(#9726)
Default 09-09-2015, 04:13 PM
Originally Posted by Rushan
Running the new firmware for the past 2 days and seems all smooth, but today at once I got odd reduce engine error while spirit driving 30FC exhaust fume turbo turbo charger, density. Never had this error before or any main reduce power errors before, I deleted the error and car running perfect not sure if it's related to the firmware or it's just odd error, thought to share in case others had the same.
I'd presume that's a flash issue. But as always, log it to evaluate.
trohde78's Avatar
trohde78 trohde78 is offline
Car: 2009 335i Coupe 6MT
Default 09-10-2015, 07:27 AM
I updated to the G5_ISO_31 last Thursday, and I like the improvements overall. I'm still getting used to the linear throttle, but the power delivery is much smoother and more predictable now. :-)
The one thing I don't like is that when I come off moderate throttle there is a loud metallic "clank". I'd say it sounds like the waste gates slamming shut, but I would guess they are more likely slamming open(?). Is there a setting to minimize this?
Default 09-10-2015, 09:54 AM
Moved log posts to the support area.
Default 09-10-2015, 09:55 AM
You'd need to record it in a log to evaluate where the WG is moving when you hear it. Uncheck record WOT only to record things like that.
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 09-10-2015, 11:31 AM
anything we should be changing before switching from 31 to 31.4 to help avoid overboost issues?
Stucks Stucks is offline
Default 09-10-2015, 12:05 PM
+1
Current: 2008 e92 335i coupe.
Default 09-10-2015, 01:16 PM
spool feels stronger but hard to tell, my car's been pissed at the high heat lately so it's been reluctant to break traction in 2nd
Default 09-10-2015, 01:19 PM
Nope. If you have an issue post a log in the support area.
hokejka hokejka is offline
Car: 135i 6mt
Default 09-10-2015, 04:45 PM
finally got my g5 iso installed, will update to new hex tomorrow. still need to clip diodes? or is it only on the original g5 batches?
nyt nyt is offline
Car: 335ix
Default 09-10-2015, 04:50 PM
no diode clipping on g5 iso
Car: 135i 6mt
Default 09-10-2015, 07:54 PM
thanks dude. cable should be here tom. can't wait to upload 31.4
cmg5461 cmg5461 is offline
Car: 2008 E90 335xi 6MT
Default 09-10-2015, 08:46 PM
Can you please add stealth gauges on > 50% boost instead of pedal?
E90 335xi 6MT - Deep Green
GermanBoy's Avatar
GermanBoy GermanBoy is offline
Car: BMW 335i e92
Default 09-11-2015, 12:45 AM
boost bypass didnīt work at my car.
set 3rd gear limit to 12psi. push the volume down button but nothing happend, boost stays low.
what did i wrong?
mrx168 mrx168 is offline
Car: BMW E90 335i
Default 09-11-2015, 01:36 AM
With the new 31.x FWs, is an incorrect menu 12 setting the main cause of jerky boost/acceleration during low/moderate throttle?
2007 E90 BMW 335i |JB4|AR ***|ER chargepipe + Forge DVs|BMS dual cone intake|
1993 R33 Nissan Skyline GTS-T |SAFC-2|Apexi POD|Boost Tee|FMIC|3" TBE|
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 09-11-2015, 08:33 AM
Upgraded to 31.4 this morning and set 11 to 5000RPM. Boy, what a freaking difference. Probably a little too sensitive but is fun. I may keep it here for now but need to back it down for winter driving.
I only drive it once so far. I noticed the can flap (set to open), openedwhen I started the car, then closed for a minute, then reopened and stayed open. I'll monitor to see if that happens again as it was never a past issue. No waste gate rattle issues, though this has not been a problem on my car.
335xiboost's Avatar
335xiboost 335xiboost is offline
Car: 2008 335xi jb+ VSRF ******* DP DCI cabin filter delete
Default 09-11-2015, 08:39 AM
If I just purchased a JB4 a week ago would any of these updates be on there?
2014 M5 1 of 577 6spd awaiting MORE BOOST
07 Cayman 5sp
08 Cayman S 6spd
02 996 TT 6spd more boossttt
04 Gallardo gated 6spd
Default 09-11-2015, 08:50 AM
Might have v31. New systems normally ship with firmware only after its been out a few weeks and determined to be fully stable.
what did i wrong?
It's up now since down is used for anti-lag.
GermanBoy's Avatar
Car: BMW 335i e92
Default 09-11-2015, 09:19 AM
Thanks Terry, will try it tomorrow.
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 09-11-2015, 09:40 AM
Ah yes I just noticed this today and was wondering why 20psi felt the same as 16psi...very sneaky...I guess my radio will be yelling at me to slow down now instead of my wife !!
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Default 09-11-2015, 09:43 AM
Get an anti-lag kit on there and she will really be yelling!
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 09-11-2015, 11:20 AM
When will the anti-lag kit be available to purchase?
537.75HP 540.63TQ
Default 09-11-2015, 11:35 AM
There is a separate thread re: anti-lag testing you can check in on. No date is set.
Default 09-11-2015, 12:09 PM
Thanks. Ive been following that thread quite closely.
537.75HP 540.63TQ
newbmwguy newbmwguy is offline
Car: e92
Default 09-11-2015, 12:12 PM
So with the new file the tables that were previously multiplied by 2 still are correct? If that's the case what are people's inputs the number shown on the tach or the number after multiplication?
Copyright Đ 2007 - 2020, N54tech.com
