(#1226)
Default 12-17-2018, 09:15 AM
WMI discussion here: https://www.n54tech.com/forums/showthread.php?t=56205
Metalmania82 Metalmania82 is offline
Car: Stinger GT
Default 12-17-2018, 09:46 AM
It's an add on wire to the JB4 harness we're experimenting with that lets it adjust the IAT, originally was testing it for timing control but found it's more useful in situations where we need to increase the flash target. Like really cold weather, with primary *** deletes. For now it's just an experimental thing I'm testing with a couple customers.
Would this help at all with secondary deletes?
Default 12-17-2018, 10:04 AM
Don't think so, testing it for primary combined with very cold weather, where throttle closure is an issue due to the low factory boost target in cold weather. The better solution for them longer term will be JB4 EWG control but we're still working on that. The EWG control is going to open up the tuning for larger turbos down the road.
Adamdan Adamdan is offline
Car: Stinger
Default 12-17-2018, 11:59 AM
Hey terry I did some test runs on map 0-3 today. No issues so far car pulls very hard and smooth. My afr are around mid to high 11s. I did notice When I did a pull on map 0 in 3rd and my afr are around the same as with all the other maps. Does map 0 not disable everything? Like it drops boost down to stock but fuel changes are still active. I’m running a e85 mix right now if that helps.
sym sym is offline
Car: Stinger
Default 12-17-2018, 12:16 PM
@Terry,
In some of my logs the "oilf" value is a constant 200, in others it is a constant 0.
Is this an oil temperature switch or is there something else going on?
Default 12-17-2018, 01:03 PM
Originally Posted by sym
@Terry,
Oil logging isn't active currently. If you press WMI purge then that is probably what you're seeing in the log, that doubles as a diagnostic button for internal tests we do on the unit prior to shipment.
Let me see the map0 log, it should disable fuel control. I can tell from the log and the fuel enrichment parameter.
Car: Stinger
Default 12-17-2018, 01:14 PM
here is a short map 0 and a map 2 and 3 pull.2018-12-17 10_33_37 Map-0.csv
2018-12-17 10_43_11 Map-2.csv
2018-12-17 10_36_52 Map-3.csv
thx
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 12-17-2018, 01:24 PM
You can tell fuel control is not active on your map 0 log because the parameters 'fuelen' (bank 1 bias) and 'calc_torque' (bank 2 bias) are both 0 throughout the run. Your other logs show these with values indicating that fuel control is active
Car: Stinger
Default 12-17-2018, 01:34 PM
Thanks now I know what to look for. I wonder why my car is so lean then. Even the runs with fuel wires it does not seem to need to run a leaner afr through most of the rpm range.
Default 12-17-2018, 03:52 PM
here is a short map 0 and a map 2 and 3 pull.Attachment 82026
Attachment 82027
Attachment 82028
thx
Looks off on map0 to me! If you do a longer run with shifts you should see AFR go to 10:1 on the map0 without fuel control.
The fuel control is meant to balance out the COT mapping in the DME that targets a rich AFR as modeled EGT increases.
Meltony67 Meltony67 is offline
Car: 2019 Kia Stinger GT
Default 12-17-2018, 04:05 PM
New to the group guys! Purchased a 2019 Stinger GT AWD a few weeks ago and I have to say, I'm really enjoying the car. I have about 1200 miles on it and installed intakes and muffler delete. Gapped factory plugs to .022 as well, thanks to the tips in this thread.
Purchased a JB4 w/fuel wires and wireless connectivity this past weekend and I'm super stoked to get it installed on the car. Let me know if you guys have any tips on anything and I look forward being part of the group.
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default 12-17-2018, 06:24 PM
FYI - not sure you want to gap the stock plugs to 0.022, that’s too tight for those (right terry?). You need the colder densos to do that I think
Car: Stinger
Default 12-17-2018, 06:38 PM
I have stock plugs gapped to .024 with no issues so far I’ve run all the maps but run 2 and 3 mostly. That being said I wish I would have put a colder plug now.
Default 12-17-2018, 07:03 PM
With v7_BETA3 it appears the passive delete change made didn't work so I reversed it for now.
For using using that feature update and let me know. For those not using it no reason to update that is the only change from BETA2.
Default 12-17-2018, 07:33 PM
You can gap stock plugs down to 0.020 if you want, no problem at all. But given all the work to take it apart for me the Denso's make more sense. They are a better plug IMHO.
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 12-18-2018, 03:55 PM
For some reason I can't find Calc Tq on the log. Am I missing it?
Default 12-18-2018, 04:10 PM
You're on the latest firmware? It's on column n
Car: Kia Stinger
Default 12-18-2018, 04:15 PM
Yes I'm on the latest firmware.
Car: Kia Stinger
Default 12-18-2018, 04:18 PM
Where is column n?
Default 12-18-2018, 04:21 PM
Where is column n?
Sorry I'm on mobile, but here.
Car: Kia Stinger
Default 12-18-2018, 04:24 PM
I'm lost what your trying to say. I'm on the latest firmware. But I do not see the Calc Tq anywhere.
Default 12-18-2018, 04:57 PM
Why looking at CSV? Email log to yourself and view on windows app, or on phone in graph format. May be called dutycycle still in CSV.
I sort of doubt the data itself matters to around 99.9% of you on that parameter... Do you guys know what you're looking at with it?
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 12-18-2018, 10:27 PM
I believe it is still called duty cycle
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
drumma022 drumma022 is offline
Car: 2016 340i
Default 12-19-2018, 07:42 AM
Another 60-130 log. Although the boost isn't as high as the last few logs I've posted, but this is my best time so far.
Map 3 on v7 Beta.
Still E30-ish in the tank (about 1/3 tank so weight may be the factor).
Note - not a 1/4 mile time (I wish!)
Next chance, I will try a 1-shift and a 0-shift pull.
