(#526)
Car: q50
Default 02-25-2021, 10:33 AM
Comments about vacuum are only applicable when installing post throttle body. And losing a small mount in the line between the nozzles and solenoid is negligible. Its a high pressure pump that reacts plenty quick enough to keep the car from detonating.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Sleeper2017RSAWD Sleeper2017RSAWD is offline
Car: 2017 Infiniti Q50 AWD RS
Default 02-28-2021, 07:50 PM
You got it.
Well, here we go. WMI kit ordered.
2017 Q50 RS AWD; JB4 - BT/FW/EWG; 93 Pump Gas; HKS ***s
jrobohm's Avatar
jrobohm jrobohm is offline
Default 02-28-2021, 08:19 PM
Welcome to the party
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ DO7s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS Catted FDP (Pending)
  • AMS CAI
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
HoHo HoHo is offline
Car: Q50
Default 03-04-2021, 02:09 PM
Log review please? Map 6 w wmi.
2018 Q50 silver sport RWD
Jb4 w fuel wires
Wmi
Megan ldp
Default 05-02-2021, 10:00 AM
I have this kit and planning to install within a week or so. I already purchase some yellow plumbers tape (used for gas lines I believe), but also read somewhere to not use tape at all because the potential to clog injectors (was on a nitrous forum). So paste? What's the best product to use?
jrobohm's Avatar
Default 05-02-2021, 11:16 AM
Not sure what you are planning to use tape on? To assemble the copper fittings and the Meth nozzles, I would suggest a very small amount of Teflon paste (very small) if you are worried about fitting leaks.
  • BMS WMI w/ DO7s
  • AMS CAI
Default 05-02-2021, 11:30 AM
Was planning to use tape on basically everything with threads to prevent a leak. Not needed?
jrobohm's Avatar
Default 05-03-2021, 07:07 AM
A very small amount of Teflon paste is all I use. Just want to make sure not to have any visible when everything is tightened up - if it is absolutely needed could be up for debate.
  • BMS WMI w/ DO7s
  • AMS CAI
Thumbs up 05-03-2021, 05:09 PM
Got it, thanks
