(#1001)
Default 07-31-2018, 10:01 AM
Originally Posted by alexk
Hello
I have the JB4, with burger chargepipes and watermethanol kit.
My question is whether it is better to run 100% methanol or the 50-50 methanol and water mix.
I always run 100%, 50/50 is okay too though.
garyf10m5 garyf10m5 is offline
Car: F10 M5 CP
Default 08-01-2018, 02:20 AM
It's not used on the platform yet so leave it at 0.
Thanks for your response, Terry. I recently got the CSF intercoolers that came with 4 meth bungs(2 on both sides) and intend to use them for my BMS meth injection instead of those on the chargepipes. Do you think my 220psi cooling mist pump that came with your BMS meth kit be able to support say 4 BM7/BM10 nozzles? Or a higher capacity pump say "Pro Meth" 300psi pump is required? Thanks in advance.
Default 08-01-2018, 10:12 AM
It's mostly about flow, not pressure. Our pumps flow 1.3GPM IIRC which is a lot.
I just don't see any reason to be needing all those nozzles. Even our customer car with 1100whp F10 M5 wasn't running those large of nozzles and he had 4.
You should be fine with twin BM10 nozzles after the intercooler, that's what I would do.
Mrshorty14 Mrshorty14 is offline
Car: 2012 BMW X5M
Default 08-20-2018, 10:04 PM
Hey Terry, Iím having trouble with my jb4. Is there any way that I can send you my data log so u can take a look at it?
Default 08-21-2018, 02:09 PM
Email me and send me the CSV to check it out.
Payam@burgertuning.com
Car: 2012 BMW X5M
Default 08-21-2018, 04:08 PM
Ok thanks. I just send email it to you.
sabujan sabujan is offline
Car: 335i f30 2012
Default 08-24-2018, 12:07 AM
when can we expect MHD and Burger BEF for F85 S63 TU ?
Default 08-24-2018, 08:16 AM
As soon as MHD releases the flashing tools for it!
Default 08-25-2018, 09:29 AM
Hey guys, recently adjusted the S63TU JB4 mapping to make map4 a low boost "VALET MAP". This has the dual purpose of having a slower map you can let "friends" borrow the car with, an economy map, and a more effective safety map especially for those running back end flash maps with higher targets.
Will add the firmware to the first post and could use a couple logs on it to ensure it's working right!
Sossa215 Sossa215 is offline
Car: F10 M5
Default 09-04-2018, 04:41 PM
Is there any use of running my JB4 along with my BM3 stage 2 flash? If so how do I do it?
Default 09-05-2018, 11:29 AM
Of course! Set FUD bit 6 on and get a log on map 1 to start and post in support so we can evaluate for you.
Car: F10 M5
Default 09-05-2018, 02:04 PM
I should do that log on map 1 of the JB4 even though Iím running a stage 2 flash?
Default 09-05-2018, 03:17 PM
Get a log on map 0 so we can see how your flash tune is set up.
NEIN NEIN is offline
Car: F10 M5
Default 09-08-2018, 01:00 PM
If I have a BEF, do I need to set FUD bit 6?
Default 09-08-2018, 01:20 PM
Yes set FUD.6 on.
Car: F10 M5
Default 09-08-2018, 01:29 PM
When you are using stick TMap censor what should you have the N20/TMAP set to?
Car: F10 M5
Default 09-08-2018, 01:30 PM
When running stock TMap censor what should the N20/TMap be set to?
Default 09-08-2018, 05:27 PM
Should be left alone, no need to touch it.
Car: F10 M5
Default 09-08-2018, 07:21 PM
Ok, trying to figure out this TMap ground error that I get once in a while.
V8MUNRO V8MUNRO is offline
Car: F10 M5
Default 09-14-2018, 12:35 PM
I have hybrids and flashed ecu can i try/ use bit 5 (self learn duty bias) and is bit 6 worth me using or trying? Also what does bit 6 change? I have got my duty bias dialled in pretty well but be good to see if jb4 thinks it should be different.
F10 M5 SAKHIR ORANGE
Car: F10 M5
Default 09-15-2018, 01:07 AM
Sorry just seen to set fud 6 on whats it change exactly?
Car: 335i f30 2012
Default 09-15-2018, 08:07 AM
Hi Terry .. I have a JB4 connect kit REV3 with blue wire removed from M135i - to which wire should i connect it on my S63TU V1 board. Thanks
