(#3826)
marconi118 marconi118 is offline
Default 01-26-2012, 09:37 AM
Terry,
Could you add in a future release of JB4 firmware a setting that permits to close completely (100% DC) the waste gates at idle or lift-off throttle?
To do something comparable as the 1M with the M button engaged.
This could enhance the spool-up time of turbo and reduce lag for cars still affected by this (MSD80)
I monitored the total WG DC% with a led in parallel to the solenoids, at idle or lift-off the DC% is quite low (WG open) in my car on map1 JB4
Default 01-26-2012, 10:10 AM
Originally Posted by marconi118
Terry,
It won't reduce lag or spool up time, but in some cars will reduce wastegate rattle when letting off the gas. We actually have this in the BETA firmware for testing. Email me if you want to try it.
MathR601's Avatar
MathR601 MathR601 is offline
Default 01-26-2012, 02:39 PM
Any way that the values learned by the map 5 be saved (as a baseline) when switching to another map?
Same thing for map 3.
That way, when switching back to map5/3, it would not have to learn from scratch.
Just asking
BES335xi's Avatar
BES335xi BES335xi is offline
FBO+ N54xi
Car: '07 E90-335xi
Default 01-27-2012, 01:07 PM
For some reason Menu 1 stays on 3......which is i beleive Autoclear....I want it off, i bring it all the way to 0, bring the Menu to 0 and hit the volume down, but it wont save.
Any ideas? It's irritating the 'ish outta me haha...I'm going to go play with it some more maybe i gotta set my car on Menu 5 to 335i metric or whatever, idk...will try. But if anyone else knows anything...Please do tell me. ty
JB4+usb | BMS OCC | P3 Vent Boost Gauge v2 | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Stett Tial BOV W/Meth Charge Pipe [soon] | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumpers | Cyba Red Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | Matte Black Finishing Rods | 30% Tints | Sports & Winter package | Black Leather Int. | Aluminium Trim | & few extras not listed. Car: '07 E90 335xi vrrooom lol'
SHATX's Avatar
SHATX SHATX is offline
Car: 07 E90 335i
Default 01-27-2012, 01:08 PM
Read Page 1 - you have to move to "4" to disable autoclear.
I eat M3's and Baby Chickens for Breakfast. How bout you?
BES335xi's Avatar
FBO+ N54xi
Car: '07 E90-335xi
Default 01-27-2012, 01:10 PM
lol Grrr...idk how i keep missing things, i gotta slow down on my reading. Thanks man.
iFRANChISe iFRANChISe is offline
Car: 08 e90 335i
Default 01-28-2012, 08:08 PM
Nvm figured it out.
Default 01-30-2012, 04:54 AM
Why shouldn't it reduce the lag?
In the 1M pressing the M button the WG is closed at idle and low load to spin the turbo and reducing the lag. Why this would not apply to the 335/135?
Default 01-30-2012, 10:49 AM
We already close the wastegates when in motion and pushing the gas in more than 0%. The only thing we don't do normally is close them when letting off the gas.
Reiss91 Reiss91 is offline
Default 01-30-2012, 03:43 PM
Terry,
Besides noise and unnecessary strain on the turbo. what are the downsides to keeping the waste gates closed at idle?
Just curious. Personally I wouldnt want that.
Default 01-31-2012, 02:25 AM
Yes I noticed this by monitoring the DC % of the JB4, as soon as the gas is pushed more than 0% the DC gores briefly to 100% to close the WG as quick as possible. But I think anticipating it, by closing them always and opening them only when desired boost is reached (PID) could reduce lag a bit.
This is indeed a good solution to rattle, many think to avoid rattle by opening the WG so far that the flapper don't touch any more the seat, but close it to avoid movement (and rattle) of the flapper is even better!
Default 01-31-2012, 02:29 AM
Originally Posted by Reiss91
Terry,
Just curious. Personally I wouldn't want that.
BMW is doing it on the 1M with M button engaged and maybe on the early 2007 335i program (pre 29.2)
All other boost actuated WG turbos have the WG closed at idle!!! (it needs boost to open)
Except little more wear, and less MPG efficiency there shouldn't be any inconvenience???
Default 01-31-2012, 10:09 AM
Terry,
Likely minimal downsides. The current test firmware closes them when letting off the gas, but then after ~4 seconds lets them go back to their natural state. Seems to work as the rattle comes up only when letting off the gas.
spectacula spectacula is offline
Default 02-01-2012, 06:20 AM
Is it possible to have the car make a sound when the shift lights come on? i can never see my shift lights
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 02-01-2012, 07:36 AM
That would be cool. If Terry wants to look into it I've seen a audio test menu in INPA that basically plays a generic tone to test each speaker.
E36graduate E36graduate is offline
Car: 335xi Sport
Default 02-03-2012, 07:32 AM
at 105K miles and 30% of those miles meth/dci/93oct/jb4ish i am starting to hear a little bit of wategate rattle from inside the car. It doesn't help that I have the cowling removed!
The noise that i hear is a faint rattle (like valve tap) at very low rpm's.....if i am in any gear and not taching to high and let off gas pedal i can hear that valve tapping noise for a split second or two....if i give the gas ever so slightly and let off ever so slightly that little tapping noise comes back.....weird. Almost like that pinging sound feel on a car (not bmw) with low octaine gas.
I was at first worried that a valve was loose or something, but the car runds awesome, no codes and recent oil change didn't change noise.
Default 02-03-2012, 11:14 AM
Would need access to that to scan the CAN commands for the tones.
2008_335i_coupe's Avatar
2008_335i_coupe 2008_335i_coupe is offline
Car: 2008 BMW 335i coupe
Default 02-04-2012, 08:02 PM
Terry,
Is it possible to add a feature of always showing the current gear on the dash
2008 Alpine White 335i E92, 6AT, Saddle Brown Leather, NAV, CF roundels, M3 steering wheel with M3 paddle shifters, Aero lip, painted kidneys (white / black), painted lower grilles (black), debadged, M3 spoiler, ST V1 coilovers, 19" CSL wheels.
, JB4 ISO 5, BMS DCI, AA Intercooler, Coolingmist methanol kit, Forge Diverter Valves, BMS 3", CPE Charge-pipe, BMS Oil T-state bypass, RB PCV
Default 02-05-2012, 10:58 AM
Originally Posted by 2008_335i_coupe
Terry,
Doesn't it already do that? The only thing we could do would be to show gear on the oil or fuel gauge, etc.
steve.kodra steve.kodra is offline
IXLR8
Car: 335xi
Default 02-05-2012, 01:59 PM
Terry,
You must be referring to when the car is in normal auto mode, because the wife's car shows up when in manual mode. For me, mine is a MT and I always know what gear I'm in!
moparacker moparacker is offline
Car: '07 E92 335iA
Default 02-05-2012, 03:12 PM
Terry, thanks for the added info in the first post. Cleared up a few questions about some features.
Trickcruiser's Avatar
Default 02-06-2012, 03:06 PM
Just checking in to see how the aggressive map testing is coming and if there are any plans for a more aggressive meth map in the works.
Thanks for all the hard work T!
Default 02-06-2012, 03:20 PM
Non-meth stuff is coming along nicely. With meth performance is really just a function of octane, meth quality, and your meth additive setting. So although the new firmware will help clean up the fueling end a bit down low performance is going to be more or less be unchanged.
BES335xi's Avatar
FBO+ N54xi
Car: '07 E90-335xi
Default 02-06-2012, 09:25 PM
Question, Menu 8 stays on 2600 on my jb4, is that normal/default or i touched it n forgot...thx
IXLR8
Car: 335xi
Default 02-06-2012, 09:40 PM
I have to chuckle at the map8. What are you gonna do when a hot chic pulls up to you in her svt focus and wants to put it to you, and she does...be strong...be ready. Be BMW! Need I say more? No one underestimates a BMW... No one! Anyone with me... Hear me?...
