laynevans laynevans is offline
Car: 2020 Stinger
Default P0106 error, just added fuel wires - 10-13-2021, 09:42 PM
I've just had the check engine light/limp mode/code P0106 come up so looking for any help it. I've found a site that says it could be intake valve control solenoid circuit low, fuel rail pressure too high, cold start injector 1 malfunction, ign coil A prim/sec circuit malfunciton.
I've just recently added the fuel wires to my JB setup and the check engine/error code came up after the first time I was able to give it close to WOT.
I've turned the car off, disconnected ECU, turned on again and it's gone. I've turned ON "Disable Fuel Control" so if it is anything to do with the fuel wires it doesn't return. I have a track event on tonight.
Default 10-14-2021, 08:59 AM
JB4 log?
Car: 2020 Stinger
Default 10-14-2021, 04:42 PM
I didn't getting any logs as I was just driving around in regular sh*t traffic. Had to fully disconnect the fuel wires and code hasn't returned. 1min 10sec around Wanneroo if anyone is interested. Some of the times faster than me are track prepped cars, no interior etc.
I'm using the short adapter so I didn't even have to posi-tap into original wires. I've positapped the red wire on the adapter? It's the only coloured wire so figure that must be the one to tap into? Any difference in AUS/RHD? Short wire to the RHS (when standing at front of car looking at engine bay)
Will try to get some logs today or tomorrow but racing again tomorrow so can't afford to have it go into limp mode again.
