Jesse2321 Jesse2321 is offline
Car: Hyundai Sonata n line
Default Map 6 help - 10-17-2021, 06:18 PM
I’m just trying to figure out what’s a good guideline of making a custom map I normally use map3/4 any information helps thank you.
Car is Hyundai Sonata n line
Default 10-18-2021, 12:28 PM
First step would be to upload a log of maps 3 and 4 for review.
Default 10-18-2021, 08:03 PM
Hopefully these 2 are good I tried holding and doing it correct
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 10-19-2021, 06:21 AM
Jesse,
I've been reading logs for some time now but this one got me. Both your Map3 and Map4 logs are off. You are getting very little ignition advance, the lowest I've ever seen... Weird. At most 5 to 7 degrees and it should be between 13-15 ish or higher. I'm not talking about plugs 2-6 deviation, I'm talking overall. Maybe a BMS person can comment.
edit.... I think I figured it out.
You have FUA set to 3, not sure why. Change FUA to 0 and relog unless someone else has experience reading a log with FUA on 3??
Default 10-19-2021, 06:33 AM
Wow that’s weird I have no idea why FUA was 3 I set it to 0. Maybe could be my e% this was around 27-28 I normally have it at 32%
I have also posted map3 logs in the past and Steve looked at it and said it looked fine if you want to compare to that aswell.
Appreciate the comment
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 10-19-2021, 06:48 AM
Nah, it has nothing to do with the E content. It was probably fat fingered. With FUA on 3, timing doesn't record properly so it's impossible to assess. I'm sure Terry saw a log with it on 0 or 1.
If you could post an older one, or a new one I'd be glad to help out with Map6
Default 10-19-2021, 06:55 AM
Yeah I’ll post 2 newer ones later today with that fixed and hopefully everything will be situated then
Default 10-19-2021, 12:38 PM
When you do the new logs...
To properly evaluate the tuning, we'll need a full throttle JB4 log 40-90mph on a safe private track. Try not to hit the kickdown or induce a lot of tire spin.
This is the 2.5L correct? If so, yes, set FUA back to 0.
Default 10-19-2021, 12:49 PM
Kk I think this was 30-130 so I can do that. And yes this is the 2.5
Default 10-19-2021, 06:18 PM
Kk here are 2 newer ones I started the log at around 40mph then pretty much floored it
Car: Evo VIII
Default 10-20-2021, 10:11 AM
Both maps look to be running good.
Default 10-20-2021, 11:09 AM
Lets try this again....
"This is the 2.5L correct? If so, yes, set FUA back to 0."
FutureUseA (FUA) as of v22 firmware:
FUA 1: Show cyl 2-6 as raw timing rather than timing corrections.
FUA 2: Required for 2018 and earlier 1.6L models
FUA 3: Required for 2019+ 1.6L models
Default 10-20-2021, 11:17 AM
Yes I set back to 0 those 2 logs above are me setting FUA to 0
AWDGT2's Avatar
Car: 2019 AWDGT2
Default 10-20-2021, 11:32 AM
See attached
Default 10-20-2021, 11:43 AM
Originally Posted by AWDGT2
See attached
Weird I set it to 0Ö Iíll do it again
Car: 2020 Kia Forte GT
Default 10-20-2021, 04:18 PM
Beyond all this settings stuff -
What exactly are you looking to improve with Map 6?
If it's traction off the line and since it's a DTC, try enabling 1st gear boost reduction.
Other than that, I don't know when the 2.5L runs out of puff and would need to see logs as everybody else has suggested.
IMHO Map 3-5 are plenty aggressive for the vast majority of people. Most of the extra power is going up in smoke with wheel spin anyway.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Default 10-24-2021, 07:19 PM
fixed the fua to 0 i had to be connected lol
goal is just to see how much more it can be pushed I guess to the comment above. but I agree map 3/4 are very aggressive and I notice a huge difference on map3 always
Car: Evo VIII
Default 10-26-2021, 09:50 AM
Both logs appear to be healthy.
Default 10-29-2021, 05:56 AM
Ty
