RVA_N55_Fan RVA_N55_Fan is online now
Car: 2014 435i
Default Log review. Installed PS2 and Spool-FX150 HPFP - 10-11-2021, 01:40 PM
100oct.
map 7 feels good. Seems like she wants more. How do the logs look? Any adjustments?
Ran a quick map 6. Threw a tmap code. Also boosted much higher than boost fail safe. Isn't boost fail safe to prevent over boost? Thoughts?
2016 435i MPPK Sport Manual 6 w BMS JB4 EWG BEF-PS2-Race, FF, ODBII, Pure Stage 2, Spool-FX150 HPFP, BMS Cold Air Intake, BMS FMIC, BMS Clutch Stop, BMS Wheel Spacers, BMS BOV, 3.5 TMAP, BMS Diff Bracket, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMW M Package, BMW SSK, BMW Track Package
Default 10-12-2021, 09:44 AM
No need to post the pictures of the settings as they are all captured in the log.
You need to review the large turbo setup thread, adjust your settings accordingly, and then take another log.
N55 Large Turbo Tuning Info - N54Tech.com - International Turbo Racing Discussion
Also make sure the setting for the 3.5bar TMAP is only used in the flash OR the JB4 settings and not both.
Car: 2014 435i
Default 10-12-2021, 11:55 AM
I changed my user setting to large turbo defaults. Also, I have the jb4 set for 3.5. I don't think I have it set for flash unless you see something I don't. See attached.
In the mean time I'll run some logs in map 6.
Thank you!
Car: 2014 435i
Default 10-13-2021, 12:23 PM
Log for map 6 for review please and thank you.
One pull no code....the second pull coded almost immediately
Default 10-14-2021, 09:47 AM
I can't see it in those settings, are you still running the BMS flash? Also, did your car require the adapter to run the 3.5bar, it could be an actual short as well.
Car: Evo VIII
Default 10-14-2021, 09:48 AM
Try changing over to map 5 and drive around for a bit. Then upload another log and we will see how it looks. Please write out what codes you are getting also.
Car: 2014 435i
Default 10-14-2021, 09:55 AM
New map 6 pulls. 5 gallons e85. Bef - ps2-race
Car: 2014 435i
Ok. I can try that as well
Car: 2014 435i
Default 10-14-2021, 11:03 AM
Yes the bms ps2-race flash. No adapter was required.
Car: 2014 435i
Default Yesterday, 12:32 PM
Map 5 w codes 121001, 120408
Thoughts?
Default Today, 11:18 AM
You're running too lean because your trims are in open loop. You're also overboosting because FF is too high and you have learning disabled.
Car: 2014 435i
Default Today, 11:29 AM
Thanks Steve. How do I fix the lean? Also, I'll check my ff learning and enable.
Default Today, 11:34 AM
You might want to try resetting your adaptions.
Car: 2014 435i
Default Today, 11:43 AM
update. I replaced my plugs...should have done that before. ive gotten this code a couple times now...
1F0526 DME, internal error: monitoring torque comparison
Car: 2014 435i
Default Today, 11:51 AM
Reset all my user settings. I only have bc controls disabled and BEF enabled for my f32.
Car: 2014 435i
Default Today, 02:03 PM
Also reflashed to JB4_F_EWG_PS2_RACE_13 to see if that helps w the DME code above.
RVA_N55_Fan
