lanii00's Avatar
lanii00 lanii00 is offline
Car: bmw 335
Default Did I blow it up? - 12-02-2019, 05:46 PM
While at a red light, not moving, my n54 with 114k miles threw the engine malfunction light then shortly after it threw an oil pressure light, I waited at the light not knowing how bad it was and drove the car to the nearest stop. There is an insane amount of oil all over the engine bay and most of it spilled onto the window shield and out of the front passenger side light. I turned the car off and back on just fine. No knocking. This thing blew up, smoke was everywhere and inside the car. I checked the car and I could not find a broken hose, I did not see a hole in the block. So I pulled the codes and got one code 2A98- crankshaft inlet correction. Any ideas what could have happened? Is it worth fixing? someone please help
335i e90 sedan| Cobb catted *** | Muffler Delete | VRSF 5 stepped intercooler| BMS OCC | BMS dual cone | MMP Inlets | BMS Oil Temp Cooler | JB4 G5 | PureEvilTuning Custom E60 BF | XHP TCU Flash | Phoenix Racing Charge Pipe | Tial BOV | 3.5 Bar | Stock Turbos | NGK 2 Step Spark Plugs (0.020 Gap) | Fuel It Stage 2 | 19psi making 475whp & 528lb tq |
Default 12-02-2019, 06:29 PM
Can't tell from a post, but something physical is broken if oil is spraying everywhere. Might be a simple oil line leak or pump failure? But if you drove with no oil pressure, probably time for a rebuild.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 12-02-2019, 11:37 PM
You should tow the car to a shop and have them diagnose what happened. Impossible to tell for sure without more information. Could be anything from a hole in the block to a hole in the valve cover or a failed oil cooler line or something.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
ReforMatt ReforMatt is offline
Car: 2010 E92 335i
Default 12-03-2019, 04:55 AM
Front passenger side light sounds like something around the fender wells oil cooler. The windshield?? Not really sure but If your not one to do surgery on your own car I would do as the op stated get it towed to a qualified shop. Good luck
Car: 2008 E93
Default 12-03-2019, 11:20 AM
Agreed
I also felt oil cooler or lines when reading this thread yesterday. Windshield ? Oil sprayed from front to back because of fan most likely ?
lanii00's Avatar
Car: bmw 335
Default 12-03-2019, 12:11 PM
After cleaning all the oil, looking for hours, I decided to put more oil in it and have someone turn it on and off quickly, as a result I found the issue! The bolt holding the oil cooler housing was pushed back and too the thread from the oil filter housing with it. The gasket is tore and oil flew up onto the hood in seconds. Looking forward to changing that and having it back on the road!
lanii00's Avatar
Car: bmw 335
Default 12-03-2019, 12:12 PM
Thank you all for the replies!
Car: 2008 E93
Default 12-03-2019, 12:39 PM
Can you post a couple of pics from where it leaked ?
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 12-03-2019, 10:23 PM
Happy early Christmas hahaha.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2010 E92 335i
Default 12-04-2019, 10:26 AM
I can’t even imagine how this would happen kind of a head scratcher..both seals to the oil filter housing are in a shaped groove and the seal is rubber type compound. But they don’t extend beyond the groove by much. They have had a history of leaking but typically it would be a slow leak down the front side causing a belt to very bad things to a engine. Hopefully we see some pics.
lanii00's Avatar
Car: bmw 335
Default 12-04-2019, 10:47 AM
Definitely have photos that I tried to upload from my phone but failed because the image was too large I will upload photos once I figure out how to shrink the files
codesx codesx is offline
Default 12-04-2019, 11:08 AM
Yes, it would be nice if they could scale on the fly... sigh.
Make sure your alternator and Serpentine belt is clean.
Avoid the belt shredding and getting pulled into the block through the Crank Pulley... simple issue can get complex fast if she's not appropriately clean.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
2018 - A/T Replaced | Plugs | Ign Coils | Walnut Blasting
2019 - Index 12 Injectors | VCG | OFHG & O-rings | Alternator w/ Clutch Pulley | Water Pump & TStat
lanii00's Avatar
Car: bmw 335
Default 12-04-2019, 11:58 AM
Here are the pictures, definitely lost some quality when scaled down
Car: 2010 E92 335i
Default 12-04-2019, 06:22 PM
WOW your cars looking like it spit up. Can’t tell where it actually leaked from because of the mess it left. But I would for sure break the front end off an remove any trace of the oil. Replace the belt an pulleys along with the leaky culprit. Kind of looks like the it came from where the oil cooler lines connect to the filter housing. I would be half tempted to replace that whole assembly. As much as you have invested into it already.
lanii00's Avatar
Car: bmw 335
Default 12-04-2019, 08:43 PM
As you can see this is why I thought I blew it up and the amount of smoke that went up from the hood and inside the car I truly thought the car was on fire!
Default 12-05-2019, 10:57 AM
Good news is it didn't blow-up... it just spit-up.
Fix it properly, clean it well - not minimally, but proactively.
That headlight picture is epic. Looks like it had a 1950s ballast pop.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Maintenance:
