(#151)
Default 06-20-2019, 06:52 PM
Hmm that code is something with a fuel injector circuit. Read via JB4 or an external tool?
Stevelkinevil Stevelkinevil is offline
Car: Alfa Romeo Giulia
Default 06-20-2019, 06:54 PM
JB4
Default 06-20-2019, 08:13 PM
For kicks try using another reading tool so we're sure it's being read properly.
Default 06-20-2019, 08:53 PM
tried it with my ELM and Torque app. But no codes, Likely because I had to clear it with the JB4 to get it running right and get home. Ill keep a close eye on it, have not seen anyone have this issue more than once that I am aware of. The engine temp concerns me though.
Default 06-20-2019, 09:40 PM
It might just be something you have to dealer the car for if a factory part is faulty... Let's confirm the code first and go from there.
KickingandStreaming KickingandStreaming is offline
Car: Alfa Romeo Stelvio Ti Lusso
Default 07-05-2019, 10:16 PM
Originally Posted by Stevelkinevil
So it finally happened to me today, Ive read other post's here and on the Giulia forum regarding getting a sudden check engine light along with the service electronic throttle and engine start/stop unavailable messages. The car lost power (guessing it went into limp mode?) could barely get it over and off the highway it had less power than a Prius with a dead battery. Was able to clear the code and it did not come back the rest of the way home. However also noticed the engine temp went up one click over 1/2 which never happened before. Anyone able to get any info on this issue or had it more than once
You aren't alone. I had that happen in my Stelvio about three weeks ago when hunting down a Cayenne. Unlike yours, no fault codes thrown- just the mentioned warnings and limp-home mode. After a 15 minute engine shutdown, it went away and oddly no codes thrown.
No further issues aside from the hotter intake temps throwing off the performance. Is there any fix or workaround for this or for the higher throttle temps?
Default 07-06-2019, 10:55 AM
Intercooler development will need to take place to improve intake temperatures, it's not something we're working on yet but if no one else steps up to the plate we'll direct more focus to it.
Default 07-08-2019, 10:05 AM
I think a methanol kit would be more efficient IMO.
Default 07-09-2019, 03:11 PM
Yes that is also worth looking in to.
Default 07-09-2019, 04:53 PM
I'll see what I can do. The intercooler is not that simple because it's A2L.
