Car: 2018 Accord Touring 2.0T
02-05-2019, 04:03 PM
Here you go! It looks off because the plastic Engine Cover was removed. Please PM me directly if you would like me to help with any testing and stuff. I'll do what I can once the weather warms up!
02-05-2019, 08:14 PM
For the install photos might be faster to email support@burgertuning.com, as Ando knows this one the best.
Car: Accord Sport 2.0t 10AT
04-19-2019, 08:00 PM
Terry, Any eta on canbus control?
04-19-2019, 09:50 PM
Should be active? JB4 log with OBDII in?
04-20-2019, 07:32 AM
Last I spoke with you, you said it was in the works and to just stay in map 1 for now. Gave you my logs in above posts around 6 months ago. I was wondering if there were any updates as far as getting boost readings, afr, new maps, etc...
04-20-2019, 09:19 AM
Plug in OBDII, update to latest v5 firmware, grab a log, and lets evaluate it!
04-20-2019, 09:58 AM
I do not have an OBDII plug with my jb4 only the optional data cable. I use an otg cable to connect to my phone with the app. That should be fine right?
04-20-2019, 11:42 AM
You need the OBDII cable for the JB4, it would have been included with the tuner. If you don't have it contact us for it.
04-20-2019, 12:01 PM
Yes your right, I had to check the box it came in. I totally forgot it was in there, its been a while. I'm going to try and get some logs tonight. Two little ones will make you  lol.
04-20-2019, 01:57 PM
Haha I know the feeling! Sounds good.
04-20-2019, 07:20 PM
Got the logs done
04-20-2019, 08:41 PM
Looks fine to me! Let's try map2 next.
04-21-2019, 09:09 PM
I drove around with map2 today but had the kids in the car so couldn't really play around. It did feel good and smooth no issues. Definitely could feel the turbo spooling much sooner and lots more diverter valve sound. I will get some logs in the next day or so. Could you please list what each map is and bolt on requirements?
04-22-2019, 08:39 AM
Check the main Honda JB4 thread!!  We have it in the first post.
04-27-2019, 08:04 PM
Got that mobile adapter installed and ran the logs. Got map2 and 3 for you!
04-27-2019, 09:11 PM
Both look fine to me! Boost, timing, knock, fueling, all in check
04-27-2019, 09:16 PM
Map 4 and 30% e85 next?
04-28-2019, 01:38 PM
Hey Terry just got a code P0200. I unplugged the battery and all is good any ideas? Btw I was running map3 when this happened.
Made another video on progress:
2018 Accord Sport 2.0t JB4 Map3 results and 0-60 ish - YouTube
04-28-2019, 06:02 PM
Some sort of fuel injector related code it appears... If it comes back I'd let the dealership take care of it for you.
04-29-2019, 07:34 AM
The car definitely doesn't like map3. On the highway it's fine but from the lower gears and more frequent shifts seems to make it kick out of map3 to map0. The 10sp AT is busy at lower speed. Maybe has something to do with fuel cuts during shifts? Posted a log when it happened.
04-29-2019, 09:00 AM
Any misfire codes? If not that then likely fuel pressure dropping. I see it starting to tank in the log. Sounds like map2 is the best fit for your specific situation.
04-29-2019, 11:19 AM
I checked and didn't come up with any codes. Yeah I'm just going to run map2 for now seems to be the sweet spot. Do you think its specific to my model 2.0t 10 At or my actual car?
04-29-2019, 03:53 PM
Too early to know, we'll have to see what other setups can get away with.
