Ke93 Ke93 is offline
Car: 335xi
Default New to tuning. Review my log please - 05-22-2019, 08:00 PM
Hey there fellow bimmer lovers. looking to fine tune this tune. Im full bolt on arm motor sports kit W/(jb4 bef mhd) in an awd 335xi 2008. I have never had a tune installed on any of my cars and id like to get some help with the setup of everything. I'm not sure what to do so im just gonna leave this here. Thanks for all of your input i greatly appreciate it.
Edit( i realized i was to be in drive for this per the forums at virtual dyno.I did this log in the gear selection mode going from 3rd @ 2-2500 wot to redline. is this accurate? trying to get a base line hp figured out as well as have you fine gents review and tweak my setup.
Car: 335xi
Default logs - 05-22-2019, 08:05 PM
These are my date logs. i believe i did them correctly. 2-2.5 k rpms in 3rd gear wot to redline.
File Type: csv 190522_2146jb45222019mhd flashjb4mode2.csv (7.0 KB, 36 views)
Default 05-23-2019, 12:11 AM
Enable 6cyl timing in user adjustments
What are you using for fuel?
Car: 335xi
Default 05-23-2019, 08:20 AM
Using ethanol free 93, ill make the adjustment tonight and re log for you guys. secondly what is the proper technique for a proper data log. im under the impression it is a 3rd gear @2500 pull w.o.t up to 6500rpm? question being is this done in the sport mode or race mode?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-23-2019, 11:39 AM
A couple adaptation runs are good if you made any recent changes
Flat open road
3rd or 4th gear (preferably 3rd)
Traction off - manual mode if auto (try not to hit the kick down button)
Start log WOT 2k to redline Stop Log
Post it!
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 335xi
Default 05-23-2019, 03:02 PM
Thankyou for the clarification! ill do a couple logs tonight I have just the spot ! Stay Tuned for new logs tonight
Default 05-24-2019, 12:29 AM
Just be safe
