(#951)
Grip Grip's Avatar
Grip Grip Grip Grip is offline
Default 06-28-2015, 04:06 PM
Originally Posted by MHD
You can see the loaded file in Read codes.
If you don't see your purchases, make sure in Google Play that you are logged in with the same email you made the purchases with. Then go to Android settings, apps, and clear MHD file cache. Then reboot the device.
- Martial
I just cleared the Cache, rebooted the cell, and it still informed me that I'd need to "Obtain a license". There is also an option to "clear data", but I don't think you want me to do that. Thanks for the suggestion though.
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 06-29-2015, 10:48 AM
The user that blew two turbos was running the JB4+BMS backends loaded with MHD, not a MHD stand alone map.
- Martial
My mistake, sorry.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-29-2015, 11:32 AM
Yes, clear data (or delete app) then reboot.
Beemin Beemin is offline
Car: 2007 e92 335i
Default 06-29-2015, 01:29 PM
I'm still unclear on how MHD reads and stores your stock bin.
I currently have a bms pump flash loaded through Bimmerboost and a BT Cable. In order for the MHD to back-up my stock bin, will I need to flash my car back to stock using the BT cable, or will MHD recognize my car and have the stock bin on file, even though I have a pump flash?
07 E92 335i 6MT- BMS JB4 G5 ISO, BMS Meth Kit with dual CM7's, MMP inlets/outlets, AMS FMIC w/ custom 3" Lower CP, N54 Tuning ***, BMS CP, MHD, PE Mod Exhaust, 4" tips, Vibrant 1792's in place of secondaries, BMS OCC, N20 TMAP, RB PCV, BMS CDV Delete, BMS Clutch Stop, BMS/Shifteck SSK, BavAuto Weighted Knob, 335d intake, 335is Engine Mounts, E46 M3 Tranny Mounts, Redline Mt90 & diff, 1/4 BOV barb, OEM Aero Lip, CSL Trunk Spoiler, Painted Side Markers, Angel Eyes, Enkreuz H10R 19in Wheels, coded.
Default 06-29-2015, 02:16 PM
Not sure if this has been asked yet- any plans for datalogging and monitoring via Bluetooth. Something about cables all over that really irritates me
volcom8190's Avatar
volcom8190 volcom8190 is offline
Not New Member
Car: 2010 335i
the data logging rate will probably be much lower than with the cable,
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 06-29-2015, 06:02 PM
What does MHD stand for? genuine question
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
Grip Grip's Avatar
Default 06-29-2015, 06:13 PM
Worked perfectly. Thank you very much.
Default 06-29-2015, 11:17 PM
Martial Hesse-Dreville ?
goodboy1451 goodboy1451 is offline
Car: BMW 1M
Default 06-30-2015, 01:10 AM
Many Happy Delights?
rosullivan04's Avatar
rosullivan04 rosullivan04 is offline
Car: 2008 335i
Default 06-30-2015, 09:26 AM
I just flashed the latest 93+FMIC with the wastegate rattle and cold start noise fix and WOW, it made a tremendous difference. The car sounds phenomenal now with that annoying rattling gone. Great job! I love how this just keeps geting better and better
2008 335I 6MT
Antonio91 Antonio91 is offline
Default 06-30-2015, 11:03 AM
hey does anyone know how to run a custom flash with the JB4. on a n20 map. for example would i have to set the n20 feature on the MHD flash or let the JB4 control that.
i think this was answered some where in the thread but i can't find it
I'm asking bc i tried this out but get a 3100 low boost code along with throttle closure
max's Avatar
max max is offline
Default 06-30-2015, 04:41 PM
Martial H. Dillon
Drives 2011 335is
NOTE: Post count does not reflect any actual knowledge about anything.
Default 06-30-2015, 07:23 PM
Use our back end flash maps as a reference. They are in the first post.
Default 06-30-2015, 09:40 PM
Terry this was a log of mine on map 7 w/ PI. using the BMS single turbo flash via MHD. what do you think of it?
its on 100% e85
jordan313 jordan313 is offline
Default 06-30-2015, 10:50 PM
its on 100% e85
that log looks good but lpfp is getting low in the upper rpm's. what turbo and fuel pump?
Default 07-02-2015, 07:00 AM
I apologize because I only scanned about half this thread for the answer but after 45 minutes I thought I would just ask since I saw several others have without a answer.
If I am running a BMS flash using BB flash tool do I need to flash back to stock map to move over to the MHD BMS flashes?
Thank You
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 07-02-2015, 07:07 AM
Thank You
Nope, you can just flash right over top of the BB Flash.
Default 07-02-2015, 09:14 AM
its on 100% e85
Seems OK. I'd switch to the twin turbo E85 flash though. Looks like you can take the extra timing.
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 07-03-2015, 03:07 PM
just noticed terry that you updated the bb flash will you updating this flash as well?
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
torn08 torn08 is offline
Car: 08 e93 335i
Default 07-03-2015, 04:04 PM
Is there a difference in the BB and MHD flash files?
08 e93 335i - JB4 w/Trebila tune, alpina trans flash, bms dci, vrsf cp, tial bov, vrsf dp, vrsf 7 fmic, bms occ, fuel it stage 2, N20 TMAP, vtt inlets, st coilovers
Running E50ish
nyt nyt is offline
Car: 335ix
Default 07-03-2015, 05:52 PM
yes
Car: 08 e93 335i
Default 07-03-2015, 05:58 PM
Thank you
Running E50ish
Traf Traf is offline
Car: 2009 135i Coupe
Default 07-04-2015, 06:41 AM
Does anybody know why the app can't connect to the ECU ? I've set the JB4 to map 0, but still...
I'am using this cable http://www.ebay.fr/itm/181743125089?...%3AMEBIDX%3AIT
csu87 csu87 is offline
Car: 09 335xi
Default 07-04-2015, 06:51 AM
Probably cable issues
