Car: bmw 335i
08-13-2018, 05:31 PM
What maps would you like to see the most?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Car: bmw 335i
08-13-2018, 05:56 PM
Also any plans for a JB for the C63?
Car: 2012 135i M-sport package
08-26-2018, 07:47 AM
Is there a metal enclosure available for this JB4? I thought I remember seeing it somewhere on the BMS website, but I can't find it now.
08-27-2018, 10:31 AM
Yup!! All the way on the bottom, Billet Casing
http://www.burgertuning.com/JB4_upgrades.html
08-27-2018, 03:26 PM
That specifically mentions E/F series BMW. Will this W205 MB JB4 fit perfectly in that case? Thanks,
08-28-2018, 09:16 AM
Yes, sorry about that. I'll have them fix the description.
Car: Mercedes C43
08-28-2018, 02:57 PM
Here are a few quick logs from last week on my C43. Seems like I don't make map 2 target boost of 6 psi until 4th gear? What all should I be looking for when making adjustments on my map 6? I'm sure the Texas heat isn't helping, but our platform seems to be very sensitive to IAT. DA varied between 2200 and 2900 during these logs.
Map 6 (starting IAT around 116F), 3rd and 4th gear
Map 6 (added .2 psi across rpm and starting IAT around 112F), 3rd and 4th gear
Map 2 (starting IAT was 95F), 3rd gear
08-28-2018, 04:07 PM
Post the CSV files for logs, so I can open and view them in the JB4 interface. But the target is a request. The turbos may not be able to hit that request until EGT gets up which is what you are probably seeing.
Car: MERCEDES C400
08-28-2018, 05:02 PM
Here is two logs with a map6 in my c400
Both logs starting in 2nd Gear DA around 2600
First log 93 Degrees outside with 93 fuel
Second log 95 Degrees outside with E30
Doing this from my phone so hopefully I got the logs to upload correctly.
08-28-2018, 06:15 PM
Both look really clean to me. Timing rolling up towards redline, boost on target, AFR in check.
Car: Mercedes C43
08-28-2018, 06:54 PM
My bad! All runs on E25. How does EGT effect our cars?
2018-08-22 19_44_31.csv
2018-08-23 map6 heat v2 throttle fail.csv
2018-08-27 20_17_58.csv
2018-08-28 19_54_02.csv
08-28-2018, 07:52 PM
In lots of ways, but what I was referring too above is when you're working against limits of the turbo itself, as EGT goes up there is more relative exhaust pressure to hit higher boost targets.
What's wrong with the "throttle fail" log?
Car: 2018 AMG C43
08-28-2018, 09:00 PM
check these
08-28-2018, 09:16 PM
Using boost by speed I see, looks fine to me!
Car: Mercedes C43
08-29-2018, 06:48 AM
I was under the impression that big drops in throttle indicated that I was requesting too much boost. Are large dips in the throttle ok? Is there a better method to adjusting target boost in map 6?
08-31-2018, 09:02 AM
Will this work with the GLC43 AMG? I assume so since it is the same exact engine as the C43.
08-31-2018, 09:04 AM
Yes
08-31-2018, 09:05 AM
Throttle is used to regulate boost if it jumps over target or the target suddenly changes. Dips are fine. If the throttle is consistently closed that would indicate a physical issue with the car that needs to be resolved like a stuck wastegate.
Car: C400
09-02-2018, 07:37 AM
Hey Terry,
I am hoping you can tell me your thoughts on running JB1 on Map 2 on 91 octane at 5K+ ft altitude. I have researched the octane at altitude topic but there seems to be much debate. The idea is that 91 octane at high altitude performs the same as 93 would at sea level but that seems to be for NA cars and not turbo cars. I really would like to run map 2 but we only have 91 octane fuel in CO. If the answer is to run some logs on map 2 and evaluate, what should I be looking for in the logs that would indicate the car is behaving badly? Thanks for the help!
09-02-2018, 09:55 AM
I'd have to see the JB4 log to evaluate it myself. Mainly looking at the ignition advance profile during longer single gear pulls, and shortly after shifts, for 3 degree drops indicating pull back.
Car: C400
09-02-2018, 01:58 PM
Thanks. I was hoping maybe the question had been asked before. Looks like I will have to upgrade to the JB4 so I can get a better log to evaluate
09-04-2018, 08:10 PM
I remember for the E9x, one could simply clear the ECU and remove any data about max boost pressure and the dealer would see no evidence of the tune having been installed. Is that still the case with these newer cars? I have heard rumors of peak boost being permanently recorded, but I imagine that is just speculation.
09-04-2018, 09:20 PM
The JB4 prevents the ECU from ever seeing true peak boost.
Car: Mercedes C43
09-10-2018, 03:58 PM
New logs:
09-10-2018, 07:58 PM
New logs:
With logs be sure to post the car details, fuel details, and mod details with them.
