(#26)
Default 03-11-2015, 07:35 PM
I got the software up and running and so far it works as advertised. Maps I've loaded function exactly as they do under the BB & Cobb environment. Only, with a little more flexibility than than we have via the free environment.
I initially was not thrilled with the licensing model but now that I've had a few days to think about it I've realized MHD will need to provide some level of support for this. So while charge per VIN wouldn't be how I'd structure pricing I can respect the model.
I'll discuss working out a special price for BMS customers who are only using this system to load JB4 back end flash maps. Maybe the system can send a ping out and the JB4 respond via CANbus to enable that special license. And for those who want to do their own tuning the existing pricing model seems reasonable compared to what Cobb charges. For those using the BB software currently we'll continue to support & develop those maps as free open source options.
mave198 mave198 is offline
Car: 07 335i e90
Default 03-12-2015, 11:06 AM
With the MHD flasher are u able to just load the current BB back end flashes?
Default 03-12-2015, 12:33 PM
The current BB flash maps can be loaded directly.
For those who run > 18psi, the race logic in this system will allow us to produce an improved version of the back end flash maps specifically for higher boost levels. I'm starting to work on that now. So far no issues having the flash map observe up to 20psi. If anyone is testing out the MHD stuff in a JB4 back end flash map format drop me an email.
trebila's Avatar
trebila trebila is offline
Default 03-12-2015, 01:02 PM
I'am.
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 03-12-2015, 08:57 PM
Question about the bolded part
Will the revisions to the back end flash maps, such as 22psi boost limit and increased torque monitor limits be able to flash thru the BT cable with the BB software?
OR
Will one have to purchase the $99 flasher module + $69 Monitor module + android device and various cables?
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Default 03-12-2015, 09:01 PM
OR
It's a unique basically closed flash platform, similar to Cobb. Each car flashed has to have a VIN license. In terms of what a JB4 owner will need to purchase to load one of these maps via their system, I don't know yet. I'm trying to work out special pricing with MHD for JB4 owners who want to load our high load back end flash maps. You can't load a high load map designed for the MHD system via the free software. But we'll maintain normal load versions of all back end flash maps for those of us using the free flash tool.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 03-12-2015, 09:22 PM
I understand,
I will be very interested in back end flash maps for the JB4 via MHD, Iíll be ok buying their modules and can borrow my dadís Galaxy S5. However if there is a price for each map (pump, race, E85) it will be hard to justify the cost especially on stock turbos where the gains are marginal (at least from the descriptions and features listed)
Keep us updated, I hope everything works out!
bnk bnk is offline
Default 03-12-2015, 09:43 PM
I understand,
Backend maps are free. They have always been free.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 03-12-2015, 10:21 PM
Regular maps yes, but what about maps via MHD flashing modules?
if free perfect!
bnk bnk is offline
Default 03-12-2015, 10:48 PM
if free perfect!
MHD supports both free and paid maps so you can pick what you want.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 03-13-2015, 12:56 AM
OR
Actually for back ends you don't need the logger module.
Terry, Trebila don't you think current backends can be improved due to the modifiable torque tables, even when targeting no more than 18 PSI?
Martial
trebila's Avatar
Default 03-13-2015, 01:39 AM
my MHD backend I'm developping since a week is already heavily modified, compared to the BB backend.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 03-13-2015, 07:54 AM
if all that's needed is a flasher module and a cable I'm on board
Originally Posted by trebila
my MHD backend I'm developing since a week is already heavily modified, compared to the BB backend.
talk is cheap, post logs...haha JK
trebila's Avatar
Default 03-13-2015, 08:08 AM
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 03-13-2015, 08:53 AM
Nice log, good timing recovery!
Default 03-13-2015, 09:29 AM
I understand,
The JB4 back end flash maps have always been free and will continue to be free. You'll just need a license from MHD to flash via that system.
Default 03-13-2015, 09:47 AM
Martial
It's difficult to say. It certainly can't hurt, and I think the low throttle mapping changes we can do with the torque monitor set to 1.0 will be an improvement. But the biggest issue facing flash tuning in general I think is false knock. For some reason when reshaping the load curve seen by the DME curves that drop load more aggressively to redline have less instances of timing drops post shift than curves that hold load to redline. Despite boost, timing, AFR, VANOS, etc, being unchanged in those areas. So this causes us to run wonky load targets like 200 tapering to 130 at redline to avoid timing drops. Which in turn leads to more work on the tuning end to make curves like that work. Part of that work is spoofing torque up as a function of load so the trans will shift well. But if we could eliminate the root issue then things could be a lot cleaner on the flash end.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 03-14-2015, 01:08 PM
I would love to have special price for MHD flasher, for BMS backend flash
any news about it?
I dont plan to go beyond BMS
2007 E92 335
ST - GTW3684
JB4 G5, ST Pump Flash, Fuel-It Stage 1, Meth
MT (after swap),
MFactory LSD
Default 03-14-2015, 03:26 PM
On timing, for example, here are two runs with similar boost curves. Both running 10psi off a WG spring on 100% E85. Actual boost reported back to the DME is the same in both logs and neither log gets up to the DME load target.
One has an internal load target of 200 all across, the other 200 tapering to 135 at redline. The one with the taper has normal timing while the one with 200 all across has massive timing issues including post shift drops. Why load target effects the timing behavior even when not running boost anywhere near that target continues to baffle me.
Levan-i's Avatar
Default 03-14-2015, 03:52 PM
i definitely want to became beta tester
what do i need to do?
levanime at gmail.com
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Default 03-14-2015, 04:07 PM
Oh, I would be all over this. Looking forward to the backends being available.
N54 | Build Thread
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 03-15-2015, 07:52 AM
one of the n54s greatest mysteries
e92
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 03-15-2015, 05:25 PM
Hi Terry. Which table are you referring to exactly?
Default 03-15-2015, 05:58 PM
If you email me I can reply with the current IJE0S single turbo file I'm testing.
Default 03-15-2015, 06:20 PM
So, I understand this is in beta testing, can we get a flasher module? Or do us that are wanting to use JB4/backend have to wait until release.
N54 | Build Thread
