Default 04-22-2016, 11:36 AM
I personally don't think it's as important as you guys think it is. The oil pump is cam driven, so you would instantly know if you're not getting enough pressure.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 04-22-2016, 11:37 AM
for any non-JB4 users, I can add this to MHD in about 30 seconds
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
omarmarji's Avatar
omarmarji omarmarji is offline
Car: n54 335
Default 04-22-2016, 11:51 AM
god damnit jake lol
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
CURRENT: E82 135i (under construction)
Visit my website VaderSolution.com !
E90Convert E90Convert is offline
Car: 08 E90 335i
Default 04-22-2016, 11:57 AM
In for oil pressure. Would be great to have this on my JB Connect when tracking my car
E90 335i 6-Speed Manual
JB4 ISO G5 - BMS Pump flash - VRSF Inlets - VRSF FMIC - VRSF CP - HKS BOV - VRSF DP's - Dinan oil cooler - BMS OCC - H&R sways - Goodridge Stainless lines - ATE slotted rotors - Hawk HPS/R Pads - Apex Arc-8 17x9
Car: 2007 BMW E90 335i
Default 04-22-2016, 12:00 PM
Do it!
2013 135is DCT Carbon Black
Slawekn1 Slawekn1 is offline
Car: 2008 BMW 535xi
Default 04-22-2016, 12:05 PM
Originally Posted by ferocity02
Do it!
+1!
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 04-22-2016, 02:53 PM
+1
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 04-22-2016, 04:51 PM
+1 was going to at an external output but this would be great.
2015 FBO 550i msport(Daily)
2007 e92 MT single turbo 335i
Default 04-22-2016, 04:59 PM
We can do anything but everything has trade offs. The more data you request the slower everything else goes as the DME can only spit out so much info.
seroga1986's Avatar
Default 04-23-2016, 04:56 AM
So one more extra parameter will slow down the dme THAT much?
2008 135i Sport 6at
2013 X3 xDrive28i M-package
maddmatt02 maddmatt02 is offline
Default 04-23-2016, 08:37 AM
its not ONE more, I dont know when it all started but for arguments sake 6 cyl timing was ONE (maybe FIVE) more, ATF temp was TWO more, oil pressure would be THREE more... etc...
I am no code writing genius but seems like there could be an option in the app to enter a choice of 0/1 like with the TMAP but you are choosing whether or not you are monitoring oil pressure. Then the problem with that is I don't know if the rest of the parameters could scale back on their own to make some ?bandwidth? available for the oil temp info? or would he have to rewrite the commands and also have a "1" value input drop the requested intervals of other info?
all this aside I would like to monitor it as well
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 04-23-2016, 09:11 AM
So do it, you're really starting to make a habit of teasing things.. We haven't seen any progress in a couple months now. Not that your required to produce, but things like coolant temp and minimum WG would be good to have, you've claimed them done over a month ago but no love for us.
Honestly if it's a compensation/non copycat thing, make a new distribution platform I'll pay, most people will pay let's just figure we need to do to get things moving again.
(Sorry for the slight highjack)
livnpaintball2 livnpaintball2 is offline
Car: 135
Default 05-04-2016, 05:57 AM
Add a stand alone gauge, its not that hard.
2016 Mustang GTPP Whipple! 650rwhp, easy..
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Thor 12.9 mega motor installed!
psychosinmylobby psychosinmylobby is offline
Car: 07 e92
Default 05-04-2016, 06:54 AM
Could we have the option to turn on or off the parameters in which we request? This way we can log what we want and leave what we don't want. Maybe also limit the number of parameters we can log
135pats 135pats is offline
Default 05-04-2016, 07:40 AM
This.
If your oil pump takes a crap logging isn't going to help you. Your motor is gone unless you somehow caught it pretty much instantaneously.
Are people really dropping motors due to oil pumps failing? I'm not even sure how they'd fail in the traditional sense since it's not electrical or belt-driven.
Default 05-04-2016, 08:15 AM
Only real reason I want to monitor it is to see what it is before and after an oil cooler retrofit...
ryanm8 ryanm8 is offline
Car: 07 335I
Default 05-04-2016, 09:54 AM
It's useful to know what is going on with your engine before an issue occurs. E.g., how fast pressure builds at startup, and knowing your oil pressure while driving can tell you if you're low on oil.
Car: 08 E90 335i
Default 05-04-2016, 03:35 PM
Bump
Car: 08 E90 335i
Default 05-06-2016, 09:00 AM
Bump still interested in oil pressure
milez milez is offline
Car: E92 N54 335i
Default 04-26-2017, 08:57 AM
is this still a possibility?
JMVela's Avatar
JMVela JMVela is offline
Car: 335is
Default 04-26-2017, 05:28 PM
+1
2012 335is DCT 719.9 WHP MMPs BB turbos 93 oct pump gas + Meth. Trebila tuned.
Mrjrock85 Mrjrock85 is offline
Banned
Default 04-26-2017, 05:32 PM
Cam? The Oil pump is chain driven off the lower crank sprocket. Also doubt you'd instantly know. Signs of a failing oil pump are predictable with a gauge. I'm all for adding oil gauge
PitbullN54's Avatar
PitbullN54 PitbullN54 is offline
Meat Popsicle
Car: 08 BMW 335xi
Default 04-26-2017, 09:09 PM
+1 163k I'd like to keep an eye on it. I really don't want to add gauges.
08 BMW 335XI - CPE chargepipe - Tial BOV - Jb4 ISO - DCI - VRSF 3" Kittenless Dp's - VRSF 7" FMIC - VTT GC lite - 1 Precision driver
Baileythebimmer's Avatar
Baileythebimmer Baileythebimmer is offline
Default 04-27-2017, 12:48 AM
nvm
Car: E92 N54 335i
Default 06-20-2017, 09:23 AM
could this be added. Pretty please
