yurslo yurslo is offline
Car: 2009 335i E90, 2011 328i E90, 2012 335xi E92
Default JB4 kicking to map 4 from map 1 and 2 - 08-17-2020, 06:55 PM
As the title suggests JB4 consistently reverts to map 4. I have attached 3 logs, two runs starting with map 1 and one run starting at map 2. Had a CEL for misfire about a week ago. Replaced all coils, plugs and upgraded to full set of index 12 injectors. Also upgraded fuel pump to BMP bucketless. Although I no longer have a CEL and am not throwing codes, JB4 is still reverting to map 4 at about 3500 rpm. Also running MHD pump BEF. Please help.
Default 08-17-2020, 07:21 PM
Your on old firmware - id update
Your throwing the overboost safety.
Up that to 20
Default 08-17-2020, 09:16 PM
Up that to 20
Updated with latest firmware. Tried to up the boost safety to 20, but it gives me a message that says valid range is 0-100. Then it reverts back to a value of 6.
Default 08-17-2020, 09:18 PM
Here's the screenshot.
Default 08-17-2020, 10:24 PM
After updating firmware I took a couple sets of logs and the car seemed gutless after 3500 rpm. Logs show boost rapidly dropping after 3500 rpm. Pulls were done on map 2 and map 5. CSV files attached.
dmckmc dmckmc is offline
Car: E60 535i
Wink 08-18-2020, 12:57 AM
Try starting with the default settings for the firmware. Compare your settings to the default settings found in post 3 here: https://www.n54tech.com/forums/showthread.php?t=10605
N54
FBO
E40
JB4
MHD
XHP
Default 08-18-2020, 11:56 AM
Reset everything to default settings and that corrected the errors. Thanks. Boost is now trailing target by a couple of pounds throughout the entire range, but at least I have boost all the way through.
Default 08-18-2020, 12:36 PM
Post a log w. everything @ default
Default 08-18-2020, 01:18 PM
Log with default settings attached.
Default 08-20-2020, 08:19 AM
enable 6 cyl timing under your user adjustment tab.
What are you using for fuel?
Default 08-20-2020, 08:47 AM
Just 91 octane (CA) but will run e40 once I'm sure everything is completely situated. Will be doing a 17t turbo upgrade in the coming weeks. Replacing inlets, waterpump, thermostat and all hardware in the process. Right now I'm running ARM 5" stepped IC, COBB CP and VRSF ******* ***. I waited almost 2 months for VRSF 7.5" racing IC to ship, but they're having manufacturing delays, so I canceled my order. I imagine I'll have to get a bigger intercooler sooner rather than later.
Car: 2008 E93
Default 08-20-2020, 09:34 AM
Look into the BMS RACE FMIC!
I run this intercooler on my car, zero complaints.
Default 08-21-2020, 05:33 AM
You won’t regret it:
https://burgertuning.com/products/e-...cc4fbd41&_ss=r
