(#226)
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 10-15-2015, 06:41 AM
Just an update for the international guys looking to purchase fittings...I've upgraded my international shipping method to FedEx. It's a bit more expensive but it's much more reliable than USPS. It's also a lot quicker and provides much better tracking.
Baileythebimmer's Avatar
Baileythebimmer Baileythebimmer is offline
Default 04-17-2017, 01:07 PM
I'm guessing these are not made anymore?
08_335i 08_335i is offline
Car: 2008 335i
Default 04-18-2017, 01:13 PM
Correct.
Mrjrock85 Mrjrock85 is offline
Banned
Default 04-18-2017, 01:27 PM
Originally Posted by AUbeast86
Finally finished modeling the Coolant Manifold Block with -6AN Supply Fitting...
Excellent work. Would you consider making -8an pcv fittings? Nobody currently offers them or affordably anyways.
Lifestyler's Avatar
Lifestyler Lifestyler is offline
Default 06-28-2017, 05:19 AM
U Sold the fittings?
135i n54 FBO!
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 06-28-2017, 09:17 AM
https://www.fftec.com/item/1325/FFTE...ater_Pipe.html
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
AUbeast86's Avatar
Default 06-30-2017, 07:08 AM
Thanks. I still have 2 of these coolant manifold blocks left in stock.
erichale's Avatar
Car: 335i coupe
Default 06-30-2017, 09:52 AM
Sorry Jason, I thought you sold out of your fittings already.
AUbeast86's Avatar
Default 06-30-2017, 09:55 AM
No worries. Fittings, yes. These 2 coolant blocks are all that's left.
erichale's Avatar
Car: 335i coupe
Default 06-30-2017, 09:59 AM
Glad i got mine from you when i did
