(#101)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 03-23-2015, 03:45 PM
Originally Posted by mike082802
what is the difference of just setting the jb4 to map 0?
With map 0 the JB4 is still controlling the boost but cannot log, and neither can the MHD Flasher log too.
Car: vw passat
Default 03-23-2015, 07:07 PM
so i can leave the jb4 in if i download the new firmware in the other thread using the jb4 as a pass through? how has that been for you? also any map changes to the e40?
thanks
Car: 09 E92 335i
Default 03-24-2015, 12:41 PM
Would definitely be interested in having MHD as a backend flash device. Or potentially uses JB4 for only gauge and water pump control at the track. FYI, I haven't been a fan of the newest BB high load backend pump flash from BMS. The low throttle response has been quite jerky to the point that I have switched back to the previous version to retain the a smooth 2-3 gear pull.
Any idea what would be the date for MHD to come out of beta testing?
swat's Avatar
swat swat is offline
Car: 07 335i
Default 03-24-2015, 01:11 PM
Rule number one with developers, don't ask for ETA's!
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Default 03-24-2015, 01:18 PM
It should be perfectly smooth. If not, log it so we can see why it's not. On part throttle with high load logs you may prefer the JB4 pedal mapping to the flash pedal mapping. 4/2 enables the JB4 mapping.
Car: 09 E92 335i
Default 03-24-2015, 07:45 PM
Never got the chance with all the snow we have at midwest a month ago. Just too much hassle at this point, I will just deal with a bit of power lost from the post shift timing drop with the previous version. For my roadcourse use, a smooth throttle is much more important than extra 20 or so whp. I had tried wedge maps last year, had similar issue... I am not too well versed with the fine details in the difference in each of these flashing solutions, but I believe the high load maps with the BB software request too much load at lower-mid rpm under partial throttle, causing overboost which JB4 and DME then tries to correct by dropping wgdc and/or throttle opening, leading to a jerky power delivery during initial throttle application. But again, I am just guessing. FYI, I always uses the 4/2 options.
Think I would just rather wait for the MHD, seems like it is a better solution than the BB software.
Default 03-24-2015, 07:57 PM
In any event you'll need to log the car to see what is going on regardless of what setup you're using to tune it. As far as the JB4 goes with 4/2 part throttle should be perfectly smooth and repeatable, on any flash, as it ignores the flash boost target all together. When you want to fix it capture the issue in a log and from that we can see what the issue is.
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 03-27-2015, 07:42 AM
So is the MHD flasher better in the single turbo world for a mt car? Or is everything just as good as my bb flash with the jb4? I'm slightly confused. Sorry for the dumb question.
Default 03-27-2015, 08:08 AM
For an MT it can't hurt compared to BB but there is no specific benefit..
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 03-27-2015, 08:36 AM
thanks
Not yet i dont think. I had to yank my JB4 out.
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
Default 03-27-2015, 08:41 AM
Originally Posted by Spxxx
So far, I'm pretty happy with the performance of the E40 map, I do miss my 2nd gear boost limiting + boost on fuel and there needs to be some refinement of the app but it is very cool that we basically have full Cobb functionality + Tuner pro options without being locked down with expensive hardware. Just patiently waiting for the new XDF tables to be pushed public!
+1000
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Spxxx's Avatar
Spxxx Spxxx is offline
Car: E92 335i
Default 03-28-2015, 12:00 AM
So when should we start sharing bins and get some cool **** built, all the Cobb folks have such an advantage to us jb4 stacked folks who never gave a **** about boost control haha. Liking the progress so far! Finding an INPA cable that is reliable is another issue.
M-Sport 135i - N54 - FBO - E60 - Mfactory LSD - MHD - JB4 - SPX Tuned
Spxxx's Avatar
Car: E92 335i
Default 03-28-2015, 12:02 AM
You can leave the jb4 in there fully installed and load the new firmware but you will have to log with the jb4 software... Or you can use the jb4 for just gauges & remove two of the connectors + log with the obd port
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 03-28-2015, 07:52 AM
This. I can't wait for this to be available to the public. The wealth of information we all have is going to help us all to be better tuners. I always hated how secretive most "tuners" are with information. Wedge and Terry are more than willing to share and help people who want to learn more.
Spxxx's Avatar
Car: E92 335i
Default 03-28-2015, 10:32 AM
This is available now!
Haha go to the thread in this section titled "using the jb4 for just gauges (or something along those lines)" and download the firmware and load that **** up!
Map 2 is sweet if you want to live on the ragged edge, allows you to bypass the jb4 safety control for boost aka run up to 21psi and still enable limited 1st and 2nd gear boost control
Spxxx's Avatar
Car: E92 335i
Default 03-28-2015, 10:35 AM
In fact... Here you go... Option A firmware attached...
Car: 09 E92 SG
I'm flash only right now. What I meant was I can't wait to start sharing BINs
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 03-28-2015, 12:00 PM
I bought this one: http://www.amazon.com/gp/offer-listing/B008KZDDGA and it works great.
Spxxx's Avatar
Car: E92 335i
Default 03-28-2015, 09:29 PM
Sweet, I actually found a local seller in Santa Clara (Bay Area) that sells a decent quality cable, I had one for about 6 months before with crapped out haha. $30/ea
They sell all kinds of OBD wire and gizmos
DV135i's Avatar
DV135i DV135i is offline
Default 03-28-2015, 10:04 PM
How can I get one of those? I live in SF (hayes valley).
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
Spxxx's Avatar
Car: E92 335i
Default 03-29-2015, 04:34 PM
So they're kinda hard to get a hold of and also don't have a website. I might just pick up like 10 and resell them here so people have access to them. Let me text the owner of the shop and see how people can purchase them.
DV135i's Avatar
Default 03-29-2015, 07:51 PM
Sounds good, let me know!
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 04-01-2015, 07:17 AM
Originally Posted by MHD
+1, I need more testers and feedback for the e40 map. BTW the timing you quote was really for the v1 map. v2 targets 13.5 above.
If having a tester using a DCT gearbox would help then I'm happy to help.
Based in UK. Seeing different fuel blends may help?
Car: vw passat
Default 04-01-2015, 08:09 PM
The current BB flash maps can be loaded directly.
For those who run > 18psi, the race logic in this system will allow us to produce an improved version of the back end flash maps specifically for higher boost levels. I'm starting to work on that now. So far no issues having the flash map observe up to 20psi. If anyone is testing out the MHD stuff in a JB4 back end flash map format drop me an email.
i am a beta tester and want to try some of the maps. i want to email you but for the life of me i cant find your email.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 04-02-2015, 03:39 AM
Hi Guys,
Is there any update on when this will become available? Keen to try out a few new maps?
Cheers Russ
Ifreezebmx562
