nguyeneric09 nguyeneric09 is offline
Default JB4 STAGE 1 Logs - 05-19-2019, 11:22 PM
Hi there I am uploading my logs to see if my tune is running correctly as it should be. ATM I have two codes P112f and P142e which I will be taking care of asap. Please let me know if you need additional logs.
Default 05-20-2019, 10:32 PM
Hey a couple things
Enable 6cyl timing
Update firmware
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-21-2019, 12:01 AM
Hey a couple things
Enable 6cyl timing
Update firmware
Hello Dave Is this the correct firmware?
G5_ISO_32_14
and what number do I put to enable 6cyl timing?
also I am pulling a couple more codes if you have any idea what these are.
2D2E Angle of throttle Valve - Intake Pipe Under Pressure
29DC Cylinder Injection Switch-off
2ABC Charing Pressure sensor
3100 Low boost mode engaged CEL Displayed
2c7c Lambda Probe behind Catalytic Converter 2, Signal
Default 05-21-2019, 03:53 AM
G5_ISO_32_14
Clear codes- see what returns
Yes to firmware
Cyl timing value correlated to the DME you have
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-21-2019, 06:38 PM
Yes to firmware
Hi Dave I updated the firmware and deleted all codes only 2 show up now
29DC Cylinder injection switch-off
2D2E Angle of throttle valve - intake pipe underpressure, correlation.
I have an e90 335i 2008 I set the DME to 5 is that correct? I will get an updated log later today/tomorrow to see what else I need to adjust thanks for all the help!
Default 05-21-2019, 08:37 PM
UPDATE
I ran map 1 everything It is running good and not kicking me into map 4. here is my log please let me know if there is anything I need to update. Also the last safety is now saying 1 - Boost over safety.
These are the codes that are back on.
2ABC Charging Pressure Sensor
3100 Low boost mode engaged CEL displayed.
Default 05-21-2019, 09:59 PM
UPDATE
You don’t go WOT in the log.
We’d need a 3rd gear WOR 2k to redline log
What map sensor are you using?
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-22-2019, 02:53 AM
You dont go WOT in the log.
Wed need a 3rd gear WOR 2k to redline log
I am using the OEM sensor. and did you mean WOT 2k to redline on 3rd gear? I do not know what WOR means.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-22-2019, 11:03 AM
WOT = WIDE OPEN THROTTLE (FULL THROTTLE)
In your log (pedal) you do not go 100
Proper Logs:
A couple adaptation runs are good if you made any recent changes
Flat open road
3rd or 4th gear (preferably 3rd)
Traction off
Start log WOT 2k to redline Stop Log
Post it!
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 05-24-2019, 01:30 AM
Proper Logs:
Flat open road
Traction off
Post it!
Here is an updated log. please let me know if I need to re-do anything thanks for the help always!
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-24-2019, 02:03 AM
still not going full throttle
07 E90 AT - xHP
FBO
Hybrids
Default 05-24-2019, 06:53 AM
You only go WOT for 2-300 rpm.
We need full WOT 2k to redline.
Logging can be difficult with traffic etc- so you need to find a nice, flat, empty stretch
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-27-2019, 12:17 AM
Sorry for delay been working a lot lately no time to log but here you go! I hope I did everything right this time thank you for your patience.
Default 05-27-2019, 08:44 AM
Hey- still don't go WOT...try again : )
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-27-2019, 03:23 PM
I did go WOT I’m looking at the logs I’m not sure why it drops my foot was all the way down maybe the sensor is messed up hmm?
Default 05-27-2019, 08:41 PM
I did go WOT Im looking at the logs Im not sure why it drops my foot was all the way down maybe the sensor is messed up hmm?
possible- looks to get stuck at 76/77
e92 AT 335xi 2.0
Doc Race Kit 6062
