(#2201)
BS1983 BS1983 is offline
Car: 2017 Infiniti Q50 RS400 AWD
Default 01-29-2018, 12:44 PM
1. Yes, any modification can void your warranty if it causes damage.
2. Generally speaking it's not able to be tracked once removed, but we do not encourage or endorse warranty fraud. Pay for any damage you cause with modifications, Stage1 or otherwise.
3. Yes, nice gains on even 91 octane.
4. Data cable or blue tooth adapter is required for any tuning adjustment to the Stage1 or JB4.
Thanks for the reply...so I can use the blue booth adapter if I only get the Stage 1?
jrobohm's Avatar
jrobohm jrobohm is online now
Default 01-29-2018, 02:18 PM
Yes - Take a look at post # 371 - the BT Kit / Phone App is not cheap but well worth the investment for Logging and easier Map changes from the comfort of inside your car!
Default 01-29-2018, 03:27 PM
Yes
dprada01 dprada01 is offline
Car: Infiniti Q50RS
Default 01-29-2018, 06:28 PM
Yes
Do you have any experience using the JB4 on top of a tune?
My biggest problem is that the stock parameters are very inconsistent.
I wonder if a flash will help keeping timing/boost target consistent. Then I could boost control above letís say a stock target of 18 vs 13-14. Iíve never seen an ECU vary so much. Some pulls my stock ECU psi levels are at 14 and some pulls itís at 7-8. ign looks consistent and the same, IATs are around the same ball park. Idk why on some pulls itís such a huge boost difference.
ekpogi ekpogi is offline
Car: Infiniti Q50
Default 01-29-2018, 08:19 PM
uh...not sure if the question is serious or not. If you could get a tune, why not tell your tuner to set the boost and correct other parameters you want right there? Technically, you can still use JB4 but it's pointless IMO. Let alone you're going to mess up the mappings your tuner have done.
Default 01-29-2018, 08:32 PM
Actually quite common. Flash tuner loads a conservative tune for use with pump gas, then you use the JB4 to up boost a bit when E85 or higher octane fuel is in the tank, or fill in areas of the curve you'd like to tweak.
Car: Infiniti Q50RS
Default 01-29-2018, 08:59 PM
Exactly. I was thinking a conservative pump tune at 17-18 lbs with the cam angles and ignition tables tweaked for power and smoothness. Then when I run the cut outs after the ******* D o w n p I p e and e85 I up the boost to let’s say 21-22 and let the Ecu adjust timing from there if need be. Instead of trying to boost 22 lbs by just over shooting the PSI 7lbs all the time.
I love the map changes and boost by gear the jb4 has to offer. With a flash tune I just get one flash and that’s it. So I’ll pretty much raise the bar of my starting point and use the JB to tweak the fueling and boost by gear or what not as well as logging since I already have the Bluetooth module.
5oh_mo 5oh_mo is offline
Car: Q50
Default 01-30-2018, 10:27 AM
For people running E mixtures with JB4, how poor is your MPG comparing to running straight 91/93?
17' Q50 RS
QFitty's Avatar
QFitty QFitty is offline
Car: 2016 Q50 Red Sport
Default 01-30-2018, 11:01 AM
@Terry
What would be an ideal ignition value for plump gas? I guess I'm trying to understand at what point do I need to add more octane by looking at my data from 3,4,5 psi etc..
2016 Q50 Red Sport
Ecutek tuned
Infiniti Sport Mufflers
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 01-30-2018, 01:15 PM
Maybe 2-3mpg less.
Awgd8 Awgd8 is offline
Car: 2018 Q50 3.0t Luxe AWD
Default 01-30-2018, 01:44 PM
Same for me. I donít see any difference.
I only mix 2.5 gallons max of E85 to 17.5 Gallons of 93 shell( no ethanol mix) V-power. When I had an Ecutek Q40 NA engine I only fill my gas tank halfway (10 gallons) so car is lighter, but with the Q50 tt, I do full tank since the lowend torque is amazing!
Default 01-30-2018, 01:49 PM
That make sense since the ECu mapping with the flash tune is setup a bit more aggressive than the stock fuel mapping.
Default 01-30-2018, 01:53 PM
Exactly. I was thinking a conservative pump tune at 17-18 lbs with the cam angles and ignition tables tweaked for power and smoothness. Then when I run the cut outs after the ******* D o w n p I p e and e85 I up the boost to letís say 21-22 and let the Ecu adjust timing from there if need be. Instead of trying to boost 22 lbs by just over shooting the PSI 7lbs all the time.
I love the map changes and boost by gear the jb4 has to offer. With a flash tune I just get one flash and thatís it. So Iíll pretty much raise the bar of my starting point and use the JB to tweak the fueling and boost by gear or what not as well as logging since I already have the Bluetooth module.
Why only one flash? Normally, Ecutek gives you different maps?
It will be nice if the Jb1 can be tweak to add boost per RPM. I only have JB4 so Iím not familiar with JB1. So if I have an ecutek flash with JB1 (cheaper),
I could tweaks the valleys in my tune... With Ecutek BT, I could see if Iím leaning out with the JB1.
ThreeBlockWar ThreeBlockWar is offline
Car: 2017 Infiniti Q50 Red Sport
Default 01-30-2018, 03:13 PM
Someone can correct me if I'm wrong, but I think that wouldn't be possible on the JB1. You would need access to the OBD port which is part of the JB4 in order to make those changes.
Default 01-30-2018, 03:26 PM
I think you are correct!
Default 01-30-2018, 04:24 PM
Terry, do you sell the OBD2 JB4 wire separately? (The one that goes via rubber grommet)
Default 01-30-2018, 04:46 PM
Yes, it's on our upgrades page.
Default 01-30-2018, 05:06 PM
Thank you!
Infiniti Addict Infiniti Addict is offline
Car: 2016 RS400 AWD
Default 01-30-2018, 06:13 PM
Originally Posted by QFitty
@Terry
What would be an ideal ignition value for pump gas? I guess I'm trying to understand at what point do I need to add more octane by looking at my data from 3,4,5 psi etc..
You want ignition to rise with rpm like in this log
Name:  BT good log.jpg
Car: 2016 RS400 AWD
Default 01-30-2018, 06:15 PM
This shows a bad log.
Name:  BT bad log.jpg
Car: Infiniti Q50
Default 01-30-2018, 07:06 PM
While I don't doubt that it's technically feasible, i don't think it'd be practical. In Ecutek, for instance, you can have more than 1 map and you can choose the tune that suits your mood.
Anyways, to each his own.
Default 01-30-2018, 07:21 PM
There are a lot of extra features we can add in to the JB4 like boost by gear, additional safety systems, wireless data logging to your phone, water/meth system integration, and other functions, that will exceed what you could do flash only. Not to mention who wants to flash their car in the staging lanes and hope it all goes to plan at the track? Down the road we'll detail some of the benefits of running the JB4 in conjunction with a flash map.
mattds mattds is offline
Car: q60
Default 01-30-2018, 08:50 PM
Many BMW guys run a flash and then jb4 on top. Its an easy, quick way of upping power...
chainar1 chainar1 is offline
Car: 2017 Q50 Sport
Default 01-31-2018, 12:44 AM
Terry,
Can you take a look at these two logs? The first is at +5psi and the second is at +6. I've noticed my timing seems to dip at peak boost a bit and then rise as I move up the RPM range and boost tapers as I approach redline.
I'm running 93 pump on map 2 99% of the time on my SS. I've run +6 maybe once or twice to test it out. Regardless, the timing dip occurs on either map. I've seen this happen occasionally in the past, even on Map 1, but it seems to be more frequent and perhaps a bit more pronounced as of late. Odd. Nothing has changed (no new mods, same gas, same map).
Anything I should be worried about?
2018-01-21 16_12_24.csv
2017-12-20 13_03_33.csv
Car: q60
Default 01-31-2018, 12:28 PM
Originally Posted by chainar1
Terry,
Attachment 71151
Attachment 71152
Hey there, Terry had told me that ideally you want your ign numbers to keep climbing...and yours seem to be falling partially.
what i don't know if how to fix that. I know for myself, fuel plays a big part in it. 91 octane won't do it if i'm asking for high boost. A stock redsport tops out at 14.3psi...so in some cases your pushing that.
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
jrobohm
