover was removed. Please PM me directly if you would like me to help with any testing and stuff. I'll do what I can once the weather warms up!
Default 02-05-2019, 08:14 PM
For the install photos might be faster to email support@burgertuning.com, as Ando knows this one the best.
Dan Villa Dan Villa is offline
Car: Accord Sport 2.0t 10AT
Default 04-19-2019, 07:59 PM
I finally did a couple of videos of the installation as well as some driving.
Install Video:
2018 Honda Accord 2.0t and 1.5t JB4 install - YouTube
Driving:
2018 Honda Accord 2.0t JB4 results 0-60 - YouTube
Default 04-19-2019, 08:00 PM
Terry, Any eta on canbus control?
Default 04-19-2019, 09:50 PM
Should be active? JB4 log with OBDII in?
Default 04-20-2019, 07:32 AM
Last I spoke with you, you said it was in the works and to just stay in map 1 for now. Gave you my logs in above posts around 6 months ago. I was wondering if there were any updates as far as getting boost readings, afr, new maps, etc...
Default 04-20-2019, 09:19 AM
Plug in OBDII, update to latest v5 firmware, grab a log, and lets evaluate it!
Default 04-20-2019, 09:58 AM
I do not have an OBDII plug with my jb4 only the optional data cable. I use an otg cable to connect to my phone with the app. That should be fine right?
Default 04-20-2019, 11:42 AM
You need the OBDII cable for the JB4, it would have been included with the tuner. If you don't have it contact us for it.
Default 04-20-2019, 12:01 PM
Yes your right, I had to check the box it came in. I totally forgot it was in there, its been a while. I'm going to try and get some logs tonight. Two little ones will make you lol.
Default 04-20-2019, 01:57 PM
Haha I know the feeling! Sounds good.
Default 04-20-2019, 07:20 PM
Got the logs done
Default 04-20-2019, 08:41 PM
Looks fine to me! Let's try map2 next.
Default 04-21-2019, 09:09 PM
I drove around with map2 today but had the kids in the car so couldn't really play around. It did feel good and smooth no issues. Definitely could feel the turbo spooling much sooner and lots more diverter valve sound. I will get some logs in the next day or so. Could you please list what each map is and bolt on requirements?
Default 04-22-2019, 08:39 AM
Check the main Honda JB4 thread!! We have it in the first post.
Default 04-27-2019, 08:04 PM
Got that mobile adapter installed and ran the logs. Got map2 and 3 for you!
Default 04-27-2019, 09:11 PM
Both look fine to me! Boost, timing, knock, fueling, all in check
Default 04-27-2019, 09:16 PM
Map 4 and 30% e85 next?
Default 04-28-2019, 01:38 PM
Hey Terry just got a code P0200. I unplugged the battery and all is good any ideas? Btw I was running map3 when this happened.
Made another video on progress:
2018 Accord Sport 2.0t JB4 Map3 results and 0-60 ish - YouTube
Default 04-28-2019, 06:02 PM
Some sort of fuel injector related code it appears... If it comes back I'd let the dealership take care of it for you.
Default 04-29-2019, 07:34 AM
The car definitely doesn't like map3. On the highway it's fine but from the lower gears and more frequent shifts seems to make it kick out of map3 to map0. The 10sp AT is busy at lower speed. Maybe has something to do with fuel cuts during shifts? Posted a log when it happened.
Default 04-29-2019, 09:00 AM
Any misfire codes? If not that then likely fuel pressure dropping. I see it starting to tank in the log. Sounds like map2 is the best fit for your specific situation.
Default 04-29-2019, 11:19 AM
I checked and didn't come up with any codes. Yeah I'm just going to run map2 for now seems to be the sweet spot. Do you think its specific to my model 2.0t 10 At or my actual car?
Default 04-29-2019, 03:53 PM
Too early to know, we'll have to see what other setups can get away with.
Default 08-12-2019, 06:38 PM
Any updates on fueling for running map3?
I made a quick video of some pulls on map2 video below!
2018 Accord 2.0t night driving JB4 map2 highway pulls - YouTube
