Memo Memo is offline
Car: Bmw n54 335i 2009
Exclamation My logs for terry - 07-10-2020, 05:03 AM
I have 335 n54 2009 jb4 g5 iso mhd backend flash bef race dual cone intec bms ******* vrsf intercooler vrsf vrsf exaust Street map sensor 4 bar charch pipe vrsf tial blow off bms methanol sistema cm 10
Default 07-10-2020, 06:55 AM
Enable 6 cyl timing under user settings
What fuel?
Timing looks like it drops a bit mid pull
Exclamation 07-10-2020, 03:23 PM
What fuel?
In number 5 enable 6 cyl timing under user settings ok?
I use pump 93 oct and methanol 70 30
Default 07-11-2020, 05:43 AM
The cylinder timing value correlates with your DME- so just match your DME, with the value assigned
Get that enabled & relog
Default 07-23-2020, 04:35 PM
This is the New logs with 6cc in number 5 in jb4
Default 07-23-2020, 05:09 PM
Logs
Default 07-23-2020, 05:13 PM
New logs
Exclamation 07-23-2020, 05:40 PM
Fail to send I kent the logs
Default 07-23-2020, 07:49 PM
I don’t see any logs?
Default 07-24-2020, 06:58 AM
Default 07-24-2020, 07:02 AM
I have problems sending my logs, I don't know what happens, I don't attach the record, I only send the message, sorry, any suggestion, please
Default 07-24-2020, 07:55 AM
Default 07-24-2020, 08:33 AM
Email in to support@burgertuning.com as this thread isn't working.
Default 07-24-2020, 08:39 AM
Ok terry thanks
Default 08-23-2020, 02:45 PM
Logs
Default 08-23-2020, 03:16 PM
Hello, send these previous logs to support@burgertuning.com and they tell me that I have to buy my low-pressure fuel pump stage 2 and I bought it, I'm just waiting for it to arrive these days to install it, I have to do something else, some programming to the module ekp after installing it and heard something about a fuel pump code that appears in some units n54 or just installed the fuel pump stage 2 without doing any programming I hope you can help me or give me some information about that since this is new for me ,Thank you
Car: 2008 E93
Default 08-23-2020, 11:14 PM
Just install it. Should be pnp.
Default 08-24-2020, 06:43 AM
Just install it, our LPFP's are PNP / drop in ready.
Some have had issues, but most do not. I wouldn't worry about it, unless it actually happens.
Default 09-30-2020, 05:13 PM
I already installed the fuel pump stage 2 these are my new logs but this is static my fpl in 48 does not move it is the same as when I had the oem fuel pump
Default 10-03-2020, 06:05 AM
when the LPFP value stays pegged like that, your :LPFP sensor looks to be shot.
Default 10-03-2020, 12:41 PM
Will I have to install a new one? If so, I have seen two types of sensors, one oem copper color and one from the bosch brand, which of the two do you recommend?
Default 10-05-2020, 06:58 AM
Either work.
Default 11-03-2020, 10:53 PM
I already installed my new low pressure fuel sensor now it shows at 66 psi at idle on 91 octane fuel, could someone tell me what is the normal range of the 450 stage 2 pump
Default 11-05-2020, 12:04 PM
That's normal. 65-72 at idle is what I usually see.
Default 11-07-2020, 12:16 AM
Ok thank you very much then I will do a couple of logs to know if everything is fine
