Bimmerlife35 Bimmerlife35 is offline
Car: 2007 BMW 335i
Exclamation Engine stuttering when Idling, driving normal, and when WOT - 03-25-2018, 11:26 PM
Okay so just yesterday my car has started to stutter, mods I have are jb4 with mhd backend, dpís, dci, and full straight pipe. it Doesnít matter if Iím idling, driving normal, or wide-open throttle there always this stutter that happens id say maybe 2-3 times a minute, itís like it looses power, or something with fuel delivery?, i donít really now how to explain it well, I canít post a video on YouTube if that would help anyone. I know the injector on cylinder 1 is leaking but it has been for 4 months so I donít see that being the problem. Iíve checked spark plugs, coils are good, no codes what so ever besides the DME telling me it had detected Dpís, and Iíve cleaned the vanos selonoids. I canít do any data logging because my tablet for some reason never wants to connect to the jb4 rev 3 kit but from a log I did 2 weeks ago said that my LPFP got down to 51 for about 2 seconds, could that be it? Could it be o2 sensors? Intake carbon build up?
Please let me know if anyone has had this happen before or knows what I can fix! This is driving me nuts
2007 BMW 335i
DCI
Custom exhaust (Full Straight!)
Charge pipe w/ Tial BOV
JB4 Tune
Backend MHD
E30-E40 Mix when itís not raining
skirmozas's Avatar
skirmozas skirmozas is offline
Car: 2010 N54 BMW 135i
Default 03-26-2018, 11:52 AM
Well, I think plenty of people on these forums had similar problems, so did I. But I'm just not sure what exactly fixed it or what the actual combination of things that did was. If we're talking about the same problem, which I would describe a hiccup at idle (barely noticeable dive in RPM's and hiccup only audible from outside, like the car skipped a single beat), then that's what I did and it got better. I think it idles smoother, but it's hard to tell if I just got used to it:
1. Backend flashed the car with BMS pump flash. It felt like it helped a little, but I could still hear the hiccups on occasions.
2. Replaced VC, spark plugs and injectors. VC was cracked so the spark plugs and injectors were deep in oil, didn't seem to affect the coils though. I did them all at the same time, it was convenient. Now after this, considering my needs for perfection are pretty humble, I would say the car started idling properly. I could hear something very similar to it on cold starts only, maybe once or twice in the first 30 seconds after the car has been started. Not very noticeable or very audible later.
3. Walnut blasted intake valves some time later. When inside, one can think that the car is not even on when you're coasting in neutral or just standing at the traffic light. Still the same cold start I would say. Nonetheless, I consider walnut blast to be the 2nd best "mod" for power gains in cheap and common hardware changes, right after the dpipes. The car runs so much smoother on WOT and seems predictably and extensively powerful. And of course, the sound of air filters sucking so much more air than they used to before. And this is just the point, where you realize that you really need a proper intercooler and inlets.
Back to the topic, I don't have access to E85, which probably makes our cases slightly different. E85 could be somewhat related to your problem. Other than that, we have very similar mods (except for straight exhaust), which makes this an interesting case to me too
Good luck troubleshooting the problem, hope you can find a fix for it.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 03-26-2018, 12:37 PM
Grab a log of the issue when you can. You can get a full log of regular driving by going to Logging - X Axis - (uncheck) Heavy Throttle Only. Not sure where the option is on the mobile version but should be similar. Tough to diagnose otherwise. Could be injector, fuel pump, O2 sensors, tuning, etc.
TDLI TDLI is offline
Car: E93
Default 03-27-2018, 11:02 PM
Great advice!
To OP, I would start by trying to clean your TMAP and MAF sensors. I also had this problem and ultimately changed spark plugs really helped. Could also be your LPHP sensor.
GEOS07335i GEOS07335i is offline
Car: 2008 BMW 335i E93 N54
Default 03-28-2018, 05:58 PM
Do you have any misfire issues? Or just rough idle. How many miles on your car and when was the last time you changed plugs and coils? Had similar issues. I swapped injectors, plugs coils ultimately it was my precat o2 sensors that went bad. There only good for 100k so it's a maintenance item for sure. You could also try cleaning your vanos solenoids quick 30 minute job and it's supposed to help with rough idle. I will admit it didnt help much in my case but it did quite down the "lifter tick".
