(#226)
reyes104 reyes104 is offline
Car: q50
Default Re-log on map 2 - 05-27-2020, 09:58 AM
Hi Terry,
Thank you so much for the feedback ! As requested, Here is my log on map 2
Much appreciated for the help !
settings:
duty bias all 50
pid 20
auto shift 60
ff 60
mods:
jb4
map2
91oct
lip
muffler delete
Default 05-27-2020, 10:51 AM
Looks good to me on map2, I'd stick with that.
Car: q50
Default 05-27-2020, 12:18 PM
Will do ! Thanks again for the help !
V@pors's Avatar
V@pors V@pors is offline
Car: 2017 Infiniti Q60 RS AWD
Default 05-29-2020, 05:54 PM
Hoping I just got lost in the shuffle. Anyone able to look at my logs from post #204? thank you.
2017 Q60 RS400 AWD Midnight Black/Monaco Red
AMS Cold Air Intake | AMS Heat Exchanger | AMS Coolant Expansion Tank
BMS JB4 w/Fuel & EWG Wires | Z1/HKS BOV kit | Fast Intentions catted FDP's | HKS Legamax CBE | Mishimoto OCC
Z1 2-piece rotors | HRE FF04 10x20" front 11x20" rear rims | Pirelli PZero PZ4 tires 265/35/20 x 305/30/20
Blackview DR750s-2CH camera system| Blackview Power Magic Pro
Default 05-29-2020, 07:04 PM
Originally Posted by V@pors
Just installed the EWG wires on my Q60 RS AWD. Would appreciate any input on these logs:
I have settings set to defaults suggested on 1st page, Fuel Wires enabled, and Bit 6 turned on (RS)
Running 91 octane, 88 F today, 4,500 ft elevation
Run 1: Map 0
Run 2: Map 1
Thanks in advance!
Boost seems lower than it should be. Do another log or two to evaluate.
Jdm010697 Jdm010697 is offline
Car: 2018 q50 luxe RWD
Default 2018 Q50 luxe RWD EWG HELP - 05-29-2020, 07:46 PM
i recently installed the ewg connectors. i have already had the jb4 w/ fuel wires for a while now with no issues. however once i added the EWG connectors the car is pulling alot of timing during the pull. below i will post a 4th gear log that had terrible timing and a 3rd gear pull that had good timing. (both on same ewg setting) not sure if i should adjust any setting as they are how the forum said to start them
mods: ldp
muffler/res delete
heat X
Dgvr6's Avatar
Dgvr6 Dgvr6 is offline
Car: 2016 S6 and 2018 q50
Default 05-29-2020, 08:42 PM
Terry, can you take a look at these logs.
This is on e20, FF set at 60.
Dgvr6's Avatar
Default Yesterday, 04:32 PM
mods: ldp
muffler/res delete
heat X
Looks like youíre running two different maps on both logs.
Was that intentional? I can tell you that personally, the car Iím working on doesnít like all that boost on 93 only
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default Yesterday, 04:58 PM
How did you calculate your e20 blend? My car also pulls timing with too much E
12.64 @114mph
0-60 4.46
V@pors's Avatar
Default Yesterday, 07:45 PM
Thank you. Will do.
V@pors's Avatar
Default Yesterday, 09:07 PM
I did 2 more logs on Map 1
Duty Bias = 50 (all)
PID = 20
FF = 60
Auto Shift = 60
91 octane
Thanks again
