turboAWD turboAWD is offline
Car: Stinger GT
Default BMS Transmission oil cooler - 08-11-2021, 06:31 PM
Great to see!
One question: it looks like it mounts on the rad, not near the intercooler? So I guess if I were to install it, and later switch to BMS intercooler, wouldn't be a problem? How hard is the install? How likely to dump transmission fluid everywhere?
Also - k8stingerstore has an external "oil cooler" for the Stinger that also seems to mount on the rad - it seems like it's either / or - doesn't seem like there's room for both? I'm interested in doing both, sort of.
If I had to pick (doing some HDPE in NorCal), which one would be more helpful?
Default 08-11-2021, 08:29 PM
It fits with the BMS intercooler, no idea on the external oil cooler. But a trans cooler is more important than an oil cooler for these IMHO so if you need to pick one....
Payam is working on an install guide, it's not too bad.
Default 08-12-2021, 10:39 AM
It mounts where the stock trans oil cooler sits.
Stinger_salvage Stinger_salvage is offline
Car: 2018 kia stinger gt2
Default 08-14-2021, 10:47 AM
It's a plug and play install with the provided connectors right? Also what about the fluid? It's pretty expensive so should we catch it all and reuse it? Also the added capacity of the cooler will require a trans fluid top off anyways right? Sorry about all the questions I placed my order yesterday.
Default 08-14-2021, 11:35 AM
Yes you'll need another qt of fluid give or take, capture and reuse existing fluid if practical for you.
Avant Avant is offline
Car: G70
Default 08-15-2021, 01:50 PM
Terry, you guys using the Hyundai specific ATF SP-IV-RR or have you found another ATF? Looks like Valvoline (ATF) Full Synthetic specs match.
I need to order a quart or two for the install.
Default 08-16-2021, 09:09 AM
Barely anything spills out when doing the swap, but yes we suggest getting 1qt from the dealer to top it off. It will not need any more than that.
Car: G70
Default 08-16-2021, 10:39 AM
Sounds good. I might do a flush while I am at it. The Hyundai ATF isn't cheap though haha.
Car: 2020 Genesis G70
Default 08-14-2021, 11:32 AM
Will this fit the G70?
Default 08-14-2021, 11:34 AM
We think so. Sent one out to a G70 tester last week so we'll find out soon enough.
Default 08-21-2021, 03:16 PM
Just got my kit today. Is there an install guide somewhere?
Default 08-23-2021, 12:25 PM
Will be up later today! I'll post the link up here.
djerickd djerickd is offline
Car: 2019 GTS
Default 08-25-2021, 11:41 PM
Any progress on the install guide?
Car: G70
Default 08-23-2021, 11:28 AM
Pretty amazing mod. Installed mine last week and did some before and after testing with it.
Two logs attached. Before the BMS trans cooler I would go above 200 degrees pretty quickly after about 5-6 hard pulls back to back. With the cooler installed the highest I have seen is 183 and that was after 8-9 pulls!
Default 08-23-2021, 02:29 PM
Um it looks like it won't fit the Mish kit either... Bummer.
Car: G70
Default 08-23-2021, 03:45 PM
Id be curious. I installed mine above the BMS intercooler. Not sure how high the Mish intercooler sits but there still might be room for it. Then the lines drop below/behind the intercooler and back up.
Default 08-23-2021, 03:56 PM
It's about 1.5 inches too high. However looks like I can bend the top brackets and make it fit between the Mish and the crash bar. Still a flawed design however.
Default 08-24-2021, 09:43 AM
It's supposed to fit in between the intercooler and condenser, just like stock.
Might need to remove the intercooler to install the cooler.
Default 08-24-2021, 10:35 AM
There is not enough room between the Mish intercooler and the condenser. Also I don't think the Mish can be moved out more because if it's tabs.
G70in21 G70in21 is offline
Car: 2022 G70
Default 08-24-2021, 02:38 PM
What are the physical dimensions of the new cooler, im playing with my new 22 g70 and wanted to do some planning.
On another note, if someone wanted to buy an off the shelf Mish cooler, would burger sell their billet adapter alone?
'22 G70 3.3T Havanna Red
Currently...stock
Default 08-24-2021, 07:07 PM
Dimensions are 13"x8"x2" IIRC.
We're having brackets made to fit the G70 right now. The option will be on the website sometime next week.
We only sell the kits as full, sorry.
Car: 2019 GTS
Default 08-24-2021, 11:35 PM
was the install guide ready?
Car: 2022 G70
Default 08-25-2021, 02:17 AM
Thanks! Looking forward to the brackets, are you testing on a 22 or earlier? Not sure if there is much difference in that area between the two.
Currently...stock
Default 08-25-2021, 12:22 PM
It will be made off the 2021 which we hope would be the same as 2022.
This is what our G70 Tester had to do at the moment:
Car: 2022 G70
Default 08-26-2021, 09:33 AM
Awesome.
I haven't taken the front cowl off the car yet but from what I can see they look very similar.
Currently...stock
