Dirty3092 Dirty3092 is offline
Car: F10 535I Msport
Default F10 535i Intercooler Options ?? - 03-04-2016, 10:57 PM
Sorry if this has all ready been covered. Looking to see what my options for replacing the factory intercooler are other then Wagner. I have the JB4 installed Bms intake and Charge ***** on the way, as well as Vsrf down pipe and AFE ******** back exhaust. I'm not trying to go crazy just would like everything to be as efficient as possible.
keyap keyap is offline
Car: N55 135i
Default 03-05-2016, 07:28 AM
For my E82 I've pretty much narrowed it down to two options:-
ER or Wagner EVO 2 Competition: Can you get these for a 535i?
ATM would be the other I'd consider but I think only after the above.
It depends on what you're priority is cooling / pressure drop etc. There also be variance depending on model of car.
Default 03-05-2016, 10:11 AM
The only company I've seen is Wagner. I'm almost tempted on buying the BMS f30 intercooler and making it work.
Whateva's Avatar
Whateva Whateva is offline
Car: E90
Default 05-15-2017, 07:43 PM
Revival. Did you ever conduct this experiment?
2011 F10 535i | D Shoup Flash | PS2 | GFB DV+ | Wagner FMIC | Helix Overdrive | Sprint Booster | CDV Mod | Koni Yellows | Eibach Sports | M5 Sways | Spec 2 Clutch | SMF | UUC SSK | Custom Inlet | Custom Dynomax Exhaust
AZ-MCRacer AZ-MCRacer is offline
Car: 2013 535i (N55 F10)
Default 05-16-2017, 12:09 AM
I am running the Wagner in mine.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let, N20 TMAP.
1999 e36 M3 - Track Car
Whateva's Avatar
Car: E90
Default 05-16-2017, 07:22 AM
Was it truly a direct fit or was there slight modification needed to install?
Default 05-16-2017, 11:23 AM
No modification necessary at all, but it is a very tight fit, it took a bit of manipulating and 3 hands to get it into position. Doing it on Jack stands certainly didn't help. It took a solid 2 hours.
Whateva's Avatar
Car: E90
Default 05-16-2017, 12:35 PM
Thanks for the info I'll know what to prepare for then.
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 05-16-2017, 12:54 PM
I bought CTS Turbo fmic and made it fit in my X4 another member did it on his X3
Its the F30 FMIC just take it to a local fab shop to do their magic
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Whateva's Avatar
Car: E90
Default 05-16-2017, 01:33 PM
Is that you FSociety? Eitherway how many hours of fabrication needed and level of difficulty? Also link to the intercooler used. Thanks
neejay's Avatar
neejay neejay is offline
Car: 2011 535i M-Sport
Default 05-16-2017, 02:26 PM
Is there any point on the stock turbo? I've only got a BMS intake, ER chargepipe, and JB4.
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
Default 05-16-2017, 02:30 PM
Yes, on stock turbo your IAT's will climb a good amount each time you get on it, with the bigger intercooler it makes a big difference to keep IATs down.
Whateva's Avatar
Car: E90
Default 05-16-2017, 02:34 PM
Stock turbo and no tune maybe not, but a JB4, yah! Even if you're only requesting 13psi you're already exceeding the limits of the stock FMIC to dissipate heat quickly. I'm 19psi tapering to 13psi and I am heat soaked all over the place, its gross.
neejay's Avatar
Default 05-16-2017, 09:04 PM
hmm...I've had it all wrong then. l've been thinking it'd cause more lag, but I just re-read its description.
I REALLY want a down_pipe, but I have emissions. And I've heard a catted one isn't really worth it. Looks like I may be picking one of these intercoolers up then. Thanks guys.
Whateva's Avatar
Car: E90
Default 05-16-2017, 09:16 PM
Higher boost will compensate for time to pressurize the fmic and negate lag
neejay's Avatar
Default 05-16-2017, 09:52 PM
Ah, hence why you said "stock turbo and no tune, maybe not". Understood, thanks!
Frikiton's Avatar
Default 05-17-2017, 11:57 AM
Yes thats me, my local shop only needed 1hr total
Bought this one http://www.ctsturbo.com/cart/product...-4939-553.html
AMTF10 AMTF10 is offline
Car: F10 535i
Default 05-30-2017, 09:11 AM
Which charge pipe did you go with?
Whateva's Avatar
Car: E90
Default 05-30-2017, 11:17 AM
Lit Fam and all that good ****e. Going to bring this to the attention of my mechanic. Might have to hit you up again.Thanks brother
mike@x-ph.com mike@x-ph.com is offline
Car: 2007 e92 335
Default 06-05-2017, 06:24 PM
We offer Wagner Intercooler for the 535
https://www.x-ph.com/wagner-tuning-b...n-intercooler/
Whateva's Avatar
Car: E90
Default 07-14-2018, 04:39 AM
How much modification is need here?
ceedawg ceedawg is offline
Car: 2015 f30 335i Msport Xdrive
Default 07-16-2018, 05:58 AM
Wagner or go home!!
2015 335i Xdrive Msport FBO BM3 Stg 2 93 oct
[B]1995 Eagle talon TSi AWD Fully Built!!
Default 07-16-2018, 08:26 AM
We're in the works for a larger F series Intercooler for the people who have larger turbos.
