11-30-2020, 02:27 PM
Might just be normal false alarm codes from having boost cranked up during cruise. Log?
Car: BMW 335Xi F30 N55 2013
Error code -
12-02-2020, 08:32 PM
Hi Terry,
I have not toyed with any setting it is as it has been for a long time.
Here are two log, normal no hard pulls.
12-03-2020, 01:48 PM
Seems fine. How does it look full throttle?
Which BEF is loaded exactly?
Error code -
12-03-2020, 11:00 PM
Will let you know soon, I just had to order master chip 2 days ago. I tried firmware update, kept timing out, running without firmware and is quite horrible.
Car: M2
12-11-2020, 09:31 PM
Hi Terry,
Which BEF map should I use for M2 N55 with pure turbo stage 2? I have a Dorch stage 2 HPFP. FBO and will be using JB4 to control PI meth.
12-12-2020, 11:14 AM
What fuel do you plan to use? For pump gas EWG_RACE_PS2
Car: 2014 435i
JB4_F_EWG_PUMP_10e or JB4_F_EWG_PUMP_LEANER_AFR_10 -
12-13-2020, 04:57 PM
Just ordered the MHD flasher. the only question i have is when I flash with the JB4 BEF which of these two flashes do I use? not sure i know enough to determine the difference between 10e and leaner_aft.
FBO, 93 pump gas
thanks for the assist.
2016 435i MPPK Sport Manual 6 w BMS JB4 - EWG 3.0 + MHD JB4 BEF, FF Wires, JB4 ODBII connector, BMS Cold Air Intake, BMS FMIC, BMS Clutch Stop, BMW Wheel Spacers, BMW Short Shift Kit, H&R Sport Springs, ER DP, AA CP, upgraded 335is clutch kit, BMW Track and Aerodynamics body kits
Car: 2014 335i
12-13-2020, 06:58 PM
Use the pump, don’t use the leaner afr unless diagnosing or instructed too.
Home to the worlds slowest 335i  !
2014 335i xDrive | ZF8HP | JB4, MHD w/ BMS E85 BEF, Evolution Racewerks Chargepipe, IC, and DP,
AFE Intake, MPE, and a lot of time on the garage floor!
Car: M2
12-13-2020, 10:46 PM
Thanks Terry for the quick reply. Yes I am sticking to pump gas, will use the EWG_Race_PS2 and do some dyno logs to be safe.
12-18-2020, 10:57 PM
last post:
"Will let you know soon, I just had to order master chip 2 days ago. I tried firmware update, kept timing out, running without firmware and is quite horrible."
Terry it has been a bit, got master chip and installed, but was not the problem.
Team at Burger Tuning were great and sent me out bluetooth kit, installed and finally was able to update firmware.
I am using BEF JB4_PWG3_PUMP_1.bin
I am attaching chart of a shot hard pull for you review.
Car: 2014 335i
12-18-2020, 11:03 PM
I’m not exactly terry, but what I can tell you is that you don’t have the back end flash option enabled. Go into options (Future Use D) and select bit 6 to tell the jb4 you have a backend flash.
Car: M2
12-23-2020, 10:01 PM
Hi Terry,
I tried to flash BEF EWG_Race_PS2 but it doesn’t suit my M2 and thus MHD flasher doesn’t allow me to flash this file. I can only flash M2_Race file. Also under options i can only click dorch stage 1 hpfp and not dorch stage 2 hpfp. Can you help advise asap. Thank you.
Car: m1235 2013 f20 n55
01-09-2021, 12:15 PM
Hi
What are the differences between timing (main) and timing (main) 2 and 3
if i add 2 degrees on main map need add 2 degrees on other maps ?
 m135 2013 at-8 PWG STG2 PureTurbo DP-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
Thread Tools |
Display Modes |
