spammer's Avatar
spammer spammer is offline
Car: 435i
Default Broke my cherry got first misfire now JB4 acting odd. - 07-01-2019, 09:55 AM
So i pushed it hard, got a 4 cylinder misfire - cleared coded, restarted engine, everything runs fine again tuned down a bit things are running normal.
However, my JB4 guagues are going crazy, my trims and AFR just are going nuts trims go up to 80 (only should go to 40) back to 0 up down up down up down.
Same with AFR goes to 30 down 14 up down up down up down during normal driving or getting on it.
Anyone experience this. My JB4 board going? I'm running the beta firmware but its never had an issue for the last 3 months or so until this misfire.
Default 07-01-2019, 10:00 AM
What map? Can you get a log on map 1?
Do the gauges act up on map 0 too?
spammer's Avatar
Car: 435i
Default 07-01-2019, 10:28 AM
It did it on map 2 and map5, didn't try map 0. This is a log from Map5 you can see the eradicate behavior. Now the car doesn't feel like anything bad is going on. Runs normal just the gauges, mainly trims and AFR are acting nutty.
The codes i got when the misfire happened were.
Misfire Cylinder 4
Misfires more cylinders injection is switched off
Misfires Cylinder 4 injection is disabled.
After shutting down, clearing codes and restarting all is fine. Just filled it up with a full tank of 93 just to be on the safe said for now.
next time i'm out ill do a map 0 map1 pull
spammer's Avatar
Car: 435i
Default 07-02-2019, 09:10 AM
Reporting back. Everything is normal today. Gremlins seem to have purged themselves. Thanks for reading.
andrews013's Avatar
andrews013 andrews013 is offline
Car: 2013 E92 335i xDrive
Default 07-02-2019, 11:25 AM
Something looks wrong with AFR. Signal cutting in and out. Trims are also super low. OL is set to 0 for some reason.
spammer's Avatar
Car: 435i
Default 07-02-2019, 12:12 PM
Ya FOL is 0 now because of the E85 BEF. Terry said it should be set to 0 if running a bef. When i had it turned up the HFPF was crashing car would studder bad.
Was just some bug with the signal from the DME - everything is reporting correct now.
andrews013's Avatar
Default 07-02-2019, 01:19 PM
Ah, ok, didn't know you had a BEF. Happy driving!
