verellic verellic is offline
Car: Q60 Luxe 3.0t
Default Q60 3.0t Data Logging Help - 06-19-2019, 06:20 AM
Hey everyone, I just received my JB4 yesterday and have been messing around with the different maps and map 6 specifically. However I'm having this weird issue regarding my AFR and Ignition timing. It seems whatever map I run (even map 0) the AFR and timing seem fine at idle, but after going WOT and letting off the throttle, both gauges max out and the graph looks very concerning. I don't see why it would be doing this on map 0 though, any thoughts? Ill post a few different logs soon.
My only current mods are:
HKS Resonated Lower *********
CZP CBE
Me being totally new to JB4 and all, for all I know this could be entirely normal. Would appreciate it if someone could check out the logs I posted in my reply below to let me know if this all seems normal enough!
Any help appreciated!
Car: Q60 Luxe 3.0t
Default 06-19-2019, 06:34 AM
jb4 logs - Album on Imgur
Here is an example on Map 0.
3rd gear.
jb4 map 6 log - Album on Imgur
Here is an example on Map 6.
4th gear.
Car: q50
Default 06-20-2019, 06:15 AM
Not sure what looks concerning to you. The AFR after a pull on decel will go full lean since the ECU is cutting off fuel injection. This is normal.
Car: Q60 Luxe 3.0t
Default 06-20-2019, 06:43 AM
Yeah after thinking about it a bit I realized this as well. Other than that though, how does my map 6 look i terms of AFR and timing?
Car: q50
Default 06-20-2019, 07:02 AM
Its always tough to tell from a pic. You didn't go to redline so I cant tell if you tapered the boost curve or not, but you should above 5000 as the turbos start running out of breath. Otherwise looked pretty good.
Car: Q60 Luxe 3.0t
Default 06-20-2019, 07:06 AM
Yeah I just did a quick run and wasn't able to get to redline, but I do taper boost off after like 5500.
Default 06-20-2019, 09:09 AM
For logs attach the CSV directly to the post so I can open it in the windows JB4 interface to view.
Car: Q60 Luxe 3.0t
Default 06-20-2019, 09:20 AM
I'm on my phone right now and was only able to upload the csv to my Google Drive, I hope thats okay.
Google Drive
