Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default RB Turbo N54 Stock Frame "Hotside" Chargepipe Silicone upgrade>> - 08-26-2015, 10:52 PM
EDIT: A LOT changed since this thread was started. Please read from page 15 onward for the latest information:
http://www.n54tech.com/forums/showth...=33067&page=15
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 08-26-2015, 11:30 PM
Good progress Rob, looking forward to seeing more. I'm always blown away looking at the stock frame to see how restrictive they are and seeing alternative designs to maximize flow.
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 08-27-2015, 02:20 AM
I asked for these, this will be the final pipe upgrade piece for my car.
Timmay77 Timmay77 is offline
Car: 2008 535xiT
Default 08-27-2015, 03:18 AM
I'm doing my turbos in 2 months. Would love to get these as well as the intake piping. As long as they all fit a 535XI, and of course, will be ready in time.
Will stock turbos be able to provide enough pressure to make these worth the purchase? I'm seeing threads that claim installing a larger FMIC is causing stock turbos not being able to reach boost targets.
2014 328i xDrive Msport
m5james's Avatar
m5james m5james is offline
Default 10-06-2016, 09:20 PM
Bump for this skipped over question.
Simmi15 Simmi15 is offline
Car: 2008 335xi Coupe MT
Default 08-27-2015, 07:51 AM
It would be Great if you sold a total Stage 2 turbo kit(inlets, hotside CP, turbos) cause you mine as well just take my credit card number now. Will this Hotside CP be in the stock locations? I have AWD and I wonder if my front axles will get in the way of this upgrade.
Default 08-27-2015, 07:56 AM
Looks fantastic! Can't wait.
Stalker
Car: 335I
Default 08-27-2015, 10:04 AM
You must be a fortune teller! Much more to come than just that as well.
As for the hot side modification in this thread yes it will work with any N54 to the best of my knowledge. The only wildcard will be as always Intercooler choices and how they configured their respective hot side interface. I am saying that just to be forthright, as it could be another factor, not to generate a bunch of questions about every possible Intercooler compatibility. We have configured the sample to accommodate numerous styles to the best of our ability for now. So please all be patient for further answers in that regard.
Yes sir. Me neither and it is off today!
Car: 2007 BMW E90 335i
Default 08-27-2015, 10:36 AM
Correct me if I'm wrong, but isn't the primary restriction in the outlet ***** in the piece where it clamps to the turbo? I see you are reusing these pieces, so what's the point?
http://www.boostaddict.com/showthrea...ars-completion
2013 135is DCT Carbon Black
Stalker
Car: 335I
Default 08-27-2015, 10:50 AM
Not all will see eye to eye on this matter. So rather than waging a war, we will just provide the specs for those inquiring minds to deduce their own opinion:
1) Compressor housing outlet ID- 1.025"
2) Chargepipe flange ID- 1.060" (which immediately tapers up to tubing ID) NOTE: This is already .035" bigger than the compressor housing interface, and .275" bigger a mere .5" later.
3) Chargepipe tubing ID- 1.300"
4) RB Silicone ID- 1.5" to 1.75" to 2.5" merger
In my opinion the restrictions (beyond the housing itself) of the charge pipe are in the dimples and merger, which this modification will replace in its entirety.
Thanks,
Rob
Stalker
Car: 335I
Default 08-27-2015, 08:55 PM
UPDATE: This did go out today. Should be there mid next week. Hopefully we can have a new sample in hand within 3 weeks.
mikeseli mikeseli is offline
Default 08-27-2015, 09:23 PM
Can you show a better picture of the "Y" pipe. The angles look too far apart from the pics above.
totti totti is offline
Car: E82 135i N54
Default 08-27-2015, 09:31 PM
Do you have a rough price guide for these yet Rob?
Stalker
Car: 335I
Default 08-27-2015, 11:58 PM
It's just a tacked together piece of work sample. It all aligns right as it was all mocked up on a car. The merger is going to be great once all in silicone so no worries. Can't take more pictures though as it's already been shipped off.
Certainly no more than $250 with all 3 Stainless T-bolts clamps.
Thanks,
Rob
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 08-28-2015, 05:26 AM
I like the fact that most of it is metal pipe, but half of it is OEM sized pipe.
I'm going to sit on the fence with this to see how it compares with the other one coming out.
Do you plan on getting some dyno results vs stock ***** Rob?
Maximum996's Avatar
Maximum996 Maximum996 is offline
Car: 08 535xi
Default 08-28-2015, 05:38 AM
So all your cutting and beading is the front pipe? What dimple are you referring too, the front pipe to heat and bend out? What about core front *****, send a cut/beaded front pipe and we send back original for the people not willing to modify the front on their own...
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* DP, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
Stalker
Car: 335I
Default 08-28-2015, 08:47 AM
Dyno would not show this until the turbo is pushed until last breaths. The best way to test the upgrade would be by flow/pressure drop testing (easiest) or by measuring shaft speeds at same target boost. All in all the point of the upgrade is to avoid the turbo working harder than it needs, to overcome unnecessary and obvious restrictions in and around the charge pipe merger, to meet the same boost target (ie. enhance high-flow efficiency). Specs of all of the affiliated hardware are provided above, if you visualize each data point it is very clear that there is not any restrictions (above and beyond the compressor housing itself) within the parts remaining after this modification.
The intent is to really just offer a quick cheap universal upgrade to those who are interested to perform the mods themselves. We are not really interested in doing the mods for others, however it the demand is there we may work something out to those interested. We can discuss methods to get it done as needed when the time comes. Of course for those who want to do nothing we would have to send them core ***** and get their old back for refund. Overall it is a very simple process to just do in the field, but we would be bead rolling the front pipe after cutting it and removing the dimple.
Rob
Optigrab Optigrab is offline
Car: 08 135i 6AT
Default 08-28-2015, 08:55 AM
What is the purpose of front turbo pipe dimple? Is it to prevent the pipe from hitting something?
Stalker
Car: 335I
Default 08-28-2015, 09:01 AM
Nothing really. Likely something with the production of the pipe. That dimple in itself gets much worse all around the merger area, which is why we want to get rid of it all so there is no restriction (beyond the housing size itself).
I am not saying this part is going to make a substantial difference, ie. make 50whp, but for those who are looking to optimize a setup it will certainly help by reducing pressure drop from the turbo to the intake… which is very important to keep in mind.
Rob
Stalker
Car: 335I
Default 08-30-2015, 08:18 AM
Here are some pictures illustrating x-section views of the restrictive bits of the charge pipe that this modification eliminates. After the modification there is nothing remaining aside for straight through true ID larger tubing with a much more ideal 2 into 1 merger.
ross22 ross22 is offline
Car: 2007 BMW 335i
Default 08-30-2015, 08:34 AM
Thank you for continuing to push this platform forward. My bank account on the other hand, does NOT thank you. Looking forward to the final product and shipping dates.
Stalker
Car: 335I
Default 08-30-2015, 12:11 PM
Thanks sir. There is more to come as we have numerous further N54 upgrades in the pipeline as well, mostly addressing weak links outside of the turbos.
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 08-30-2015, 04:48 PM
Looking forward to this one.
shandyb135i's Avatar
shandyb135i shandyb135i is offline
Car: RB TURBO 135i
Default 08-31-2015, 07:41 AM
will these fit RHD 135i's? and whats the chances of a group buy on these like with the inlets?
UK RB TURBO 135i
Tuned by Wedge Performance ///
Stalker
Car: 335I
Default 08-31-2015, 07:45 AM
Yes and 100%.
And just as fyi- Our hand fab'd sample arrived with the vendor today.
